09-13-2016, 02:44 PM | #1410 |
Rep 1,985
Drives: 2020 G20 320i M Sport
I think your head unit is shot. It should say No Signal if there's power to it but no video signal. I've plugged an EVO Screen to a regular NBT before and even that gives me "No Signal".
Vehicle Diagnostics | CarPlay Solutions | Retrofit & Repair Consulting/Programming steve.ma@cmbsolutionsltd.com | www.codemybimmer.ca Online Store | Remote Coding Package| ID6 Retrofit for almost all F Chassis BMWs |
09-13-2016, 03:33 PM | #1411 | |
Rep 21
But I'm starting to think the same, it's strange though, that thing is 3 months old and I'm able to VO code it without giving any error I plug in the Entrynav HU and it works, even without a screen attached, when plugging in the NBT (with or without emulator) , nothing happens but the NBT fan blowing and a noise coming from the speakers. I didn't attach the Touch controller, but I don't think that can be the issue, I also put DAB in the FA, as the donor car had it, but still no working NBT 2 other things I noticed: - the MOST light is working on the rear side - when I push the eject button, it works So, it isn't completely dead I also checked the CID voltage with HU_ENTRYNAV , also 8,5V, so the NBT isn't giving any input to the screen, like it's not waking up completely. for the ones interested: I was able to FDL code the Sports display to my HU_ENTRYNAV with 8.8" screen, which is nice. shawnsheridan , can you please give an input ? I know you're not familiar with NBT, but I'd like to know some things I can still try to get it working... Last edited by r200teg; 09-13-2016 at 03:39 PM.. |
09-13-2016, 04:28 PM | #1412 |
Rep 263
What about checking with Rheingold?
It helped me to identify former faults of my HU when I was retrofitting. You can also trigger HU functions. |
09-13-2016, 04:54 PM | #1413 | |
Rep 21
thanks! where can I find the software ? Last edited by r200teg; 09-13-2016 at 05:15 PM.. |
09-13-2016, 05:59 PM | #1414 |
Rep 41,224
Sorry, but I am at a loss here. I have no idea what is issue with your NBT.
09-13-2016, 08:52 PM | #1415 |
Rep 817
Drives: bmw M3 F80
If you have the error (emergency call Panne)
must be added (TELD) in the HO-Wort file |
09-14-2016, 02:08 AM | #1416 |
Rep 263
09-14-2016, 10:00 AM | #1417 |
Rep 41,224
PM sent.
09-14-2016, 04:20 PM | #1418 |
Rep 21
I got the NBT working
It was in transport mode! here's how you get it out: connect to vehicle read FA activate FA Read SVM(.. go to external applications double click the transmitter click the connect button double click 31 01 0f 0c 00;setenergymodedefault. -> the NBT starts and the screen comes up ! Now it asks me for the activation code for Navigation, although the Emulator is connected. Time for some further searching, but I'm happy I got the Unit working thanks all |
Fixx6.00 Deleted-User73.50 |
09-15-2016, 07:51 AM | #1419 |
Rep 21
Okay, new update:
-I've got the navigation activated (thanks Shawn), but it shows me the wrong location, when I drive, it's navigating, but i'm somewhere in the UK in stead of my actual location. I'm using a Fakra antenna from Ebay. I suppose it is faulty ? it's located behind the Kombi but I put it on the dash now for testing. - I added 6NS, 6AL, 6AK and 6AM to my FA and VO coded HU_NBT, but my connected drive menu is completely empty. I also FDL coded these: 3003 > DUN_PROFILE - aktiv 3003 > PAN_PROFILE - aktiv 3003 > ONLINE_BROWSER - beide_aktiv 3003 > ONLINE_SERVICES - nicht_aktiv 3003 > ONLINE_SERVICES_GLS - nicht_aktiv 3003 > ASSIST - nicht_aktiv 3003 > ONLINE_BROWSER_LIVE - aktiv 3003 > DATACOMM_CSIM - nicht_aktiv any ideas ? Edit: nav problem solved. Only thing not working now is Connected drive. The menu is completely empty... Last edited by r200teg; 09-15-2016 at 10:02 AM.. |
09-17-2016, 11:38 AM | #1420 |
Rep 21
BMW Live and Online sorted (Donor car did not have 6AL, zo had to put another VIN in FA)
I now have a 99.9% working NBT ! Only thing which is not always working is connecting my iPhone. I can only use aftermarket cables because Apple cables keep on connecting/deconnecting the phone next retrofit will be 6WA or PDC After retrofitting NBT, can I still get my car for having a custom ECU tune ? I thought I read somewhere to change to stock before Engine tuning... |
09-18-2016, 08:33 AM | #1421 |
Rep 63
7XP in the United States
I completed a NBT retrofit of a German donor HU everything works be the apps, the donor unit came equipped with 7XP but i'm not sure if I should try to code that or the US verion 6NR. Anyone run into this issue?
