10-13-2013, 07:39 PM | #111 | |
Rep 391
I have removed the foam along the bottom edge of the doors but did notice a ever so slight increase in noise. I replaced it with a smarter looking rubber strip but that seems to have done nothing. Cant be bothered removing it. I will add another post when i get home w photos but i can debunk the mirrors as the cause of road noise. It is also the poor window seal where the mirror is located. Consider this a preview post :-) Last edited by CKau; 10-14-2013 at 08:48 AM.. |
10-13-2013, 08:52 PM | #112 |
Rep 391
Before the weekend and before u run off and start buying supplies i suggest you play with the windows and observe whether there is any downward pressure on the recess edge of the seal and any lifting on the outer edge. That will tell you if you even have a window seal issue to begin with.
10-13-2013, 09:18 PM | #113 |
Rep 72
Awesome work as always, thumbs up!
Could you please make another photo from the perspective like the following one but with neoprene tapes applied? Also, just to be clear, do you differentiate strictly between: a) wind noise (top of B-pillar) b) road noise c) tire noise ? If yes, what exactly does your latest mod reduce? a) or b)? |
10-14-2013, 08:46 AM | #114 | ||
Rep 391
The photo you quoted was of the driver's door. The photos in my post were actually of the front left door... so it's the mirror image of the driver's door. I didn't post the "before" shot of the front left as I only thought to take a photo after I had applied the tape. Anyway, I used arrows to highlight where I applied the neoprene rubber tape Quote:
I equate c) to the tyre noise and vibration coming through the suspension, where I call b) the noise that you hear through floor, panels & windows that is the tyre roar reflecting off the road. I call tyre roar the contact noise made as the tyre's contact patch hits the road. When I was scrutinising the car, I observed that BMW have gone to great lengths to insulate the floor. That's what made me determined to fix the problem, as opposed to giving up & selling the car, as I can see the basics are in place for a car that can be fantastically quiet. The sound I'm eliminating is the sensation of the windows not being closed properly when I'm driving on loud poor surfaces. Some people in the wind noise thread complain of this as well. Like them, I also touch the window switches to ensure the windows are fully wound up. But in their case wind is infiltrating the cabin whereas in my case, wind is not - only the road noise is. In terms of pitch, on poor surfaces there is a lot of low frequency rumbling accompanied by an annoying higher pitch noise that sounds like aircraft fuselage turbulence noise at the back of a passenger jet. When I put the tape in place, the higher pitch gushing noise is eliminated and I'm left with the low frequency rumbling sound. This is not a cure for c) tyre noise... when I drive on really bad surfaces, I still hear that via the suspension - but at least the aggregate volume is now a lot less than before to the point that the rumbling level is comparable to other cars I have driven (and these were really quiet cars). I've already tried to reduce tyre noise by switching out RFT's to normal tyres. I'm not sure there is much else I can do other than switching to touring summer tyres... but that's going a bit too far for me as I do want some good grip for sporty cornering.
2018 BMW X3 xDrive30i M Sport
[sold]2013 BMW X3 xDrive30d [Sold] 2013 F30 328i |
10-14-2013, 01:21 PM | #115 |
Rep 160
Just dropped of the car at the dealer for an oil change and to have them look (again) at the door seals...
They gave me a 2013 F30 as a replacement car. The thing I noticed immediately is that the doors close with a solid 'thumb' sound, whereas mine sound like a tin can. Will check tomorrow morning for wind noise when I'm on the freeway. I'm definitely reporting this to the dealer when I'm going to pick up my car tomorrow and maybe I'll ask for an appointment with a BMW inspector at the dealer to let them hear the difference for themselves. |
10-14-2013, 03:01 PM | #116 | |
Rep 72
Additional insulation adds weight though. |
10-14-2013, 04:27 PM | #117 |
Rep 391
Sorry. Forgot to mention shrouding the wheel arches also reduces road noise. I forget who has been following my exploits and assumed readers knew that already :-P
10-14-2013, 04:33 PM | #118 |
Rep 391
10-14-2013, 05:36 PM | #119 | |
Rep 72
What I meant was taking the wheel arch cover off and putting a layer of the self-adhesive automotive insulation foam onto the _whole_ surface of the wheel arch. If you do all four of them, THAT adds weight. |
10-14-2013, 06:38 PM | #120 |
Rep 391
I tried to remove.the front wheel arch but was confounded.by the plastic retaining moulding at the rear of the wheel arch where the arch meets the fender. Cant work out how to remove it as it looks to be clipped in, not screwed in. Any pointers welcome.
10-14-2013, 07:22 PM | #121 |
Rep 72
Hm, no real competence there, sorry. Reason is: that one I wouldn't do myself even if I were contemplating putting additional insulation there. Would take the car to the pros and get some solid warranty.
05-25-2014, 02:01 AM | #122 |
Rep 391
1 1/2 yrs later figured out why the road noise is so bad. It's the outer door seal of the rear doors not making contact with the chassis.
