04-13-2019, 05:04 PM | #14434 |
Rep 42,953
04-13-2019, 08:32 PM | #14436 |
Rep 42,953
PM sent.
04-14-2019, 01:08 AM | #14437 |
Rep 10
cafd_00000794.caf.012_037_100 with function names
shawnsheridan
Could you please share un-castrated version of cafd_00000794.caf.012_037_100 ? I believe you previously shared it Thank you! |
04-14-2019, 12:02 PM | #14438 | |
Rep 42,953
This CAFD though is mapped by E-Sys Launcher, which should suffice:
04-15-2019, 07:04 AM | #14440 |
Rep 42,953
PM sent.
04-16-2019, 02:15 PM | #14442 |
Rep 42,953
PM sent.
doctor8030.00 |
04-17-2019, 06:57 AM | #14444 |
Rep 42,953
PM sent.
04-17-2019, 07:08 PM | #14445 |
Rep 8
Just re-did some coding, following fitting MPPSK kit. Here's my experience and comments on the process.
The newest ECU flash caused my psdvdata 63.3 from last year not to work any more. CAF mismatch issues. Got a new psdvdata from Shawn. Thanks again. To cut a long story short (many hours wasted), the time warp script to reset computer clocks to 2018, so the Loader program will work, does not work with Windows 10 r1809. I should have read the "readme" properly in the start. Fixed by finding another laptop that still has Windows 10 r1803. And then Java has to be JRE v7 64 bit for the Loader program. Wasted some more time playing around with the latest v8 version. http://tokenmaster.blogspot.com/2015...va-64-bit.html But, even with the latest psdvdata, the FEM_BODY CAFs (and a few other irrelevant CAFs) don't match properly. For my purposes though, most of the other controller codes work fine. And the annoying "bong", for every damned reason, is now disabled. |
04-20-2019, 07:50 PM | #14446 |
Rep 4
Coding to enable Online Mail at any speed
Hi guys, my 2018 spec 340 has a HU_NBT2
Coding to enable reading and dictating SMS/text messages and BMW service messages whilst in motion works fine. I have also coded to unrestrict speedlock for video in motion which is fine. However I am unable to enable reading Online Mail in motion (using my bmw connected account to access my gmail). The option is greyed out as soon as the car is in motion. I managed to remove the handbrake and gear in P condition, so as long as the car is stationery at zero speed, the mail option comes back on again. But option disabled as soon as the car starts moving again. Any advice is greatly appreciated. If you think it can’t be coded, that advice would be appreciated too. Many thanks! |
04-22-2019, 02:20 PM | #14448 |
Rep 42,953
PM sent.
04-23-2019, 04:49 AM | #14449 |
Rep 29
Hi, I have a F31 from 2013 and need to do some urgent coding but no connection with the car.
I installed everything on my pc with WIN7 (Esys v.3.27.1, Launcher Premium 2.0, realm crack and PSdZData_Lite according to shawns pm) and seems to work ok but the car does not seem to make a connection. No ZGW available. I can't see a VIN code appearing in the ESYS selection/start screen. Connection via UTP cable + OBD cable from aliexpress. All options appear and I can choose 'F020' for my F31 so the Psz data seems ok I guess..? When refresh nothing happens.. I get an error connection code C:0027? Only an orange led appears in the utp cable. Can someone help my because my car is flickering like a Christmas tree with all the LCI LED updates.. Last edited by FrederikD; 04-23-2019 at 05:36 AM.. |
04-23-2019, 07:11 AM | #14450 | |
Rep 42,953
1) The Target Connection Window should not be blank (It should show multiple target connections for different chassis') 2) ENET Cable must be good and making good contact in OBDII Port 3) Car must have proper voltage (Make sure motor is running if car is not on a Charger). 4) Laptop must not have Firewall or any Antivirus software running. 5) PC Lan Adapter should get a fallback IP address of 169.254.xxx.xxx (Make sure it is using DHCP and does not have a Static IP address assigned to it)
04-24-2019, 03:45 AM | #14451 |
Rep 102
Coding advice
Hi.
I'm new here and new to coding and eager to learn. I have just got the I Car pro by Vgate and purchased the bimmercode app. I have tried it to code some basic changes with mixed success. Some changes have worked, others haven't. I have an F33 convertible with memory seats and auto dimming/dipping mirrors. I am about to fit power fold mirrors and the switch this week and wondered if I will be able to code them via bimmercode, or if I will need to get them coded at a local indy garage? Any advice welcomed |
04-24-2019, 11:22 AM | #14452 | |
Rep 17
Found this thread, sorry to dig it up. I have an F30, and I need to change my battery capacity. If I understand correctly, I can simply go to FEM_BODY and change the KLASSE_BATTERIE, then select code FDL. Is there anything else needed for this? Also, why would I change the VO if it is so easy to change the FDL code? Thanks! |
04-24-2019, 12:12 PM | #14453 | |
Rep 42,953
After Coding, you need to Register the battery with ISTA.
04-24-2019, 06:35 PM | #14454 |
Rep 17
shawnsheridan
Okay, another question for this obvious noob. The guide I'm following says after I change the VO all I need to do is select the module that was changed and click code. Question is, how do I know all of what was changed...like which modules. I guess in this case, specifically the battery change I made. Also, side question... how come cheat codes loads for all except FEM_BODY. I looked in the xml, I know there are cheat codes in there. As always, thank you very much for you knowledge!! |
