08-20-2019, 12:50 PM | #14807 | |
Rep 19
The ignition would turn on, but the starter wouldn't engage. Actually, if I remember correctly, the starter engaged for <1 second during one of my attempts. I then proceeded to freak out a little, and instantly went back and changed that value back. I'll try it again in the future and report back. Thanks! |
08-21-2019, 08:49 PM | #14808 |
Rep 1
Data Files
Hi Shawn,
I recently had all the coding in my 340 wiped by the dealer after a DME update. Now I receive the following error message when coding: [ACSM - 1] - [Exception - UNKNOWN] CAF cafd_00000909-005_001_003 does not support FA2FP version 001.000.152 for F030. Minimum required version is 001.000.154. Please use current PDX template! I'm guessing I need the latest psdzdata data. I'm currently using e-sys 3.28.1 with v.4.11.20. I'm a noob to this forum, but I'd greatly appreciate if you'd pm the necessary links to get the latest data file. Thank You!! |
08-24-2019, 04:53 PM | #14810 |
Rep 41,216
PM sent.
08-25-2019, 02:52 AM | #14811 |
Rep 43
08-25-2019, 08:45 AM | #14812 |
Rep 41,216
PM sent.
Nick75024.50 |
08-25-2019, 08:41 PM | #14813 |
Rep 218
Hi Shawn, thanks so much for all of your work on this forum. Could I trouble you to please send the links for esys latest version ,launcher and psdzdata as well?
I'm sure this is just the first of many thanks I'll be directing your way as I dive into this! |
08-26-2019, 05:02 AM | #14815 | |
Rep 41,216
alistairk117.50 |
08-26-2019, 02:35 PM | #14816 |
Rep 66
Hi Shawn!
Sorry to bother you for the same, but I’m just starting out. I got my cable today, I have used the Foxwell Nt520 for a few things but I would actually like to be able to code a bunch of the things you have done! Could I get all the relevant program links, anything you think I might need to start! Thanks for all you do for everyone here! |
08-26-2019, 08:02 PM | #14817 | |
Rep 41,216
08-29-2019, 07:15 AM | #14819 |
Rep 41,216
PM sent.
08-29-2019, 10:02 AM | #14820 |
Rep 854
Drives: 2020 BMW M340i xDrive
Hey Shawn, mind sending over links to the apps? Looking to dabble a bit on my 2018 340.
08-29-2019, 03:37 PM | #14821 |
Rep 172
Hi Shawn -
I've coded my 2015 F30 in the past and recently would like to modify a few things. Unfortunately, E-sys is no longer working on my laptop and I need to reinstall. Would you mind sending over the latest links? Thanks! |
08-30-2019, 08:22 AM | #14823 | ||
Rep 41,216
08-31-2019, 12:21 AM | #14824 |
Rep 1
Hi everyone, this is my first post on this board. Nice to meet everyone
Shawn, having moved from the E9x platform with INPA and everything else, I'd like to play with the F3x coding options as well. Would you be so kind as to point me in the right direction for getting what's needed please? My first thought would be to update the maps, so I'll try to see if I can manage getting an FSC code first. |
08-31-2019, 07:45 AM | #14825 |
Rep 41,216
PM sent.
08-31-2019, 01:14 PM | #14827 |
Rep 41,216
PM sent.
09-03-2019, 10:12 PM | #14828 |
Rep 53
Drives: 2012 335i
Anyone know what ECU the cars battery data is in? Mine keep resetting and I'd like to do a full flash of this ECU. Also tried to do a full flash and ESYS gave me a user data will be lost error. I hit okay to proceed but it did not continue with flash. Thanks for any help