To figure out if you have this problem, use a piece of red chalk and smear chalk dust on the seals. Shut the door. If there is no chalk mark on the chassis, you know the seal isn't making contact. I demonstrated this to the service centre & took the chalk with me. My main problem is with the rear right door bottom edge barely making any contact. When they saw no chalk mark, they changed it no questions asked. How did I discover this? I had a minor collision where my left rear door had to be replaced. After the repair, the road noise was attrocious. I discovered the seal was placed very far away from where the door & chassis make contact! After they fixed it the car was considerably quieter. That's when the cogs in my head started turning. I applied the red chalk to all 4 doors outer and inner seals and found the rear right was the problem. btw when you use the red chalk, you may have to create a bit of dust by rubbing it on a coarse surface to create the dust. Good luck with this tip. p.s. after driving on really poor road surfaces, I can say the problem is nicked for my car.
06-04-2014, 02:59 AM | #123 |
Rep 160
What seal are we exactly talking about?
Could you post a picture? I also think my rear right door is the issue, but having trouble proving it to the dealer. |
06-05-2014, 12:02 PM | #124 | |
Rep 46
+1 I was sick of the crappy ride and excessive noise from the run-flats within the first 1000 miles on my 428. Switched to non run-flats and am much happier regarding noise and stiffness issues. Why can't BMW offer buyers a choice or run-flats or not??? |
06-08-2014, 09:38 AM | #125 |
Rep 1
Door Seal or Tires
New here. First post, but have read quite a bit of this material.
I have 2013 328i Sport Line with 6MT with most of the bells and whistles. I have just about 15k on the odometer. My tires seem to be in good shape so I'll have to live with the excessive noise for a little while longer I guess. I also have to agree with the door seal claim as it relates to road noise. As it has gotten warmer now there is less noise in the cabin, but still very noisy. Moving up through the gears to get up to speed is probably more noticeable for me with the manual transmission. I had my first oil change around 13.5k on the odo. Just after the oil change the engine seemed more smooth and less 'grindy', but it is now back to its gruff, harsh sounds. Anybody know whether the 2015s will be any quieter? I mean with better sound insulation from the factory? |
06-08-2014, 10:08 AM | #126 |
Rep 623
Most of the time swapping RFT to normal tires won't fix the tire noise. If anything, it will improve the ride quality a bit, but that's about all. I tried it, and more than once.
I haven't tried CKau fix yet, but the tire noise is a recurring theme of all the 3/4/4GC reviews I've read. MT, C&D, Autoblog, etc, they all mention the tire noise in all three iterations of the chassis. I wish, i PRAY it's a door seal issue, but I don't think it will be so easy. IMO, it's a noise insulation problem and we're stuck with the tire and wind noise, at least until the LCI. Or if you really wanna fix it, buy a 5 Series
Enjoying: 2014 Yamaha FZ-09 | 2015 Lexus GS 350 | 2015 Lexus RX 350
Past affairs: 2014 Lexus RX 350 | 2012 BMW 328i Sport | 2009 Audi A4 2.0T | 2007 BMW 750Li | 2006 Kawaki Ninja 650R | 2004 BMW 530i | 2004 BMW 520i | 2001 BMW 530i | 2003 Opel Vectra | 2002 Citroen Xsara |
06-02-2015, 03:16 AM | #127 | |
Rep 12
06-02-2015, 05:41 AM | #128 |
Rep 258
Drives: 2016 F80 MG/SO
What's this obsession with trying to create the quietest cabin? It's an entry level luxury sports sedan with a key word here being "entry". And since they slapped the run flats on these cars, they've been louder than ever. Some will argue (and rightfully so) that it makes the car more sporty and connected to the road. If you wanted quiet, Lexus was the way to go...or upgrade to 5 series.
Current: 2016 F80 MG/SO MT
Previous: 2015 F30 IB/SB 335i AT |
06-02-2015, 10:43 AM | #129 | |
Rep 623
06-02-2015, 11:03 AM | #130 |
Rep 1,490
And here I am trying to get more exhaust/intake noise to come in.
Current: 17 Mustang GT no bmw
Gone but not forgotten: 07 E90 335I, 04 UA6, 95 E36, 04 EP3, 16 S550 EB, 14 F30 328I Stg 1, 08 E90 328I |
06-02-2015, 11:08 AM | #131 | |
Rep 3,258
Drives: 2015 F36 Jet Black Sport Line
I know..I was looking at axle back exhaust systems myself. Guessing most of the road noise experienced were due to the RF tires. They were pretty loud on a stretch of Highway 1 that we took a few weeks ago..but other than that one section...they're fine and the car is quiet enough...
2015 BMW F36 428i JetBlack. Sport Line Edition
25% 3M Tint| |
06-02-2015, 11:24 AM | #132 |
Rep 258
Metrathon, relax dude. Didn't mean to raise your temperature. I've driven plenty of cars. Posting my opinion on the forum. If you disagree with it, be a nice guy and express your own opinion as others do
