11-19-2019, 10:58 PM | #133 | ||
Rep 5,801
Thanks! |
11-20-2019, 12:23 AM | #134 | |||
Rep 1,519
Drives: F36 435xd
I follow the advise but there's no guarantee it won't "blow up".....
Brgds
Allan ‘15 F36 435xd Gran Coupé Ex: E46 330d, E91 330dA |
11-28-2019, 01:35 PM | #135 |
Rep 368
I don't think the oil change will make much difference. With the unmodified flange on there you'll be lucky to get 60-70k before it strips the teeth off. That seems to be the failure 80%+ of the time. If you have that flange loctite'd in place then changing the oil at some point is probably a good idea to prolong clutch life. I'm at 60k with the flange loctite'd, I went through 2 previous transfer cases by 80k mi with unmodified flanges. Just check my rebuild thread for pics of the failed part
12-03-2019, 11:56 AM | #136 | |
Rep 1,519
Drives: F36 435xd
Brgds
12-03-2019, 12:49 PM | #137 |
Rep 3,643
You also have a 6cyl N57 vehicle which came with the rubber giubo and produces less vibration than the 4cyl N47.
12-03-2019, 12:52 PM | #138 | |
Rep 1,519
Drives: F36 435xd
Is that part of the problem? Too much vibration from the 4 pot diesels?
Brgds
12-03-2019, 07:41 PM | #139 | |
Rep 3,643
LCI N47 cars came with a mainly rubber giubo (like the 6cyl models always had) and haven't recorded any failures in the database.
12-03-2019, 07:45 PM | #140 |
Rep 368
Yes, the guibo on the N47 is aluminum. BMW swaps them out for rubber now as part of a transfer case swap. That alone should definitely help the lifespan. Not sure what the frequency of failure is on the N57, but its epidemic on the 4 cylinder.
If the N57 is fairly problem free already having a rubber guibo then the loctite may be overkill. But if it suffers the same flange wear problems, I would do it on my car Edit: if the LCI models are problem free, then the guibo sounds like it's a sufficient fix! Hopefully my spare input shaft and flange will never need to be installed! |
12-04-2019, 12:46 AM | #141 | |
Rep 776
No question the rubber guibo is kinder than solid. |
12-28-2019, 12:47 AM | #142 |
Rep 12
Is there a database of those that are trouble free here? Seems odd such a fundamental part to the xDrive system that has been around a while his having such issues. F3x in general seem to have the issue with the D being kinda common on the 'forums'.
02-17-2020, 09:25 PM | #143 |
Rep 19
The replacement TC failed with 80k on it, 166k miles in total. I had purchased the TC at the dealer on 2/20/18. It was still under warranty by one week! The dealer replaced it for free, parts and labor, even though I had installed it myself.
I had them install the updated rubber guibo at my cost. I'm going to use Loctite 680 on the flange. Next time the TC fails, I'm done with BMW forever. To quote the lead foreman at the dealer, they are "disposable" cars. |
02-17-2020, 10:48 PM | #144 | |
Rep 1,855
https://www.henkel-adhesives.com/us/...ctite_660.html It's sad that it happens, but it should be preventable with that. I bought a used gas V8 transfer case (N63) same part number, for testing, and it had zero wear.
02-18-2020, 12:24 PM | #145 |
Dr Drei
71
Rep 245
Subscribed.
Fingers crossed I have no issues with the TC on my X3 diesel. Based on my reading, the X3 is equipped with a different TC and hopefully is not one of those prone to early wear. I will have it inspected when I do the driveline fluid drain & refill.
GLK 250 // 126xxx miles // 36 MPG // Mobil1 ESP 5w30
02-18-2020, 03:09 PM | #146 | |
Rep 1,855
ATC45L is a chain drive transfer case from what I see, and isn't as compact. It has the same non-pressed flange design, which doesn't inspire confidence. I have one used ATC45L TC coming in for exploring/research and as a spare for my dad's X3 28d (which is tuned and amazing by the way). I'll pull the flange and see what can be expected. I'll get pics.
02-19-2020, 09:39 AM | #147 |
Dr Drei
71
Rep 245
Looking forward to the pics, thank you in advance.
If possible, when I get the fluids changed I'll get pics to see if there's anything in them. Hoping that since it's a bigger case, it has more fluid capacity which should help with several wear factors.
02-19-2020, 10:59 AM | #148 |
Rep 1,855
I don't think any of these have had actual failures due to lubrication (yet).
The mass majority of failures are output flange, followed by a distant second: the module/actuator having an electrical fault (easier fix).
03-11-2020, 01:11 PM | #149 |
Rep 109
Just added mine to the spreadsheet. I also did a write up on my symptoms, diagnosis, and replacement here: https://www.revogarage.com/bmw-f30-transfer-case/
03-11-2020, 01:48 PM | #150 | |
Rep 1,855
You should be entering in the transfer case calibration code before module initialization/re-learning procedure. Of, if you did it, specifically mention it. This isn't a job that can be done without the proper tools. The transfer case will eventually throw errors for calibration issues if the transfer case code is mismatched. Secondly, have a look at this thread, it may help others as well with preventing the failure: https://f30.bimmerpost.com/forums/sh....php?t=1579087
-2019 M2 Competition MT, Alpine White. Self-tuned 560hp -2016 Mini Cooper S, MT. Many plans. Others: -E36 328is. 2000 Z3 Roady. 2003 VW Jetta TDI Manual. Estoril Z3M Coupe. Last edited by Enabled; 03-11-2020 at 02:03 PM.. |
04-10-2020, 02:26 PM | #151 |
Rep 329
Just to contribute to this thread, my transfer case failed under the previous owner at 23939 Km. At the same time, they diagnosed catalytic converter failure and replaces the cats. $$$
That visit alone was probably valued around $10 000 based on previous quotes. Car is F30 328i 2013
If you can imagine it, you can achieve it.
If you can dream it, you can become it. |
04-30-2020, 06:32 PM | #152 |
Rep 13
Mine was replaced at 66k. When i bought the car with 40k on it i always felt like something was slipping. Changed the oil in the transfer case and it help for a while.
Got it done under warranty. Now at 85k no problems. I just saw this today. Maybe something causing these TC's to fail. https://www.usatoday.com/recalls/aut...TSA-20V185000/
2014 328d Sport Wagon (Estoril Blue)
2010 E92 335i Xdrive (Montego Blue) |
04-30-2020, 10:15 PM | #153 | |
Rep 1,855
05-01-2020, 09:47 PM | #154 | |
Rep 13
Good read on you t-case flange.
