Studio RSR
      07-15-2021, 09:33 PM   #15907
RunWhileYouCan
Drives: 2012 BMW 328i RWD
Originally Posted by shawnsheridan View Post
PM's sent.
Could you also send me the details? Thank you
      07-15-2021, 09:53 PM   #15908
shawnsheridan
shawnsheridan's Avatar
PM sent.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant
2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE
      07-16-2021, 12:49 AM   #15909
vaniilla9
Drives: BMW M240i
Hi Shawn, I am also am new and looking for the software to code a 2016 328i. I dont have enough post replies to use PM so if its not too much of a hassle please email me the link/files? vaniilla9@icloud.com
Thanks either way!
      07-16-2021, 09:09 AM   #15910
shawnsheridan
Thanks either way!
Sorry, I do not send emails. Your Receive PM function is disabled. PM me when working.
      07-16-2021, 10:55 AM   #15911
vaniilla9
Drives: BMW M240i
Okay, thats okay. I’ll just post a few times on another page to unlock my PM’s! U’ll hear back from me soon
      07-16-2021, 10:57 AM   #15912
shawnsheridan
      07-16-2021, 12:40 PM   #15913
vaniilla9
Drives: BMW M240i
I think my PM’s are up and running brother When you get a chance, try Pming
      07-16-2021, 12:46 PM   #15914
shawnsheridan
PM sent.
      07-18-2021, 12:29 PM   #15915
ErwinF30
ErwinF30's Avatar
Netherlands
Drives: BMW 3-Serie F30
Thanks, really helpfull!
BMW F30 - Full M Performance Pack - Melbourne Red
      07-23-2021, 07:26 PM   #15916
binjammin10
Drives: 2014 BMW 320i xDrive
Hi Shawn,
Could you send me pzdata file ? Im trying to connect to esys over Ethernet and no target parameters loaded into the connection window.
On another note, I heard they can be generated manually by creating folders in the pzdata file, is that true? If so, do you have the schema available to share?
      07-23-2021, 07:31 PM   #15917
shawnsheridan
Originally Posted by binjammin10 View Post
Hi Shawn,
The psdzdata chassis folders each have an empty "dist" folder. Make sure that there is an empty "dist" folder in each of the psdzdata chassis folders, and if missing, create as needed, e.g.:
  • C:\Data\psdzdata\mainseries\F001\F001_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\F010\F010_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\F020\F020_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\F025\F025_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\F056\F056_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\I001\I001_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\K001\K001_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\KE01\KE01_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\KS01\KS01_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\M013\M013_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\RR21\RR21_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\S15A\S15A_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\S15C\S15C_xx_xx_xxx\od x\dist
  • C:\Data\psdzdata\mainseries\S18A\S118A_xx_xx_xxx\o dx\dist
      07-23-2021, 11:09 PM   #15918
binjammin10
esys initialization error [G270]
Thank you for such quick response, super helpful. Im still having trouble with the psdz file tho;
"The content of the current psdzdata folder "C:\Data" is invalid or empty.
Please import a valid PDX-Container. [G270]
Set PSdZ-Root using "C:\Data" failed! [C073]
Initialization of PSdZ failed due to following reason: C:\Data\psdzdata\mapping\brref.xml file is missing in psdzdata directory.. All previously applied changes during the initialization process will be undone. [2045]"
Have you seen this?
      07-24-2021, 09:19 AM   #15919
shawnsheridan
Have you seen this?
Do you have folder c:\data\psdzdata and if so, what is the size of it?
      07-24-2021, 11:27 AM   #15920
binjammin10
the psdzdata folder is 0 bytes
At this point i'm probably looking for a fresh install of E-sys and launcher with token but I'm having trouble getting my PM privileges activated.
      07-24-2021, 01:01 PM   #15921
shawnsheridan
PM sent.
      07-24-2021, 05:57 PM   #15922
f30baik
Indonesia
Drives: F30 B48
Can't fold mirror using mirror fold-unfold button
Hello,
I have been coded my car with this value:
1. Fold mirrors when locking vehicle with comfort closing > active
2. Unfold mirrors when unlocking vehicle with comfort closing > not-active
Expert Mode:
1. the speed at which the side mirrors will auto-unfold > Hex 00
2. Max speed the mirrors will fold > Hex 00
so, I just want my mirror auto unfold when I drive a car, because when I parked in a tight space I prefer the mirror not auto unfold (in case I just forgot to take somethings in my car)
but the problem is when I in the narrow road and there is a car in front of me, I cant fold my mirror using the mirror fold button on the driver side.
is there any solution?. I want my auto unfold mirror when I drive a car and I want too my mirror can be folded using the mirror button on driver side.
I coded this via bimmercode.
Thanks in advance, sorry if my English are bad.
      07-26-2021, 11:45 AM   #15923
ddkyosho
Drives: bmw f10
Hey guys,
Is there an option to code the tilt angle of the mirrors when its in reverse?
      07-26-2021, 11:52 AM   #15924
shawnsheridan
Originally Posted by ddkyosho View Post
Hey guys,
Vertical travel (tilt) of the exterior passenger mirror (Automatic Curb Monitor) when the reverse gear is engaged:
FRM => ASP_BORDSTEINAUTOMATIK_DELTA = Werte Value As desired.
      07-30-2021, 12:27 AM   #15925
Jakki2
BMW's for life tai jotain....
Jakki2's Avatar
Finland
Drives: F30 330e 2016
Hi,
did manage to follow instructions here and code out the TPMS and enabled RPA.
Good, but in the process I manage to hide/disappear the Electric info on display (KOMBI?)
car works as before but electric driving information cannot be seen, not in any mode.
Also, i did manage to code the Sport+ there already earlier by Bimmercode - which is also gone now.
What to do ?
I have Latest PSDZData with 2.8.2 launcher on Esys 3.27.1
Thanks already!
      07-30-2021, 03:33 PM   #15926
barni320
Drives: BMW 428i F32
Is it possible to code the exhaust flap always open in sport mode and close all the time in comfort?
      07-31-2021, 03:05 PM   #15927
mrdude1
Drives: f30
Originally Posted by svache View Post
Ok, for those interested, I updated the first post with a DIY.. I hope everything works out for everyone.. if not, please ask in this thread instead of PM so others who have the same problem might get helped as well)
thanks
      08-01-2021, 07:40 AM   #15928
favourhisashi
Drives: F30 328i sport
Hello Shawn,
Could you please sent the latest psdzdata to me,thanks.
