10-29-2020, 12:25 AM | #155 |
Rep 1,288
Deleted due to improper info...
10-29-2020, 04:55 AM | #156 |
Rep 415
Hi guys thought I'd hop over and answer a few questions that have been asked 🙂. As ZM2 says that's an initial log running the racegas+ map on my stock turbo DCT M2.
Quick mod list to clear a few questions up: Dorch stg1 HPFP, decat, Pure turbo inlet v2, ftp charge/boost pipes, vrsf 5" HD, panel filter, BM3, 3.5 bar tmap. Still on stock plugs and DV. Fuel used for the racegas+ map is pump 99ron (93/94 aki) with a bottle of NF octane booster. FYI I use to run the regular racegas map on my pump fuel And it ran clean logs all year round. On the e30+ map my car ran 100-200kph in 7.91s. Looking at all the data from the logs and draggy times the car has a 7.7/7.8s time in it on this map, I'll get back to this after I finish testing the racegas+ map. No 100-200kph times for the racegas+ map yet but looking at the logs it should go a little quicker than my e30+ times. Once weather allows I'll get some numbers. For VD my car is on the oem 19" wheels with 255/35F and 275/35R. I'll also grab a 4th gear log when I can 👍🏻. |
10-29-2020, 09:49 AM | #158 |
Rep 1,288
Oh....your DCT... that graph was for manual... gear ratio is major change in Hp... Need the 4th gear pull... also is the DCT the same as the M3? (Update: confirmed it is)
10-29-2020, 10:00 AM | #159 |
Rep 142
CTS Turbo catted downpipe ordered yesterday!!
This 2+ E30 map is a real monster. Spun from middle of 1st gear through 3rd gear on launch. I can just feather the throttle and get it to spin and these are Firestone Firehawk Indy 500’s, pretty sticky.. This is all in sport+ mode. It has electric motor instant torque. Like @zm2 said, this transforms the car. Last edited by ctt300; 10-29-2020 at 10:15 AM.. |
ZM22839.50 |
10-29-2020, 10:27 AM | #160 |
Rep 1,288
Can someone verify the weight on a 2018 M2... I've got three weights I found for the same car... 3450, 3505, 3638.....
10-29-2020, 06:00 PM | #162 |
Rep 4,210
Road and Track, and Car and Driver usually have a downloadable PDF with their tester car’s information- inclusion curb weight as tested, and launch RPM for acceleration, etc.
10-29-2020, 07:44 PM | #164 |
Rep 1,288
Thank you so much... Car and driver on some reviews (M2 actually) even do corner weights... so this is the official documents I will use since they obviously weigh them on the spot... M2 = 3509lbs.. We'll assume gas tank on empty I guess...
10-29-2020, 08:10 PM | #165 |
Rep 1,288
Okay... adjusted weights according to Car & Driver... 3rd gear DCT is basically same as 4th gear Z8f.... I gave all benefits as possible to the M2... Red is 2018 M2 Bm3 Race Tune... Blue is 2015 335i Xdrive MHD E20 (mine) ...
Disclaimer: Attached graph was done on Virtual Dyno and this information is for Entertainment purposes only... |
10-29-2020, 08:37 PM | #166 | |
Rep 3,715
There’s no stock HPFP N55 in the world running E20 that’s faster than these Stg 2+ maps. Show us a sub 7.9s draggy or put it on a Dynojet, skip this VD BS. |
10-29-2020, 08:56 PM | #167 | |
Rep 1,288
https://f30.bimmerpost.com/forums/sh...4&postcount=45 |
10-29-2020, 08:59 PM | #168 | |
Rep 3,715
10-29-2020, 09:44 PM | #169 | |
Rep 932
10-29-2020, 10:30 PM | #170 | |
Rep 1,288
P.s. I found a elevation site and checked the mile I log on... I'm within 5ft up & down over a mile... good enough.. Last edited by FastF30; 10-29-2020 at 11:08 PM.. |
10-29-2020, 11:26 PM | #171 | ||
Rep 7,629
10-29-2020, 11:38 PM | #172 |
Rep 1,288
Yea I know... just entertaining myself I guess... no reason not to believe for my run... I'm at sea-level/ lucky weather... Florida is sea-level...lol... my run is flat enough... I'm just saying good enough for a ballpark... want to see a upgraded fuel pump run in Florida... Black Friday is approaching... might go either Dorch II or Spool 180... I read a few things here and there...
10-30-2020, 12:04 AM | #173 | |
Rep 4,210
With that said, the BM3 Stage 2+ Absolutely makes more peak, and high RPM HP, so virtual dyno is showing us what we already know to be true. |
10-30-2020, 12:07 AM | #174 |
Rep 4,210
??? Are we sure about this.
10-30-2020, 12:08 AM | #175 |
Rep 4,210
FastF30521.00 Pussiwillow522.00 |
10-30-2020, 04:35 AM | #176 | |
Rep 2,379
(A Dane in China) |
