09-20-2021, 09:52 AM | #155 |
Rep 41,205
The bottom (newer) one.
11-07-2021, 11:59 AM | #156 |
Rep 53
shawnsheridan You can tell me why I have other lines of code in E-SYS and Bimmercode (free). It looks like:
I am doing SVT reading and for example FEM_BODY editing and in E-SYS it is: FEM_BODY 3063 MAPPING_NEBELSCHW_L_PART_OF_WL Soft_On (Turns on Left Fog Lamp with Welcome Lights) and the lights obviously don't work. And when I check Bimmer in expert mode, the same line is "nicht_active"? This is the case with many codes, I code FDL -> the coding is green successfully. The function does not work. Next ->I'm reading a Bimmercode in a moment and the function is not actually active. I don't know if it's worth buying the full version of Bimmercode for encoding? What if something is wrong with the car and the Bimmer doesn't work properly either? Honestly, I'd rather code over the cable. But VO 520 -> 5A1 coding worked... Last edited by deusexe; 11-07-2021 at 12:04 PM.. |
11-07-2021, 12:01 PM | #157 | |
Rep 41,205
You shoudl Edit FDL in E-Sys, change to aktiv, and use Code FDL, not Code.
11-07-2021, 12:34 PM | #159 |
Rep 41,205
If you did Code FDL, then setting of aktiv would be saved. If setting is saved, and FDL Code doe snto produce the desired result, then FDL Code does not work.
11-07-2021, 01:05 PM | #160 |
Rep 53
How do I fix it then? Because these are the basic codes that must work. I don't think BMW would turn off the welcome lights after updating the car. Additionally, in the code 3062> mapping_blinken_z_l_part_of_wl> E-SYS sees hard_on, which I have never even set up before. But the turn signals in the mirrors do not work as welcome lights either. It is as if the e-sys is misreading the existing coding.
11-07-2021, 01:08 PM | #161 | |
Rep 41,205
11-09-2021, 11:45 AM | #163 |
Rep 41,205
astr0nate8.00 |
11-10-2021, 06:17 AM | #165 |
Rep 41,205
Your Receive PM function is disabled. PM me when working.
11-13-2021, 10:32 AM | #168 |
Rep 41,205
PM sent.
11-13-2021, 10:33 AM | #169 |
Rep 41,205
11-24-2021, 04:19 PM | #171 |
Rep 41,205
PM sent.
11-26-2021, 08:36 AM | #172 |
Rep 365
Same request here please Shawn, I need to update my E-sys from 3.27.1 which doesn't have the coding files for my 2018 440.
Can I just say, many thanks for your on-going support with this. |
11-26-2021, 09:10 AM | #173 |
Rep 41,205
PM sent.
11-29-2021, 05:29 AM | #174 |
Rep 549
Hey can I get the latest version to download too please.
Need to reset MAF adaptations as it is stopping my regens. TIA
F36 435D XD | Carbon Black | M Sport F36 BUILD THREAD | E93 BUILD THREAD | E92 BUILD THREAD Instagram - Gazzzillionaire |
11-29-2021, 09:44 AM | #175 |
Rep 41,205
PM sent.
11-29-2021, 09:52 AM | #176 |
Rep 549
