BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > F30 N20 1/4 Mile Thread
      04-20-2018, 10:34 AM   #177
Drogon F30
Drogon F30's Avatar
Drives: 2012 BMW
Originally Posted by xxxjecxxx View Post
What is the fastest 1/4 recorded so far for 328i?!
that probably be me... 12.8 @ 109
Diegov209164.50
Fr3sh29.50
      04-20-2018, 10:58 AM   #178
Diegov209
Drives: 540i Xdrive
Hell yeah bro ill get that time soon lol im going to the track next sunday so lets see what I get lol.
      04-20-2018, 11:16 AM   #179
M2_MEDUSA
M2_MEDUSA's Avatar
Drives: 2021 M2 Comp. SpecialEdition
Ran a 8.6 in the 1/8, had a boost leak tho
One thing I found out, if you have xdrive don't use launch control
Use dsc off and rev to 2,900
I need to go back to a legit track without launch control and use dsc off completely and fix my leak and I should see a 8.2-8.4 in the 1/8 hopefully
I wanna hit the 1/4 once I get under 8.4, I don't see myself getting under 8.3 without upgraded turbos, soon as bm3 dropps a OTS e30 tune for the n20/6 then possibly I may get 8.3-8.4 on stock turbo
Instagram: M2_Medusa
      04-20-2018, 11:31 AM   #180
Drogon F30
Drogon F30's Avatar
Drives: 2012 BMW
I am on RFT too, no launch control, Stock turbo and internals. Just a good mix of e85 (stay away form it) and shifting at the right points... It was the perfect day for map 7. negative DP and 60 degrees. Just learn and log your car. I have made hundreds of passes on this car.... It takes time to get it right.
      04-20-2018, 11:32 AM   #181
Drogon F30
Drogon F30's Avatar
Drives: 2012 BMW
I am down to 8.3-8.4 in the 1/8th with a 1.8 60ft. .. I have never seen an 8.2 60ft. Maybe you will be the chosen one
      04-20-2018, 11:35 AM   #182
M2_MEDUSA
M2_MEDUSA's Avatar
That seems to be the fastest, record is like 8.33 or some shit on stock block
      04-20-2018, 11:44 AM   #183
Drogon F30
Drogon F30's Avatar
Drives: 2012 BMW
I need to get some drag radials... I can only launch at 1,500 rpm
Other than that. I got both 12.8 & 12.9 . I am happy about it. I am interested to see what the BM3 does on the track. seems like everyone is going that route.
      04-28-2018, 03:43 PM   #184
2015bmw328in26
Drives: Dd
Consistent 13.2s with 2015 n26 auto, 93 Oct, lowered. Real tires, lighter rims, sports trans. 55deg out, bms stage 1, afe scoop and filter, strut bar. New plugs, 36k miles. 0 to 60 is 4.7, never use launch control, that is an easy way to drop a few tenths. If I launch like that on wet pavement my front wheels spin alot and I get torque steer. 270whp 280torque at wheels.
      04-29-2018, 06:43 PM   #185
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
Nice! Can't wait to take her up to the quarter once I'm putting down 350/350.. Should be able to take that record before I swap off the platform,
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      04-29-2018, 07:08 PM   #186
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
I'd be surprised if you didn't with those numbers. I'd even bet on you if you were xDrive. Do you struggle with launch/at speed traction at all out of curiosity?
      04-29-2018, 09:00 PM   #187
sspade
sspade's Avatar
Drives: F30
2016 BMW 320i  [7.87]
2014 BMW 328i  [6.83]
Post a time slip to the N20 / N26 Speed Rankings page... if you have one.
      04-30-2018, 09:02 AM   #188
BunkerJ
BunkerJ's Avatar
1032
Drives: 2013 328i
I wish I were xDrive, lol. Not since I put on Michelin Super Sports. I mean, 3k launches I do, of course. I launch around 2 to 2.5k and stick every time.
rjd_F302001.50
Fr3sh29.50
      07-13-2019, 11:55 AM   #189
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
Is it just me or my car. I have a 2014 bmw 328i with a bootmod3 stage 1 tune. I also have a injen cold air intake and I’m running 14.5 @ 95mph. I’m really trying to get lower. The best I ever got was 14.3
      07-13-2019, 12:04 PM   #190
sspade
sspade's Avatar
Drives: F30
Toss on a catless downpipe. That will get you under 14s for sure....
Also. You should be looking into an upgraded charge pipe and intercooler.
      07-13-2019, 12:19 PM   #191
rjd_F30
rjd_F30's Avatar
Sounds like something may be wrong with the car. That's around what a stock car will do, if not slower.
      07-13-2019, 12:21 PM   #192
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
That's the thing I was wondering about. But my car doesn't throw any codes of malfunction anywhere.
Slowest n20 of them all
      07-13-2019, 03:37 PM   #193
rjd_F30
rjd_F30's Avatar
Run a log on BM3 and see if it's making the right amount of boost.
      07-13-2019, 03:39 PM   #194
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
It is. It's running 21 lbs
      07-13-2019, 04:18 PM   #195
rjd_F30
rjd_F30's Avatar
The target is 20.85 lbs or thereabouts for stage 1 93, so I'd be surprised if it's exceeding that. Are you sure you're looking at MAP psi?
      07-13-2019, 07:23 PM   #196
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
Yes I had went on a test drive while logging the data on my computer and it maxed out at 21 lbs. I contacted bm3 support to see why even though the boost is high I'm still running short on 1/4 mile times. They said 21 lbs is the target which is fine. And they wanted me to run more. But I never got a reply back after that. However I did find something today that's broken off. It was a pvc pipe of some sort that connects from the engine to the intake.
      07-13-2019, 07:24 PM   #197
LegitF30
LegitF30's Avatar
Drives: Bmw 328i
[IMG][/IMG] I had to zip tie it back for the time being. But have no idea what it is for.
      07-14-2019, 07:17 AM   #198
rjd_F30
rjd_F30's Avatar
Have you made a pass since you reconnected that pipe?
