12-14-2020, 10:08 AM | #155 | ||
Rep 153
12-14-2020, 12:22 PM | #156 |
Rep 272
just put mine on
F80 ED springs w/ B8s & Millway camber plates 18x9.5 +35 265/35/18 square. 10mm spacers up front I didn't weight the full setup, but my previous style 126s were near 35lbs without a tire, compared to these at 18.85... the difference is noticeable to say the least LOL My daughter has been dying to pull the plastic off the centercaps so those will be on after school Last edited by blumagic; 12-14-2020 at 12:47 PM.. |
12-14-2020, 02:12 PM | #157 | ||
Rep 7,080
-Ian
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by Expert@ApexWheels; 12-14-2020 at 02:21 PM.. |
Aldor2792.50 |
12-14-2020, 02:55 PM | #158 | |
Rep 272
-2.5F ~-1.9R camber running Federal ST-1. I just went out to do a road test, nothing rubs. Low speed full lock, hairpin turns & off camber turns at speed, freeway run.... everything I could think of with a passenger and didn't hear it rub once. I should have better photos when I have a chance to shoot with my SLR edit: better non-cell photos Last edited by blumagic; 12-14-2020 at 04:28 PM.. |
12-14-2020, 04:27 PM | #159 | |
Former WRX Geek
Rep 11
Aldor2792.50 |
12-14-2020, 04:34 PM | #160 | |
Former WRX Geek
Rep 11
12-16-2020, 03:15 PM | #161 |
Rep 32
Everyone wants to know about fitting 18 x 9 ET30 wheels with 255/40/18 tires on their F30.
I just received my new summer wheels which I ordered from Expert@ApexRaceParts on their Black Friday sale. Tires are Conti DWS O6 Vehicle is 2015 F31 328 wagon Suspension is KW street comfort. Modest drop. Perfect fitment, perfect flush, zero rub lock to lock. Here are filthy pictures of 1 front wheel I put on to test the fit. You will all have to wait until Spring to see cleaner pics. |
Expert@ApexWheels3782.50 isenc2151.00 |
01-05-2021, 08:41 AM | #164 | |
Rep 1
01-12-2021, 02:15 PM | #165 |
Rep 7,080
Back in 2019 we did a photoshoot of our customer Frederick's F30 328i with a set of 17" Fully Forged APEX EC-7Rs in Bushed Clear Finish.
APEX Wheel Fitment Specs:
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey Last edited by Expert@ApexWheels; 02-01-2021 at 05:49 PM.. |
Desertnate391.00 |
01-13-2021, 08:13 AM | #166 |
Rep 848
Drives: BMW 435i
I really like the look of silver wheels with a black car. Great looking car and great looking wheels.
01-13-2021, 05:26 PM | #167 |
Rep 469
2017 340iX
Arc-8 Powder Coated Gloss Black
Frt 18x8.5 et37 with 12mm spacers Rr 18x9.5 et35 Tires: Michelin Pilot Sport A/S 3+ Frt 225/45-18 Rr 255/40-18 Suspension Koni Active (Red Shocks) Eibach Pro Kit Springs Last edited by Runner340; 01-14-2021 at 08:54 AM.. |
Expert@ApexWheels3782.50 |
01-14-2021, 07:01 PM | #168 |
Rep 2
Hey guys, I just purchased my first BMW (manual '17 330i) last week. This will be the first time I've ever purchased aftermarket wheels, so I just wanted to double check and make sure I'm good to go before I make the purchase.
I want to purchase 2 18x9" ET30 EC-7R's for the front and 2 18x9.5" ET28 EC-7R's for the back, seeing as it's a RWD. Tires will be the Pilot Sport 4S' (245/40ZR18). I do plan on getting coilovers, but that won't be until next year after I move from my current spot. Am I missing anything or should I be good to go? |
01-14-2021, 09:36 PM | #169 | |
Rep 4,507
max.330i4.50 Expert@ApexWheels3782.50 |
01-15-2021, 03:35 AM | #170 | |
Rep 413
If same size tire, why not same wheel width front and rear so that you can rotate tires? Max |
01-15-2021, 03:05 PM | #171 | |
Rep 7,080
If you are going with 9.5 inch wheels in the rear, I would also recommend going with a wider rear tire. If the plan is to run the 245/40-18s all the way around, I would recommend running 18x9 ET30 wheels both front and rear instead. These are more than sufficient in terms of width to support those tires and will be a direct fit. The square wheels and tires will also allow you to rotate between the front and rear axles as the tires wear to even out any difference in the wear rate. -Tom
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// ML-10 Survey |
max.330i4.50 alohasurftoad3309.00 |
01-15-2021, 04:08 PM | #172 | |
Rep 2
alohasurftoad3309.00 Expert@ApexWheels3782.50 |
01-24-2021, 08:21 PM | #173 |
Rep 18
01-31-2021, 06:14 AM | #174 | |
Rep 1,021
02-01-2021, 04:51 PM | #175 | |
Moto Lover
197
Rep 604
Drives: '19 BMW S1000XR
02-01-2021, 05:52 PM | #176 |
Rep 7,080
Here are some photos from the shoot posted a couple weeks back with the Forged ARC-8R in Brushed Clear finish. Both the ARC-8R and EC-7R look amazing in Brushed Clear!
