BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
Lease SwApp
      04-03-2018, 02:01 PM   #463
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by koppermonty View Post
I used the above solution via Esys in the end to clear the restraint/airbag error code. It worked wonders via this method.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      05-07-2018, 09:20 PM   #464
tke743
tke743's Avatar
Drives: MW ZCP M3
Hi Shaun, could you send me a link to the tool 32 Please?
Formerly - "That Guy" in the purple BMW
      05-07-2018, 09:50 PM   #465
shawnsheridan
PM sent.
      05-11-2018, 02:54 PM   #466
F30sam
F30sam's Avatar
Drives: 2014 320i XDrive
Hey Shaun, could you send me a link to the tool 32 Please?
      05-11-2018, 03:10 PM   #467
shawnsheridan
PM sent.
      06-09-2018, 08:04 AM   #468
autosyonal
Belgium
Drives: f11
2012 320  [0.00]
Send a message via Skype™ to autosyonal
Hi ,shauwn
First
thanks for e-sys en ptzdata finally get it connected to the car dit not code yet
i strugled with the home made cable all conections where correct and now connection posible finally i change the obd connector it was a old one and dit not connect wel on the cars obd poort
wen i read and save fa and read and save svt do i have then all back up files wen someting gows wrong ? and how to back UP if sometings gows wrong
Can you send me link voor İsta-D , Ediabas , tool 32 i
      06-09-2018, 09:36 AM   #469
shawnsheridan
Originally Posted by autosyonal View Post
Hi ,shauwn
First
Why you make cable rather than just buy ENET cable off eBay or Amazon is beyond me in first place. At less than $20 USD, it simply is not worth the time to make one, even if you have parts laying around.
As for backups, they are worthless. If you wnat to reset ECU, simply VO Code it. PM sent.
      06-11-2018, 06:28 PM   #470
autosyonal
Belgium
Drives: f11
2012 320  [0.00]
Shawn
you are 100% right, had I known before, I would have bought a ready cable
but I could not wait 1 week delivery time
so I thought I have everything in the house just a resistor of 510 ohm to buy soldering and ready. Not so no connection got checked all 10 times apparently my old obd plug was not good and gave bad contact to the obd gate of the car bad luck
      06-11-2018, 06:32 PM   #471
shawnsheridan
Shawn
I give you an A for the effort though.
      06-24-2018, 03:49 AM   #472
madnutt
Drives: E92
Shawn can you please help?
I have tool32 and ENET cable. Fault is cc-Id 108 on a 2014 435i. Could you let me know what job to load and which options to clear this. Thank you.
      06-24-2018, 08:29 AM   #473
shawnsheridan
Clear Fault Codes:
Launch C:\EDIABAS\Bin\TOOL32.EXE
Hit F3
Load C:\EDIABAS\Ecu\F01.PRG
In the "Select Job: F01" window, select FS_LOESCHEN_FUNKTIONAL
Hit F5
"Results" window should show "JOB_STATUS = OKAY"
Note: fs_lesen_funktional only read fault codes, FS_LOESCHEN_FUNKTIONAL will delete it.
      06-26-2018, 11:32 PM   #474
tarekelsakka
Drives: BMW F30 316i
shawnsheridan I know you're probably already tired of me, but could you please send me the Tool32 link? Thanks a lot!
      06-27-2018, 11:12 AM   #475
shawnsheridan
PM sent.
      08-10-2018, 08:08 PM   #476
dieselg5
Drives: 2015 328i xdrive
Hi Shawn,
Can you please send me Tool32 as well?
      08-10-2018, 09:31 PM   #477
shawnsheridan
Originally Posted by dieselg5 View Post
Hi Shawn,
PM sent.
      08-20-2018, 03:36 PM   #478
plikmuny
Drives: BMW 320d
Can i get Tool 32 link also Shawn ? i have an error throwing for long time and i need to clear that.
      08-20-2018, 03:52 PM   #479
shawnsheridan
PM sent.
      09-30-2018, 06:19 AM   #480
ozkangadow
Drives: f20
hello shawn, could you please send me the link of tool32?
thanks
      09-30-2018, 08:04 AM   #481
shawnsheridan
thanks
PM sent.
      10-26-2018, 09:31 AM   #482
duszmic
Drives: BMW 535i Xdrive 2011
Hi,
I know that this topis was discuss few times, nether the less can we make a summary of retrofit pdc in f10 ?
1. im my e sys i have "." instead folder names - why ?
2. what functions i should acivated in esys to enable rear camera ? i have install emulator and camera. Can i ask for instruction step by step ?
