01-15-2020, 06:34 AM | #2091 | |
Rep 1,048
but the files are jpg, they need to be png files, and is transparency active ? Kri |
01-15-2020, 06:44 AM | #2092 | |
Rep 7
Did you notice background operation of idrive controller in both android and cic at same time? Currently I'm implementing my own CAN bridge to solve this, and curious how it is probably can be done using 1 transceiver in this case |
01-15-2020, 06:46 AM | #2093 | |
Rep 2,370
Drives: E63 645Ci
Edit: I get it now! Sorry had one of these moments. You mean not the quadlock on OEM head unit but rather the bottom connector on Android unit. I will have to pull the unit out and check it for you. I'll try to do this over the weekend. Last edited by RedErik; 01-15-2020 at 07:57 AM.. |
01-15-2020, 06:49 AM | #2094 | |
Rep 1,048
Kri Last edited by Kri; 01-15-2020 at 07:18 AM.. |
01-15-2020, 06:53 AM | #2095 |
Rep 2,370
Drives: E63 645Ci
01-15-2020, 06:57 AM | #2096 | |
Rep 7
TJA1054 is limited to 125kbs. While NBT is 500kbs. I believe, that original PCB and MCU firmware where implementing CAN bridge, to filter out iDrive controller messages from traffic to CIC/CCC/NBT in Android mode. In the schema like this: BMW HU (quadlock)<=CAN1=> Android HU <=CAN2=> (quadlock adapter) CAR And after some cloning (and mutation? ) manufacturers discarded this |
01-15-2020, 07:05 AM | #2097 | |
Rep 7
BTW I have cut chinese quadlock adapter and connected my Android HU directly to CID header. I have combox installed, so quadlock's aux pin is not used Others CAN and Power are present on CID connector More over - CID connector has 30g signal, which is going down at 30 minutes of car sleep. This makes me more confident in CAR battery life and I can remove and install HU in 2 minutes Last edited by cybertiger; 01-15-2020 at 07:06 AM.. Reason: typos |
01-15-2020, 07:05 AM | #2098 | |
Rep 2,370
Drives: E63 645Ci
As for transceivers I have attached better photo but still can't read the last character. Is it "c" or "o" ? Edit: TJA1055T/c baud rate 125 kBd... so this is a slow one as well. Last edited by RedErik; 01-15-2020 at 07:53 AM.. |
01-15-2020, 07:14 AM | #2099 | |
Rep 120
01-15-2020, 07:17 AM | #2100 | |
Rep 7
1055 is advanced version on 1054. Could you post link to seller of HU? |
01-15-2020, 08:55 AM | #2102 | |
Rep 113
Here is a video explaining the problem. Camera also comes on instead of touch apps if I go to original part by touching radio button for exemple and works like it should be, switching off when pdc button switchs off: Cheers. |
01-15-2020, 09:16 AM | #2103 |
Dirk
Rep 52
I would recommend to look for a seller in the US to avoid issues...
01-15-2020, 09:27 AM | #2104 | |
Rep 1,048
I removed kswplauncher.apk from System/app, but the main Screen is still starting, even after a reboot also i gathered a logcat when trying to install it: Code:
W PackageManager: com.android.server.pm.PackageManagerException: Package com.wits.ksw has no signatures that match those in shared user android.uid.system; ignoring! Kri |
RedErik1050.00 |
01-15-2020, 09:30 AM | #2105 | |
¯\_(ツ)_/¯
951
Rep 1,763
For now I was able to plug the RCA into the TV in and to a positive wire on the car. When I press the MODE button on my radio I can get the input to show the rear camera on demand. I did the same for my front camera but the out is very very overexposed and unviewable. I'm not sure if it's too much voltage for the front camera :/
01-15-2020, 09:42 AM | #2106 | |
Rep 80
https://www.frequencycheck.com/carriers |
01-15-2020, 09:43 AM | #2107 |
Rep 44
I have no picture with my rear view camera and I think it is because I use my rear view light to power my camera.
can I connect the camera directly via the battery or is the battery will get empty or the camera broken (due to continuous current)? |
01-15-2020, 09:45 AM | #2108 |
Rep 1,048
I just fell over a second ADB hack
With the following commands your can move the Topbar to background ! It is still available when you swipe down from top. You need adb for this, root is not required as far as i noticed. Disable Topbar. Code:
adb shell settings put global policy_control immersive.full=* Code:
adb shell settings put global policy_control immersive.full= You can also do this for only specific apps: Disable Topbar only for specific example apps: Code:
settings put global policy_control immersive.full=com.chrome.beta,com.google.android.apps.magazines,com.medium.reader Code:
settings put global policy_control immersive.full=apps,-com.google.android.apps.nexuslauncher,-com.twitter.android,-com.android.settings Kri Last edited by Kri; 11-13-2020 at 12:00 PM.. |
01-15-2020, 10:37 AM | #2109 | |
Rep 2,370
Drives: E63 645Ci
1. "You know nothing John Snow!" And by you I mean we... I don't understand why after removing this app UI still works?! 2. In order to replace it we need either sign it with a correct key or disable signature verification with Lucky Patcher. 3. SharedUserId is a pain! Yes it allows apps to share sensitive data, but for what we are doing here it is a major obstacle. |
01-15-2020, 10:40 AM | #2110 | |
Rep 113
You only need to connect the yellow video cable to the yellow camera cable and the red +12v cable that go with the yellow video cable to the 12+ camera, not de DECT cable. On the back of the car (near the camera): You only need to connect the yellow video cable to the yellow camera cable and the red +12v cable that go with the yellow video cable to the 12+ camera. The ground (black cable) isn't neccesary. Check this video: Cheers. |
01-15-2020, 11:35 AM | #2111 | |
Rep 44
And why is ground not necessesary?? 😬 And Does the camera work even before the Android system has started, as is normally the case with det? 😬 |
01-15-2020, 11:53 AM | #2112 | |
Rep 113
The ground it's not neccesary apparently because use the ground of the yellow video cable. It's explained in the video. Cheers. |
