03-13-2020, 08:17 AM | #134 |
Rep 18
I have the logic 7 soundsystem, in my case the central speaker work perfectly everywhere, avinusa never send me update of the mcu and i never update them, my version is from 16.08.2019. in the factory settings i set the harman amplifier.
03-13-2020, 09:45 AM | #135 |
Rep 7
Hello guys. You mentioned that with carplay idrive controller works. What about andoird auto? I have used both dongle and headunite reloaded. What about steering controls in AA? For me (on 8.1 and only with headunit) they work only after I recive call. Idrive never worked with AA in any app/method.
03-14-2020, 03:42 AM | #137 |
Rep 7
03-15-2020, 01:53 PM | #142 |
Rep 11
https://files.fm/u/anvh84r9 Can anyone help how to rid of this situation once rebooted from magisk? No volume key to select or power key to press . |
03-15-2020, 05:09 PM | #143 |
Rep 86
I tried to change some tiles in ID7 but wasnt succesful without the source code of the original launcher.
Tried Car Launcher Pro. Doenst look too bad tbh. Does anyone have some useful widgets to recommend? Btw this is how it looks: |
Kri1083.50 |
03-15-2020, 05:45 PM | #144 |
Rep 6
Hi Guys,
I'm after a little help, I have a SD625 which I brought from the Astrowind seller on AliExpress. I had to perform a factory reset shortly after upgrading to Android 10, since then I've lost some of the preloaded apps my unit came with. I'm looking for the DVR software that was pre-loaded on the unit, unfortunately I don't know what this was called or where to find it? Any other Astrowind buyers out there know what app I'm looking for, or better still, can you share your DVR apk? I've tried installing DVR app that came with my camera but it keeps crashing. Thank You! |
03-16-2020, 02:57 AM | #145 |
Rep 45
idrive works whith that launcher?
03-16-2020, 12:13 PM | #146 |
Rep 117
03-16-2020, 03:06 PM | #147 |
Rep 30
03-16-2020, 05:50 PM | #148 | |
Rep 144
Do you also want me to list the other apps that were bundled with the HU? |
03-19-2020, 06:48 AM | #149 |
Rep 41
Hi,
I am not that happy with android10, since installation 3 weeks i had to rrcover 3 times now. I had to use the recovery solution with the image dince a keyboard also wont work to select factory data reset. Anyone else experience rhe same and have a solution? Im on version 1.3 Bart |
03-19-2020, 10:48 AM | #150 |
Rep 86
It does not really work with iDrive. The launcher is a little bit strange.
I switched to Nova Launcher because of that and im customizing the setup at the moment since i have 2 weeks of because of the current corona outbreak situation. I will post some images later. beeee83 I didnt have to recover once. Can you post your MCU ? What exactly happened so you had to recover everything? |
03-19-2020, 12:13 PM | #151 | |
Rep 41
never had this with the android 9 versions. and now 3 times within 6 days use. Btw a keyboard is also not working.. for selecting in the recovery mode. i can only recover by using the USB stick way. I am now trying to restore 1.2 and do a factory reset and then try a normal upgrade to 1.3 hope that helps. |
03-19-2020, 01:15 PM | #152 | |
Rep 86
Mhh weird. Please keep an eye on it and report more findings. Here is the new launcher setup by the way On the left i made a little widget in combination with Taskers new logcat feature to grab the MCU messages with the car information (mileage, speed, temperature, doors open/closed, etc) and display them on the homescreen. It uses Nova Launcher so it will work with iDrive. For the widgets im using KWGT. |
F20_M135i100.50 |
03-19-2020, 01:35 PM | #153 | |
Rep 41
Hmm has nothing todo with an interrupted boot sequeence or something I just tried restaging again first usb restore 1.2 then upgrade to 1.3 which worked fine. Installed all my apps and did a reboot via factorysettings and the screen came in bootloop again into the recovery mode... I wil stop for today. I am thinking about installing v 1.2.5 instead of 3. Mcu is still not touched since i got the screen but on the latest. Btw nice layout Bart |
03-19-2020, 02:04 PM | #154 | |
Rep 41
Btw was somebody able to navigate the recovery method witj an isb keyboard or something else? Bart |
