07-21-2018, 03:24 AM | #1 |
Rep 82
Best Brake Fluid for F30
Hi.
I am looking to change my brake fluid shortly. Which would you recommend? I have been looking at Pentosin DOT4 LV. Seems good value. I am not tracking the car, so just need it for fast road. Also, it is just 1 litre I need? F30 335d with 370mm Fronts |
07-21-2018, 08:31 AM | #2 |
Rep 16,082
BMW fluid is no more expensive than most.
Before changing mine I got one of these, to be sure that it actually needed changing: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 It showed the water content of my brake fluid at 0%, saving me the bother of changing it when it wasn't due. |
07-21-2018, 08:48 AM | #3 | |
Rep 5,457
07-21-2018, 11:29 AM | #4 |
Rep 270
the recommended interval is every 2 years.
I plan to use ATF super blue (or the US variant super gold) when I do it.
2013 328i xDrive | M Performance Exhaust | Injen Intake | DEPO Headlights |
2019 440i xDrive | Muffler Delete | |
07-21-2018, 12:01 PM | #5 |
Rep 16,082
It's two years or 20k miles, but there's nothing scientific about that interval, they just figure it's better to change the fluid before it gets water in it rather than later. I'm at 3 years but only 12k miles, so I wanted to be sure it was broken before I fixed it, what with the purging and bleeding procedure being the PITA that it is.
07-21-2018, 01:14 PM | #6 | |
Rep 558
07-21-2018, 02:16 PM | #8 |
Rep 16,082
+1, the main source of contamination would be water vapor that gets past the reservoir cap. For water to get in further down the line there'd have to be a leak. The directions with the tool say that 2% water content is OK, but I wouldn't wait for it to hit 3% before changing it.
07-21-2018, 04:59 PM | #10 | |
Rep 5,457
Has anyones dealer performed this service for free under warranty? |
07-21-2018, 05:31 PM | #11 |
Rep 16,082
They should, it is a CBS item, just like oil and so forth. I got the dashboard notice that it was due, but didn't take it to the dealer, as that's a 3 hour round trip, plus the time spent waiting. I'd have changed it myself if it turned out that it did need it, and will when that time comes.
07-30-2018, 04:00 PM | #13 |
Rep 891
I use RBF600 and flush once a year. Thinking about trying SRF as I've heard good things, but have yet to boil the RBF. I do a bleed after every couple track days to keep the pedal nice and taught.
12-09-2018, 02:01 PM | #15 |
Rep 210
@MacklinOSB how much fluid is required for a full system flush? I’m looking to replace my OEM fluid (about 6 months old) with RBF600 to prep for an HPDE event.
12-10-2018, 01:53 AM | #16 |
Rep 1,827
I just did mine with ATE Type 200. 2 liters should be more than enough.
12-10-2018, 08:40 AM | #17 |
Rep 891
As Jh said, about 2 liters/quarts should do the job. I would buy three quarts just in case you over bleed somewhere, worst case scenario you've got an extra bottle when you want to bleed them next. Make sure you do not let the power bleeder go dry (assuming that's what you're using).
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i Last edited by MacklinUSOB; 12-10-2018 at 09:36 AM.. |
jh_f301307.00 |
02-12-2019, 09:07 AM | #18 | |||
Rep 3,947
However, it should be noted that the wet and dry boiling points of RBF600 are only slightly above ATE Type 200. RBF is almost 3x the cost of ATE Type 200. This means that you'll have to bleed RBF600 almost as frequently as ATE Type 200. Even then, the dry boiling point of ATE Type 200 is still higher than the wet boiling point of Castrol SRF. In conclusion, I think only 2 routes that really make sense are to either bleed frequently (before every other event) with ATE Type 200 or bleed 1-2 times per year with Castrol SRF. Quote:
02-13-2019, 11:13 PM | #19 | |
Rep 5,089
At year 6 mark, both brake fluid and coolant were changed@dealer for $250 with BMWNA coupon. |
02-14-2019, 11:01 AM | #20 | ||
Rep 3,540
02-14-2019, 12:06 PM | #21 | |
Rep 891
Having an unopened bottle of brake fluid is a good thing to have, every person I know who goes to a track has one just in case. If you are bleeding for the first time it is easy to overbleed. If that happens and you have no extra, good luck driving to the store for more.
02-14-2019, 04:52 PM | #22 | |
Rep 3,947
MacklinUSOB518.00 |
