06-17-2023, 10:12 PM | #1674 |
Rep 2
Changing split screen image
Hey Guys,
Has anyone managed to successfully change the default split screen image when using the cars original functions? I'm stuck with this speedo and it's killing me! Running A11 s662 Any help would be greatly appreciated Cheers |
06-18-2023, 10:52 AM | #1675 |
Rep 13
Helo everyone!
Does any one knows this problem: Have installed KSW-TOOLKIT apk from https://github.com/Snaggly/KSW-ToolK...ses/tag/v1.2.1. However after instalation there is no icon of the app. Kind regards, Vlad |
06-18-2023, 12:11 PM | #1676 |
Rep 2,450
Drives: E63 645Ci
You cannot change that image. It's not part of the Android system but the MCU. MCU files can be technically modified but for practical reasons it's impossible.
06-18-2023, 12:12 PM | #1677 | |
Rep 2,450
Drives: E63 645Ci
06-19-2023, 10:49 AM | #1678 | |
Rep 13
Appreciate! As I understand I had downloaded the client (please find attachment) should I download Source code folders? Kind regards, Vlad |
06-19-2023, 10:52 AM | #1679 | |
Rep 13
or there is another guide how to root A11 SD 662& Kind regards, Vlad |
06-19-2023, 10:58 AM | #1680 |
Rep 2,450
Drives: E63 645Ci
Source code is exactly what is says it is: the source code (how the app is written). If you want to inspect it, add something or modify it then by all means download it and have a go. Other than that you don't need it.
06-19-2023, 12:23 PM | #1681 | |
Rep 13
Unfortunately, only maneged to assign Idrive knob (turn left\right) for now. I have attached video file to show how it works (have changed the format to PDF in order to upload it, in order to see the video format should be changed back to .mp4 back). Mabe there is a way how to make Android to see volume up and down buttons press on steerong wheel? May be there is correct MCU? I have HU_Entry, and using NBT CAN protocol how is on picture: Kind Regards, Vlad |
06-19-2023, 12:51 PM | #1682 | |
Rep 2,450
Drives: E63 645Ci
1. This was never intended and the MCU doesn't listen for these specific CAN packets. 2. It doesn't make any sense for stock configuration. In this case if you had these buttons assigned to Android volume, they would control Android volume and(!) OEM volume at the same time. That would result in a complete chaos and lack of real control over any audio signal. |
06-19-2023, 01:05 PM | #1683 | |
Rep 13
Just wandered, because there is an option in Ksw-Toolkit to assign volume buttons on steering wheel. buy the way, may be you know how to root A11 SD662? Kind regards, Vlad |
06-19-2023, 02:44 PM | #1684 |
Rep 2,450
Drives: E63 645Ci
06-20-2023, 01:48 AM | #1685 |
Rep 4
Hello bmw friends,
I have an X4 from 2016 with Business navi (Entrynav) and would like to retrofit Android system. At all dealers there are only 2 variants to choose from (CIC 4pin plug or nbt 6pin-plug). Can you tell me which one is the right one for my car? On my navi version it‘s: Road Map EUROPE Route 2016-1 RL_EntryNav_Nav_|16293A Thank you |
06-20-2023, 02:47 AM | #1686 | |
Rep 9
Drives: BMW E61 525i
check this. |
06-20-2023, 11:48 AM | #1687 | |
Rep 13
Unfortunately this method doesn't work for me ( had tried, but in the end occures some error: Kind regards, Vlad |
06-20-2023, 03:34 PM | #1688 |
Rep 2,450
Drives: E63 645Ci
06-21-2023, 09:04 AM | #1689 |
Rep 224
Drives: MINI Cooper, 2020 X1
Android 11 or 12 cannot be rooted with SuperSU. Topjohnwu is no longer in development, further develops Magisk. So it can be rooted using Magisk. First, you need to extract the boot.img from the corresponding payload.bin, edit it in Android with Magisk.apk , and then flash it via fastboot. It works without a problem.
06-21-2023, 10:39 AM | #1690 |
Rep 13
06-21-2023, 10:52 AM | #1691 | |
Rep 13
Can you please share link with detaled guide? Don't know for now how to extrackt boot.img and where is payload.bin and, accordingly, the next steps you mentioned. Just a bit confusedwhat you are saying, because here: https://f30.bimmerpost.com/forums/sh....php?t=1699764 is written in red not to use Magisk to root Kind regards, Vlad |
06-21-2023, 02:03 PM | #1692 |
Rep 224
And that's why I won't give any DIY. You have to know what you are doing and why you are doing it. It's easy to brick a rooted HU, and it doesn't matter much whether it's Magisk or SuperSU rooted. (for A11 and A12 and A13, etc. you have more or less no other option than Magisk). First of all, you must have access to the Volume - button, otherwise don't even try to root. A nice photo of such a button is on Discord. :-) . If you install it and run it, you can only try to root.
06-22-2023, 12:40 PM | #1693 | |
Rep 13
Thats true, don't really understand what I am trying to do, but at least (as I think) i know why i need this :-) I only need to change TTL (time to live) parameter from 64 to 65 on my HU, in order to be able to share internet from mobile phone without extra charges from my operator (I am fed up from him... constantly increases monthly charges). So this is more like fighting against the system :-) Yes, i understand that I can simply buy another sim card and install it into the android, etc... But having number of phones to pay for (wife, daughter, parents) together with many subscriptions and ofcoure mortgage, etc... together comes something heavy for me. Besides the change of TTL don't realy need root rights. Moreover, haven't updated android since i bought it in jan 2021 (still on v 1.5.2) because everything works fine for me with help of RedErik (apart new problem, caused by mobile operator). Before that just did some coding of F30 (easy beacause lots of info online) and mostly hardware things like amplifires, speakers, PCB in the stearing wheel, star ceiling and instalation of HU by my self. At least wanted to give a try before giving up. P.S. did you ment this photo from Discord (in attachment)? If yes, I think It is possible to do that (at least know some electricians that may help) The question is, wheter i can do that button after the try, I mean if i brick HU?? And if try will be successfull, after i change the TTL is it possible to remove root right back and delete Magist not to be at risk to brick HU, whether the TTL will remain the same as I want (65)? Kind regards, Vlad |
06-22-2023, 03:29 PM | #1694 |
Rep 224
Yes, that's the picture. The button connects the Volume- on the SOC to ground and if you hold it and connect the HU to power, you will get into recovery so you can revive your bricked HU
