05-25-2020, 09:54 PM | #2135 | |
Rep 37
Otherwise other than having a higher number there's no real reason for me to need to flash to anything higher at the moment, everything else works great. |
05-25-2020, 10:41 PM | #2136 | |
Rep 1,217
The issue with pausing music is most likely caused by the updated Andream system file. And I agree, not only is it difficult to obtain updates from any of these vendors but when we do they seem to be poorly developed. I have a basic iDrive controller that only moves left or right and not up or down. The setting to change a left or right toggle of the iDrive to up and down doesn't work on the latest Carlinkit software v9.2.2.yl.b. This is why I reverted back to v9.1.9.yl.b Last edited by muniz_ri; 05-25-2020 at 11:30 PM.. |
05-25-2020, 11:57 PM | #2137 |
Rep 2,637
Looking into a way on Android to disable the MMI bluetooth after connecting to android auto. So far, the only way I can see is to set Android's developer option "Maximum connected Bluetooth audio devices" to 1. Not sure if this option exists on other versions of android, but it does exist for Android 10. In theory, after connecting to the MMI and initiating Android Auto, you can manually disconnect from the MMI and then set max devices to 1, preventing it from doing its annoying auto connect. The next step is to automate this process using Tasker.
2015 BMW 535xi
Bootmod3 Stage 2 | ER charge pipe | ER Catted DP | Remus Exhaust | Gplus FMIC | KW V3 | Turner Monoball thrust arm bushings | Wallet regrets ISTA VM Setup/Tutorial |
MM198423.50 |
05-26-2020, 11:35 AM | #2138 |
Rep 5
Night mode Waze in updated andream
I everyone,
I have updated my andream : Soft v2.1.0.3.gpe.b Mcu 20.5.9.10 All IS working good but : When i use my Android auto Waze is all the Time in night mode. With all parameter in Waze (day auto night). Do yo have any idea ? It was the same with the older version... Thanks in advance 😉 |
05-26-2020, 12:16 PM | #2139 |
Rep 147
MMI or 10.25 android
If you had 6.5" screen, would you guys get the MMI and maybe later upgrade to a used 8.8" or just buy a 10.25" Android? My main use will be Android Auto any way (waze, music and calls).
Thanks. |
05-26-2020, 12:21 PM | #2140 | |
Rep 256
i went 6.5 > 8.8 > mmi > 10.25 bmw i thought about the android screens, but the screen quality and glare seem to be an issue plus there were a lot of issues at the time with other things. i haven't followed that development in awhile so you might want to research a bit. personally, id still go mmi plus bigger bmw screen again though. i probably wouldn't have bothered going to the 10.25 again though just for the headache of modifying it |
05-26-2020, 04:15 PM | #2141 |
Rep 147
Thanks.
The new Android multimedia seems better with Qualcomm and 1920x720 screens and you can also have AA or CP so you get it all in one, but reading the forum about it, it seems everyone have some issue after sometime. I am sure bmw 8.8 screen will last longer and with better display and although full Android is nice, I am mostly just listening to music with Spotify. I guess I'll take the MMI and upgrade my OE screen. |
05-26-2020, 04:29 PM | #2142 |
Rep 17
Hi All, i recently got this unit, all is working fine apart from gps. when navigating, gps seems to get lost every couple mins, it only happens when connected to carplay, navigation works fine on the phone if not connected to carplay. any idea what could be causing this. I have just updated to the latest versions now and not tested that yet, hopefully that resolves it but if anyone has any other suggestions, pls let me know. I have the small basic screen with no factory nav. many thanks
05-26-2020, 06:42 PM | #2143 | |
Rep 256
Which iPhone Which version of iOS Which nav app |
05-26-2020, 09:44 PM | #2144 | |
Rep 7
05-26-2020, 10:28 PM | #2145 |
Rep 17
Hi, yes it’s andream unit. I have iPhone X running latest iOS 13.5 , i tried it with my wife’s iPhone 8 Plus as well and it has the same issue. It has this issue on all the nav apps including Apple maps, google maps and Waze.
The issue is that it starts navigating just fine, but then 2 mins later it will loose the gps signal and google maps / Waze will freeze or if I’m using apple maps, it will constantly start saying ‘proceed to route’ Apparently, this loss of gps signal could be due to the unit trying to provide it’s own gps data rather than using the phones gps signal. Is that true? Does the andream unit have its own GPS signal? Last edited by Hassan096; 05-27-2020 at 03:39 AM.. Reason: Additional info |
05-26-2020, 10:30 PM | #2146 | |
Rep 28
I have a 2014 4 series which I believe has the NBT unit. Would love to see some pics with the google maps stretched in my unit with android auto. |
05-27-2020, 03:39 AM | #2148 | |
Rep 8
x5m25467.00 |
05-27-2020, 04:30 AM | #2149 | |
Rep 289
05-27-2020, 06:07 AM | #2150 |
Rep 91
Great thread and found some excellent info.
I ordered Andream unit for my F10 M5 (NBT) last night after going through this thread and deciding against the android screen. Also looking to get a rear camera but a bit confused if I only need a camera or some module on top? Bimmertech sells the camera for $300 on top of MMI kit so I was thinking maybe it is not just the camera but something else as well to get it working? I came across cossie1 post at the start of this thread where he mentioned that Andream's camera had fitment issues. Is that issue resolved? You reckon it is ok to go with the camera from them? And the question above remains, I just order the camera and it connects to MMI directly or need something in between? Cheers |
05-27-2020, 06:41 AM | #2151 | |
Rep 843
As for the andream camera, it fits fine, it is just the pin used to contact the release switch is made incorrectly (so need to pull it much harder than the stock bmw one), but having looked closely at pictures of the various camera's they all seem to be the same, so probably all made from the same moulds. |
msq12335.50 |
05-27-2020, 07:36 AM | #2152 |
Rep 2,152
Current: BMW M4 F83 - Mods : Pedal Covers, LCI Stereo facia Retrofit and Carbon Rear corner covers
Old: F32 435d M Sport - Mods : HR Sport Springs, 20" Veemann V-FS23 in Gun Metal, M Performance Body Kit, Pedal Covers, Eurspec CF Mirror Caps, More-BHP remap 364 BHP 741 NM, M4 Under Chassis Brace, 15mm Rear ARB, 8.8" Screen Retrofit and LCI Stereo facia Retrofit |
05-27-2020, 07:45 AM | #2153 | |
Rep 843
05-27-2020, 07:50 AM | #2154 | |
Rep 102
05-27-2020, 07:51 AM | #2155 | |
Rep 17
andream, android, android auto, apple, carplay, mmi, retrofit |