09-25-2016, 10:57 AM | #1422 |
Rep 17
I tried all day coding. When VO code ur NBT the imagine for PDC becomes allright! I had the internet working before, but now I don't. What am I doing wrong?
Donor Vin has these options: 6AA BMW TELESERVICES 6AB CONTROL TELESERVICES 6NL CONNECT. BLUETOOTH A.USB DEVICES IN 6WA INSTRUMENT CLUSTER W. EXTENDED CONT 609 NAVIGATION SYSTEM PROFESSIONAL 612 BMW ASSIST 614 INTERNET PREPARATION 615 EXTENDED BMW ONLINE INFORMATION 616 BMW ONLINE 698 AREA-CODE 2 Own Vin has this: 6AC INTELLIGENT EMERGENCY CALL 6AE TELESERVICES 6AK CONNECTEDDRIVE SERVICES 6NH HANDS-FREE FACILITY W. USB INTERFAC 6WA INSTRUMENT CLUSTER W. EXTENDED CONT 606 NAVIGATION SYSTEM BUSINESS 676 HIFI LOUDSPEAKER SYSTEM 698 AREA-CODE 2 How to combine these? Besides the NBT I also replaced my roof to a black one. The roof unit is without SOS, but however I turned it off in the VO as also in the FDL it still gives me an error. Any suggestions how to kill this error? |
09-26-2016, 03:50 AM | #1425 |
Rep 17
Hi,
Thanks for help! I VO coded the TCB today and the warning disappeared! Internet is still not working (however it did before). How do you decide to put what numbers in your VO? Do you need to put the options of the donor vin in it, or the original ones, or combined? I really don't see any logic in this... Thanks! |
10-04-2016, 07:26 AM | #1426 |
Rep 17
Hi all,
I really can not fix the internet of the car, I have the following in the VO: 609,616,676,698,6AK,6NR,6NS,6WA I also put the donor VIN in the header and VO code it twice. The only thing I dont understand is where to change the build date. Then I checked these settings: 3003 > DUN_PROFILE - aktiv 3003 > PAN_PROFILE - aktiv 3003 > ONLINE_BROWSER - beide_aktiv 3003 > ONLINE_SERVICES - nicht_aktiv 3003 > ONLINE_SERVICES_GLS - nicht_aktiv 3003 > ASSIST - nicht_aktiv 3003 > ONLINE_BROWSER_LIVE - aktiv 3003 > DATACOMM_CSIM - nicht_aktiv Everything is allright, but I still can not use bmw live or anything else related to internet. The car says it has no connection. Does anybody knows what I am doing wrong? |
10-06-2016, 04:10 AM | #1427 |
Rep 50
Hi Guys!
I have nbt evo retrofitted , after i upgrade my iphone 6 to is 10 noticed some bluetooth problems no hands-free connecting , freezing meanwhile talking etc after i repaired my phone couldnt choose to stream music (work perfect before ios10) on bluetooth just see the phone option in the pairing menu now i buy iphone 7 but the problem stay , do i have problem with my coding \ evo or its just some kind of bug \ issue from the new ios ? |
10-13-2016, 02:39 AM | #1428 | |
Rep 17
