11-08-2020, 02:23 PM | #134 |
Moto Lover
197
Rep 604
Drives: '19 BMW S1000XR
I will have some up soon, recently lowered the car and will get some good pictures.
I believe the 18x9 ET31 is. |
Pinkykillaz22.50 |
11-08-2020, 06:04 PM | #135 |
Rep 4,515
11-09-2020, 02:22 AM | #136 |
Rep 1,021
11-09-2020, 03:05 AM | #137 | |
Rep 4,515
EDIT, i stand corrected by the post from APEX below, thanks Last edited by alohasurftoad; 11-09-2020 at 11:39 PM.. |
11-09-2020, 05:26 PM | #138 | ||||
Rep 7,081
-Ian
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
alohasurftoad3319.50 |
11-12-2020, 01:47 PM | #140 | |
Rep 7,081
Here's what I could find: Matte Bronze
Stlblues106.50 |
11-12-2020, 08:03 PM | #141 |
Rep 1,021
thanks, its down to hyper black or silver. ive seen the silver in this thread. i have a while as its close to winter here in the northeast so no rush with all the salt and snow. what are the specs of the wheels in the last pic of the hyper black arc 8?
11-13-2020, 01:01 PM | #142 | |
Rep 7,081
Here are the fitment specs for the 2011 E90 335i above: APEX ARC-8 Wheels in Hyper Black Front: 18x9" ET30 with 235/40 Michelin PS4S tires Rear: 18x9.5" ET35 with 265/35 Michelin PS4S tires Suspension:
-Ian
11-15-2020, 05:57 PM | #143 |
M340i
478
Rep 1,116
Drives: BMW M340i
Expert@ApexWheels3782.50 |
11-23-2020, 10:19 AM | #145 |
Moto Lover
197
Rep 604
Pinkykillaz here you go
18x9 ET30 with 255/35-18 tires. Bilstein PSS10 Comfort coilovers on max low. DSC08550 by Richard Nguyen, on Flickr DSC08560 by Richard Nguyen, on Flickr DSC08574 by Richard Nguyen, on Flickr DSC08190 by Richard Nguyen, on Flickr |
11-23-2020, 10:40 AM | #146 | |
Rep 31
11-23-2020, 11:58 AM | #147 |
Rep 7,081
Yep! Our Black Friday sale will go live on Wednesday and run through the 30th of November. We will be discounting our wheels across the board!
-Tom
Nircom8.00 |
11-23-2020, 02:04 PM | #148 | |
Rep 68
11-26-2020, 02:12 PM | #150 |
Rep 155
Can anyone educate me why the fitment guide suggests et 42 for track and not also suggesting et 30/31 offset? I know both will work, I just wondered what benefits the et 42 may give?
12-02-2020, 04:22 PM | #151 | |
Rep 7,081
On the F3X chassis, the 18x9" ET42 requires a 5mm front spacer to fit on stock suspension but will provide you with a bit more fender-side clearance compared to the 18x9" ET30. This is beneficial when running more aggressive R-compound tires, as you will be less likely to rub compared to running the same tires/sizes on the 18x9" ET30. With that being said, the 18x9" ET30 is typically the superior choice for a square setup on the F3X, as it does not require a 5mm front spacer and is able to provide a direct fit in most cases when using street tires. We have seen customers run 245/40-18, 255/35-18, and 255/40-18 tire sizes on the 18x9" ET30 on stock or lowered F3X's without any rubbing. However, due to the lower offset, you will have a higher chance of rubbing on the fenders if you plan to use more track-focused tire compounds. If you have any additional questions, please do not hesitate to reach out! -Geirsen
bigdnno98289.00 |
12-12-2020, 05:51 PM | #153 |
Former WRX Geek
Rep 11
12-14-2020, 07:46 AM | #154 | |
Former WRX Geek
Rep 11
So I’ve read through pretty much every thread on this subject but haven’t quite found confirmation for my F30 XDrive on H&R sport springs: For the Arc 8’s 18x9 et 30, can I get away with a squared setup of 255/40 in Michelin PS4S? I’d like to keep the thicker sidewall due to road conditions around me. I’m not opposed to 255/35 and I know 245/40 is basically a direct fit with my setup but I’d like the wider wheel coverage if I can manage it without rubbing. Thanks for the help! P.S. I appreciate your previous response a few months back. I’ve since decided to stick with 18’s rather than 19’s due to road conditions and tire prices lol. Will be ordering in the next week or so. Finally! |
