03-08-2017, 03:38 PM | #133 |
Rep 541
03-08-2017, 03:49 PM | #134 |
Rep 2,152
In all honesty if you have 1 I wouldn't swap.
Tbh companies have perfected the remap dms, more-bhp to name 2. It's an ecu out job no matter what unfortunately. No way to do it via obd |
03-08-2017, 03:56 PM | #135 | |
Rep 541
http://www.bimmerforums.co.uk/forum/...rning-t290193/ |
vadimo307.00 |
03-09-2017, 01:14 AM | #136 | ||
Rep 2,152
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
03-09-2017, 04:13 AM | #137 |
Rep 1,465
For those interested, I'm taking my car on the rollers next Thursday. Had hoped to get it done this weekend, but they need a few hours to do it properly.
Going to do 3 runs: Stock, C7 & E7. I currently have mine set to E7 so would like to see what it's putting out, but also how the power and torque curves compare to map C. Will update this thread with printouts once complete! |
03-09-2017, 05:13 AM | #138 | |
Rep 365
I ran mine between C4-C6 and had fuel cut under heavy load situations, I never thought that changing to a more aggressive map would cure it, but sure as shit it did. The cars now running on E7 and is happy as a pig in the proverbial, with the added bonus of even more POweeeeeerrr Happy days |
JLR19691834.00 |
03-09-2017, 05:16 AM | #139 | |
Rep 7,000
KCH1984967.00 |
03-12-2017, 05:05 AM | #140 |
Rep 328
Hi guys I am looking to buy a CR2 box once my ACS Springs are fitted. I want the CR2 as it keeps it below 700NM (gearbox limit?)
Has anyone done 0-60mph and 0-100mph with these boxes |
03-12-2017, 09:36 AM | #141 | |
Rep 2,029
You are quite correct re the ZF 8HP70X box having a manufacturers limit of 700Nm. (8HP70 on the graph) I think with pretty much all boxes, the chances of them being anywhere near 700Nm is low and the amount of times you'd be exploring that top end of the spectrum would be minimal (not to mention a bit of fat on the bones ZF will have on the 8HP too; Input Tq capacity 760Nm). In all the research I did (with huge thanks to Smee), I never once came across anyone who had broken their gearbox after fitting a tuning box. As for 0-60 times. About two weeks after I fitted my BS Pro+ Boost box, I did a launch and (not terribly scientifically) saw about 4.3. Prior to fitting the box using the same road in the same conditions, I'd seen about 4.6 (pretty much bang on BMWs figure). Feels a darn sight more rapid off the line. Has anyone been able to code the new MPPK style recalibrated Sports gauges to read above the standard 640Nm? Last edited by Darth Helmut; 03-12-2017 at 09:49 AM.. |
Smee497.00 |
03-12-2017, 04:26 PM | #143 | |
Rep 2,152
with a box 35 to 45 is what I expect. when I get on the rolling road in may I'll know for sure hoping for 360 700nm but I am on the highest setting so if bluespark are correct 370 bhp 721 nm. we will see
03-17-2017, 06:05 AM | #145 | |
Rep 7,000
03-17-2017, 06:28 AM | #146 |
Rep 1,465
Holding off posting a full review until I get the graphs emailed across, but quick summary as follows:
Stock the car ran 258.6bhp / 409lbft - so pretty much bang on what BMW quotes. In the default mode (C6) the car ran 286.1bhp / 486lbft and the dyno plot pretty much mirrored the stock curve, which is in line with guidance from Bluespark. In the max setting (E9) the car actually produced less power (282bhp) but more torque (500lbft). This came in much earlier however, but then tailed off compared to map C. Again pretty much what Bluespark have advised. Easier to explain when I have all the graphs which can be seen. I also ran C9 and D7 so full report to follow. Pleased with the results, albeit down on the ultimate power figures Bluespark quote but torque surprisingly higher. |
03-17-2017, 06:31 AM | #147 | |
Rep 7,000
So +10.8% BHP and +19% Torque which I would be pretty happy with as torque makes a lot more impact for me. Hitting the 300BHP is my target but that's vanity |
03-17-2017, 06:38 AM | #148 |
Rep 2,152
same as you. was chatting to Kev yesterday when he was running the car and was surprised by the power. (might be worth a question to Edd??) but torque (which is more what i care about) is actually up which does make me happy. spend more time down that end of the rev range than the top end anyway.
Stock = 554nm bluespark claim = 650nm result c6 = 659nm result e9 = 682nm
03-17-2017, 06:44 AM | #149 | |
Rep 1,465
C9 actually made 291bhp for me (forget what the torque was just now) but when it was on the dyno the technician could fell the car holding back, which as reflected in a dip in the power curve around 3500rpm - I assume this is the fuel pump limitation that's been discussed previously. Either way the car did not like this setting! |
03-17-2017, 06:51 AM | #153 |
Rep 2,152
Tbh once you do your review I'll steal it and add it to the main post and any other useful information.
Interesting the graph I listed above for tdi tuning box made good power but torque well down |
