02-05-2018, 01:18 PM | #155 |
Rep 42,998
LDW (Lane Departure Warning) has nothing to do with the Side Mirror Triangles. Those are for Lane Change Warning (Active Blind Spot Detection).
02-05-2018, 01:36 PM | #156 |
Rep 67
02-12-2018, 05:40 AM | #158 |
Senior Functionality Rockstar
Rep 13
From my understand of this thread, you don't have the necessary KAFAS2 camera with that combination. But you do have the correct steering wheel and SZL. So you would need to retrofit the camera as well as the LDW on/off switch if you want to be able to toggle.
02-12-2018, 05:55 AM | #159 | |
Rep 13
Added 5AC to FA and coded FEM_Body, HU_NBT and KAFAS2 HBA works like a charm As for LDW, macs is correct, the vibration module needs to be installed in the steering wheel to get the lane departure feedback. Without it seems kinda pointless. Working on sourcing this without replacing entire wheel.
10-23-2018, 10:36 AM | #160 | |
Rep 34
It looks like the module sits at the bottom behind the "Y" trim.. Interested to add LDW to my F10 (already has HBA & SLI). |
11-02-2018, 05:25 AM | #161 |
Rep 591
I am not sure 100% but i think you need following for
LDW F30 32337849416 Vibrator 32307848337 Verbindungsleitung Lenkrad 61317849393 Steuergerät Lenkradelektronik I am looking for adding -Kafas BE Front Collision Warning -Kafas BF Pedestrian Detection -Speed-Limit Info the part what i found 61319268479 51459239299 61119322256 51169275008 51317258069 And of course i need 3 FSC BE,BF,8TH Last edited by Siki78; 11-02-2018 at 05:31 AM.. |
02-22-2019, 12:38 PM | #162 |
Rep 99
I'd like to enable lane departure, i don't have the switch but from what i read it seems you can default it to "always on".
I have the following options on my vehicle S5ACA S5AGA S5DLA S8THA S5DPA Which modules do i need to code to enable this and what values? Last edited by buggydrvr; 02-22-2019 at 04:18 PM.. |
07-14-2020, 11:15 AM | #163 | |
Rep 1
Hey Ive been trying to get it work vo coded 5AD, I have acc with stop and go HUD and 8th sign detection. So it should work I guess. But when I code 5AD Its enabled but only for like 10 seconds. Then it goes off with a note activate ldw again when suitable with driving situation when I click on help it says when it vibrates too often the motor overheats thats why it disable it. I have no motor tho. When I disable the vibrating in Kafas2 actuator it gives me camera error. All camera based features disabled. When I remove vibrating in Kafas2 and szl its the same. I just cant get It to work without vibratory motor. Do you have any idea what I can try? |
07-14-2020, 03:20 PM | #164 | |
Rep 42,998
01-02-2021, 07:18 AM | #165 |
Rep 51
Drives: BMW 530 xdrive
ldw
Hello,
to start best wishes 2021 I coded 5AD, but I have nothing displayed on the screen, nor the hud ... at best I have a kafas error .... so I went back ... I tried the different codes of the different posts, but it doesn't matter ... can you confirm the codes for me? i also read, the 6wb kombi could not display the lines ?? do you have to have the command button? or just set to on mode by default? sorry, may I have a little trouble finding my way through all the information, which is a bit contradictory ... thank you for helping me... if you need more info, say so .... |
01-02-2021, 09:49 AM | #166 | |
Rep 42,998
https://www.bimmerfest.com/threads/ldw-5ad.1402772/
01-25-2021, 12:28 PM | #167 | |
Rep 51
I managed to code... I will need a confirmation: for the alert, there is only the vibration in the steering wheel ... no display on the kombi or in the hud? can you help me? thanks.... |
01-25-2021, 12:38 PM | #168 | |
Rep 42,998
01-26-2021, 02:51 AM | #169 |
Rep 51
01-26-2021, 09:30 AM | #170 | |
Rep 42,998
You say nothing is displayed in Kombi, yet at the same time you say you have small image in bottom right of Kombi. That is something displayed, and it is the correct display for cars with 6WB Kombi. To enable in HUD, try FDL Coding DKOMBI => HUD_TLC_ENABLE = aktiv
01-27-2021, 02:58 AM | #171 |
Rep 51
hello shawn,
following my tests, I have the line indicator at the bottom of the meter which changes from orange to green when my speed goes above 70 km / h, so that's good, the system is working fine on (I ordered a vibrating flywheel, as soon as I receive it I put it in place ... I will see if the vibrations work). I activated the line in the kombi with bimmercode on the other hand I have no display in the hud, neither when stopped, nor while driving, is this normal? do I have to do it with e-sys? another question: can I display the turn signals in the hud? thanks for help... |
01-27-2021, 03:07 AM | #172 | |
Rep 591
01-27-2021, 03:55 AM | #173 |
Rep 51
Hello,
I have already activated the 5AD with e-sys, I put the command button, I just have to add the vibrator ... but I have no display in the hud ... shawn told me to activate it, which I did with bimmercode, but it doesn't change anything ... |
01-27-2021, 04:44 AM | #174 |
Rep 51
I will see with e-sys ...
01-27-2021, 07:55 AM | #176 |
Rep 51
if I ordered my complete steering wheel (acc, paddles, vibrator, heated) it will arrive next week, so it will be good for the vibrating side ... I checked with e-sys, and the hud was not activated, so I'm going to code tonight, and check that it is displayed in the hud ...
is that all there is to do? there is only the vibrating, no visual display? |
