10-19-2023, 10:24 AM | #133 | |
2015
Rep 2,195
Got there in the end...
10-20-2023, 03:02 AM | #134 | |
Rep 1,124
I noticed on my non-BMW battery, the hold down clamp's 'teeth' didn't align with the notches on the battery base for some reason. I thought it was supposed a standard across all batteries, but it's holding just fine though. I've never seen that before on any car until now |
10-20-2023, 03:14 AM | #135 | |
2015
Rep 2,195
But getting my fat hands into get that clamp back in situ was a joke... Thank goodness for my extendable magnetic wand (good for finding 10mm bits rolling round on the undertrays too)
10-21-2023, 06:37 AM | #136 |
2015
Rep 2,195
That's the summer 405Ms and tyres scrubbed clean, dried, bagged up & stored away in the gardening shed until sometime Spring 2024
F30_320D_UK215.00 |
11-01-2023, 03:13 PM | #137 |
2015
Rep 2,195
TurboWeasel Take note
All new suspension parts ordered (shocks/springs etc) Gone for Bilstein B4Ss all round; new Sachs top mounts, Eibach pro kit springs etc via Autodoc, 41% off - can't complain at that! £700 all in, delivered :thumbup: Will get the dust boots/rubber perches and gaskets etc from Cotswolds BMW & then it can all be built up on the bench and each corner swapped out smoothly etc That's about £150 all in IIRC Going to give the arms/links/bushes another full once over on Tuesday whilst it's on my pals ramps for 30mins (so I can replace the front drop links that have failed) and see which other arms need replacing as I forgot to take a proper note the other week and have forgotten
11-03-2023, 08:44 AM | #138 | |
Rep 1,124
Looking forward to the results! |
11-07-2023, 04:31 AM | #139 |
2015
Rep 2,195
Back on my pals ramps this morning
Going to replace all the front arms, drop links, track rod ends & tie rods etc... All original BMW from 2015! Rear arms are a mix of original BMW 2015 and some dated 2020, so will replace the 2015 ones and the eccentric bolts/washers/nuts too as they're rusty as hell Just ordered them via Cotswolds BMW And this happened on the way back home
11-07-2023, 08:17 AM | #141 | |
2015
Rep 2,195
11-08-2023, 05:21 AM | #142 |
2015
Rep 2,195
BMW boot mat landed & fitted:
It's a chunky mat TBH; the other one I had is good, but very soft. The BMW one is a lot more protective
YODI140.50 |
11-09-2023, 10:38 AM | #144 |
2015
Rep 2,195
Front & rear suspension arms, links and inner tie rods/track rod ends & their bellows ordered today via Autodoc with their 31% offer running
Quite a few bits, but it all needs doing really Gone with a mix of Moog, Lemforder & TRW - some TRW & Lemforder parts were out of stock; but having used Moog a LOT over the years on my E39s and E65/F01 7'ers, I've never had any issues, so happy to stick with them
Alscoob2197.50 |
11-10-2023, 08:05 AM | #145 |
2015
Rep 2,195
OEM BMW CF/alcantara handbrake fitted
Looks well and feels good in the hand From: To: First of many parts ordered arrived via Cotswolds BMW also; this is all the necessary rubber bits, gaskets and some bolts for the suspension overhaul. The rest of it is arriving via Autodoc and snail-mail Some bulbs in there too for a change this weekend and a spare bulb kit etc
11-10-2023, 09:05 AM | #146 |
Rep 2,055
Two sets of D1S bulbs? I thought they all just used a single in each lamp no matter which version you had? Either way, the clips on them are an utter bastard to undo with cold hands as I discovered the other month when I fitted the upgraded Philips XtremeVision ones to mine.
11-10-2023, 09:39 AM | #147 | |
2015
Rep 2,195
Been running Lunex xenon bulbs for years now; but in E39s and their older designed xenon heqadlights aren't as bright/powerful as the F31s, so wanted to see what the 6000s would look like (they're white, not blue thankfully) or stick with OEM 4300k etc I'll be jacking the front end of the car up, wheels off and see how I get on; might remove the wheel arch liners if they're a bugger. My hands aren't small and my patience is thin
11-10-2023, 10:58 AM | #148 |
Rep 2,055
Ah, fair enough. The colour of the Philips is actually pretty close to OEM, maybe a touch whiter, but they're definitely brighter with a fair bit more throw than the stock Philips bulbs. Not sure what that equates toon the K scale though.
They're just awkward but pushing down and back before going sideways seems to be the easiest way. Just make sure you're pushing them in the right direction...not that I did anything so daft as assuming they both went the same way, rather than each side being different! You should be fine taking the wheel off and removing the access cover, it's the headlight housing itself that really limits how well you can reach the clips and bulbs. |
danb19792015.00 |
11-10-2023, 12:26 PM | #149 | |
2015
Rep 2,195
The E39s were a doddle and if you needed to remove them, 4 10mm bolts and out they came!
11-11-2023, 05:24 AM | #150 | |
2015
Rep 2,195
Did use my 45 degree needle nose pliers to get the bulb clips back on; no way I could get my fingers in there! Osram Xenarc D1S bulbs removed; passenger side had gone yellowish, so time to change them anyways... Front indicator bulbs swapped out for the Osram Diadem chrome ones too; looks much better
11-11-2023, 07:48 AM | #151 |
2015
Rep 2,195
And freshly washed too with a good coat of AGs' Rapid Ceramic spray to see how that fairs over the wetter/dirtier months:
https://www.amazon.co.uk/Autoglym-RC...0-a8eddba1bf6a Probably the last full wash I'll give it now until early next year when the weather improves; will stick with contactless washes for now
Leeg1633141.00 |
11-11-2023, 09:30 AM | #153 |
2015
Rep 2,195
They do look much better than the OEM orange ones:
https://www.amazon.co.uk/DIADEM-halo...s%2C119&sr=8-1
11-11-2023, 09:36 AM | #154 | |
Rep 180
danb19792015.00 |
