Originally Posted by Almaretto
LHM/TMS & FLE ECU Light modules are a bit more complicated, but there is still some logic.
I do not have all details of your CAFD, but I believe this is correct: - 04 hex = 04 decimal
- Then you go to LmmIdx04_Intensity = 64 hex = 100 (%) decimal
My F015's FLE's (CAFD_000024C3) are a little different, but hopefully this example further explains architecture: - DRL_Idx:
- 01 01 0A 01 01 01 01 01 01 0B
- 0A hex = 10 decimal
- LmmIdx10_Intensity: 64 = 100% DRL
- POLI1_Idx:
- 01 01 0C 01 01 01 01 01 01 0B
- 0C hex = 12 decimal
- LmmIdx12_Intensity: 29 = 41% Angel Eye with low beam
So, to change brightness (ie intensity), you have two options: - Change the werte in section 3004 (eg, POLI_IDx, POLI_IDx, POLI_IDx for low beam)
- It can get a little confusing because larger hex can reference smaller numbers (eg, 0A --> 10 --> 100% vs 0C → 12 → 41%). You cannot simply change 04 to 64 because there are only 26 (ie LmmIdx##, where ## = 1-26)
- Change the corresponding werte in section 3005 (eg, LmmIdx##_Intensity)
Hi all
Anyone know how to change settings to reduce DRL to 50% , (not with low beam, high beam), only DRL
F31 uk model, 2015 lci, adaptive led headlights
Have FLE modules.
Thanks
