01-10-2018, 06:28 AM | #1365 |
Rep 87
01-10-2018, 06:35 AM | #1366 | |
Rep 13
I saw the unit I mentioned above ebay uk, called "Adafruit GPS Antenna - External Active Antenna - 3-5V 28dB 5 Meter SMA [ADA960]", but I'm not sure if the unit can draw the current necessary for it to work and if it's compatible. |
01-10-2018, 06:50 AM | #1367 | |
Rep 13
01-10-2018, 09:59 AM | #1368 | |
Rep 15
I dont have anything plugged into my aux. My car does not have the green optical cable on the original unit, so i guess this has something to do with why i dont need to connect the aux cable. Flac, Mp3 and Spotify extreme is superb quality in my car with this unit, so nothing to complain about for my part. |
01-10-2018, 10:02 AM | #1369 | |
Rep 87
01-10-2018, 10:06 AM | #1370 | |
Rep 15
Yes i have idrive set to AUX. But the sound does not go trough the aux cable in the armrest. I cant notice any difference compared to orgiginal unit. But i dont have the HIFI system in my car either, maybe there would be a difference then. |
01-10-2018, 12:06 PM | #1371 |
Rep 13
I've seen some posts about poor sound quality and problems with Aux port and BT.
I’ll share my experience. I think the sound is great. At first there was a problem, someone already mentioned here: the sound from the Android system only lasted some seconds and then it stopped abruptly. I had my iphone connected to the OEM BT and configured as a phone AND as audio device. I removed the connection of audio device and only maintained the phone and after that the android sound works fine. Of course, if I change to the OEM idrive screen I get no more sound from the Android and vice-versa. I also have the Aux front connection active although I don’t have any cable between the Android and the auxiliary arm port. The connections made were only those showed in a youtube video by “BMW DIY Guy” called “Avin USA 10.25" BMW Android Multimedia Navigation System - BMW F32“. I still use the connection of my phone to the OEM BT as I don’t like very much the one offered on the Android (perhaps I should check it better) and it’s easier as it is controlled by the idrive button. I hope this helps. |
01-10-2018, 02:21 PM | #1373 |
Rep 1,893
Am I the only person with a screen brightness problem on the iDrive side? Android is plenty bright but iDrive is dim and brightness adjustment fixed at 5 (50%)
01-10-2018, 04:54 PM | #1374 |
Rep 270
Has anybody else had the iDrive side display “No signal” and the Android side be fine? The sound still plays through the iDrive side though using the steering wheel controls
01-11-2018, 01:58 AM | #1375 |
Rep 87
Not heard of this, mines at 50% brightness and is the same brightness as the android side so to turn down either I have to use the android side which is really annoying as its way too bright at night without manually keep changing it.
01-11-2018, 02:00 AM | #1376 | |
Rep 87
01-11-2018, 07:57 AM | #1377 |
Rep 270
01-11-2018, 08:32 AM | #1378 | |
Rep 49
01-11-2018, 08:39 AM | #1379 |
Rep 564
I want to through this out there too. If you have a stock audio system, I can see where the audio quality may not be an issue for you. I have a 12" sub and it seemed like there was a low pass filter. There were parts of the bass of songs that was just missing. I didn't notice any difference on the treble end of the spectrum, but I only have the stock tweeters.
01-11-2018, 08:41 AM | #1380 |
Rep 13
Yes, you are right right, I didn't see that, but I know that the guy who instaled mine didn't pass any cable to connect to the aux in armrest (I only have a cable to the glove compartment with a USB port).
01-11-2018, 08:44 AM | #1381 | |
Rep 13
01-11-2018, 08:52 AM | #1382 |
Rep 564
01-11-2018, 09:11 AM | #1383 |
Rep 49
Is there any chance to contact him and let us know what he did in the audio part?
01-11-2018, 09:48 AM | #1384 | |
Rep 87
raichean is on the forum so maybe he can confirm what he did and why |
01-11-2018, 11:31 AM | #1385 | |
Rep 3,160
Drives: 2019 M2 Competition
So.. I believe it is OUTPUT not input, like I thought it was originally.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
01-11-2018, 11:49 AM | #1386 | |
Rep 87
