03-03-2024, 08:01 PM | #14477 |
Rep 1,961
Just updated my surround view to have thinner black lines.
Thread with instructions below if you'd like to do the same. https://f30.bimmerpost.com/forums/sh....php?t=2086975 |
toxik2752.00 |
03-03-2024, 08:09 PM | #14478 |
Rep 972
Drives: G12 750Li
Replace the air filter!
-2017 G12 750Li "Giulia"
-2014 F32 428i Xdrive "Bella" -2013 E82 128i "Austin" -2000 E38 750iL "Stella" |
03-04-2024, 06:16 AM | #14479 |
Rep 559
Installed and bled a new DSC Module in preparation for active cruise-control retrofit (5DF)
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, Fabspeed Catted Downpipe, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
thatgarrett1041.00 |
03-04-2024, 09:25 AM | #14481 | |
Rep 559
The installation went smoothly; I just went slow and careful to make sure that no brake lines were bent in the process and not to strip any nuts. It was a pretty big PITA to do the brake bleeding and ISTA procedure without a lift or quick jacks, but with patience and perseverance it was done |
03-05-2024, 11:06 AM | #14482 |
Professional Nomad
682
Rep 131
I replaced the standard yellow front bumper reflectors with smoke black reflectors. These end up being raised above the bumper maybe a couple millimeters. I may source some flush mount reflectors later.
03-05-2024, 11:34 AM | #14483 |
Rep 469
Ran into the same issue. Easy fix is to double or triple the layers of 3M trim tape till you get the flush fitment.
BMWCCA Member #132862 |
03-05-2024, 12:12 PM | #14484 |
Professional Nomad
682
Rep 131
03-05-2024, 03:51 PM | #14485 |
Rep 833
Drives: BMW F36, E36, E93
Spark plugs after 50k km
https://www.f30-forum.de/attachment/...02-143922-jpg/ https://www.f30-forum.de/attachment/...02-143917-jpg/
Such Fun
If you finde any spelling mistakes in my posts you may keep them, no return required |
03-06-2024, 04:33 AM | #14487 | |
Rep 3,987
03-06-2024, 06:28 AM | #14488 |
Rep 504
I didn't do sh*t to my F30 today, but I did shoot this picture.
Dyeraudio111.50 amancuso735.00 rcaso26335.50 AndrewC198911014.00 Charles B100.50 co_440i144.00 HeartbreakerF80184.00 |
03-06-2024, 11:27 AM | #14489 |
Old Member
137
Rep 86
AGA E-Brake clip
I installed the AGA E-Brake click after replacing the retaining clip four years ago with a new OEM one that also failed. Not wanting to do this job a third time, I went billet!
Car Stuff
B58 _gran_coupe_650.00 Bob Loblah91.00 disintegrator66451.50 AnimatedDriver28.00 BWbimmer276.50 davidmcw38.50 |
03-06-2024, 05:46 PM | #14491 |
Rep 136
03-06-2024, 09:36 PM | #14492 |
Rep 567
My broken brake cable clip was staring me in the face tonight and I have a spare but didn't have the energy to do it. Those billet ones look nice. Note the orange zip ties holding my brake cables off the driveshaft lol
I poly pushed my diff tonight. Last night it was ARM midpipe |
03-07-2024, 09:28 AM | #14493 | |
Rep 294
Drives: 2018 440i xDrive Gran Coupe
B58 _gran_coupe_650.00 |
03-07-2024, 09:47 AM | #14494 |
Old Member
137
Rep 86
Thank you ^_^
During a DIY rod bearing replacement (the oil pan was the real issue) and many, many more DIY projects this February and now March, I hand-cleaned every bit of the chassis.
Car Stuff
toxik2752.00 thatgarrett1041.00 Runner340370.50 B58 _gran_coupe_650.00 disintegrator66451.50 Bob Loblah91.00 AnimatedDriver28.00 co_440i144.00 B58 parts523.00 |
03-07-2024, 09:50 AM | #14495 |
Rep 1,925
impressive, that’s all i have to say.
03-07-2024, 09:54 AM | #14496 |
Old Member
137
Rep 86
The top clip pushes further back into the fuel take groove further than you would expect; a silicon lubricant (WD-40) will be your friend. Once seated, you will feel it. It's a nice solid "this isn't going anywhere" feeling.
If you do not seat it far enough, the bottom portion of the clip will drive you mad, making you wonder how this will ever clear. I would lightly liberate all metal surfaces of the clip, mount it, and then wipe it clean with acetone or denatured alcohol on a towel so the oil doesn't collect dirt and debris. Job done!
Car Stuff
03-07-2024, 11:37 AM | #14497 |
Rep 4,555
Drives: 2015 328d xDrive
03-07-2024, 11:38 AM | #14498 |
Rep 469
You have definitely inspired me to put my car up on the quickjacks and pull the belly pans down to do an undercarriage cleaning. Seems to be one of the most neglected task for most in detailing their cars.
