05-29-2022, 01:12 PM | #133 |
Rep 1,181
You don't have to test on a full tank just add some gasoline to a low fuel E45 to make around E25 and after testing adjust it again to E45.
If you fill 10 liters gasoline on a quarter tank E45 you will get around E25.
2018 340i 8AT RWD - M Sport - Catless MPPSK - Stock Turbo - TU HPFP
Tunes: Self Tuned via MHD - Fuel: E18/92RON/87OCT https://datazap.me/u/ims/e20max?log=0&data=4-19-29 |
WrxToBeamerGuy517.50 |
07-15-2022, 07:05 PM | #134 |
Rep 684
I just installed the billet manifold and been tuning again. Looks like car is holding boost pretty good. Here is a multi gear pull I did for the tuner. Only 3rd to 4th. Let me know how it looks.
https://datazap.me/u/alanle/reflex-v...42-43-44-45-46 |
mgeller51.50 |
07-16-2022, 02:35 AM | #135 | |
Rep 1,181
Looks great 30 psi and 14 deg. is incredible.
08-22-2022, 11:37 PM | #136 |
Rep 684
Just installed the bar sensor. Looks like lpfp lowest reading is around low 70s psi. Tuner asked me to upgrade the lpfp but he hasn't mentioned it in the previous 2 logs. Car is running on e50, ds2, pi and DAW ultra flow. Btw I'm still tuning.
https://datazap.me/u/alanle/reflex-v...og=0&data=3-24 |
08-23-2022, 12:10 AM | #137 | |
Rep 1,515
08-23-2022, 12:48 AM | #141 |
Rep 1,515
08-23-2022, 03:15 AM | #143 | |
Rep 1,181
You need more ethanol to improve timing.
02-12-2023, 05:17 PM | #144 |
Rep 95
Hey man ! What do you think of this log - https://*********************/graphs...3-18-22.24364/
And this log - https://*********************/graphs...3-14-18.24363/ Replace * with spool street without space I am running MHD Stage 1 91/95 octane and running 95 octane with it (E10 from the pump). I have some corrections (max -3) on some logs and on some I don’t have any. Should I start adding some ethanol (it is very hard to find in my country) or corrections like these are not concerning ? I am also going stage 2 tomorrow (installing my DP) and I am wondering if I should be safe with the same fuel without ethanol. |
02-13-2023, 03:07 AM | #145 |
Rep 3,994
Neither link is a valid link. Even when replaced with ***********.
Just make it easy for everyone and use datazap as everyone else.
03-23-2023, 03:20 AM | #146 |
Rep 190
Hello,
on BM3 OTS tunes, we can find stage 1 E30 stage 2 E50 (HPFP needed like TU) We all know here E30 is the (absolute) limit for stock HPFP (at stage 1 power levels), while E50 is with TU Pump (at stage 2 power levels). We also know these E% are not so safe, since we can see in logs HPFP is fighting hard to keep up at lower RPM. For these reasons, I'm running TU HPFP on stage 1 E30 tune, with around E40 in the tank. My question : at stage 1 power level (ie boost) what is the maximum E% can TU HPFP can handle ? Since stage 2 should boost more than stage 1, I guess we should be able to go a little bit beyond E50 when running stage 1 boost levels. Maybe E50 on stage 1 E30 tune is safe due to lower boost ? thank you ! |
03-25-2023, 12:16 PM | #147 | |
Rep 2
Hi buddy would you be able to share the xdf file with me that you use. I speak English and have some German in the one I have. I also don’t see some of these table definitions you have displayed here. |
03-29-2023, 03:43 PM | #148 | |
Rep 190
any idea ? thank you ! |
