08-31-2018, 04:49 PM | #23 |
Rep 2,499
It's great that they're now not defective. I'm sure that will make their old customers very happy.
08-31-2018, 11:36 PM | #24 |
Rep 1,348
Should have never happened is the point and still customers popping up with this defective stock of fmc”s.
2k15 335i Msport xdrive 6spd
alohasurftoad3078.00 IK6SPEED4488.00 |
08-31-2018, 11:45 PM | #25 | |
Rep 2,499
I won't divulge the vendor's name, but I find it hard to believe they didn't know that the VRSF FMIC wasn't defective. |
alohasurftoad3078.00 |
09-01-2018, 05:22 AM | #26 |
Rep 1,348
Yes I understood your post lol! Absolutely and I was agreeing with you! I also got into it with Tiago about the issue with his FMICs and charge pipes having subpar quality control.
alohasurftoad3078.00 upsidedownfunnel1996.00 |
11-07-2018, 02:03 PM | #27 |
Rep 95
I've just installed this intercooler as well, but used the factory torx bolts. The ones VRSF sent are longer, but are different threading as pictured below. What is everyone else using to bolt the FMIC up?
Current: 2015 Alpine White over Coral Red M-Sport 6MT 335i (EWG) - VRSF 5" High Density FMIC / VRSF Charge Pipe / VRSF Catless Downpipe / Borla ATAK / Pipercross Filter / MHD OTS Stage 2 95 Octane / BMS Spacers - 15mm front; 18mm rear - OE 442M wheels/ Rolls Royce Door Chimes / Bang & Olufsen DSP settings for H/K
11-07-2018, 02:33 PM | #28 |
Rep 2,499
I never got the screws you show in your photo. I just re-used the original FMIC machine screws that came with the car. I don't think I got any hardware with the VRSF FMIC.
11-07-2018, 03:10 PM | #29 | |
Rep 95
11-07-2018, 04:33 PM | #31 | |
2095
Rep 43,350
If there's anyone with an existing intercooler or chargepipe that has any concerns, feel free to PM us directly and we'll be happy to get you taken care of |
11-07-2018, 07:03 PM | #32 | |
Rep 2,499
Also, I never received new hardware (screws) in the box. Is that a problem? |
11-07-2018, 07:06 PM | #33 | |
2095
Rep 43,350
There shouldn't be an issue with using the OEM screws but the intercooler has larger than OEM tabs. Longer screws should be used. If you'd like a replacement set shoot us a PM and we'll get you setup with a set. |
strobe8913.00 |
11-08-2018, 06:34 PM | #34 |
Rep 251
I'm glad this topic came up. I just received my intercooler and didn't see any screws when unpacking it. I went out to the trash and found them taped to the back of the styrofoam packing.
11-08-2018, 07:06 PM | #35 | |
Rep 1,046
I actually have louder fan noise because the intercooler is slightly larger than the stock, and the fan sits just slightly further back causing a gap between the fan and the intercooler. Is this normal? |
11-08-2018, 08:42 PM | #36 |
Rep 832
Drives: 2019 G01 X3
Can anyone confirm the VRSF provided longer screws work with the new fixed tabs (even though the threading is clearly different)?
11-08-2018, 09:26 PM | #37 | ||
2095
Rep 43,350
11-09-2018, 01:30 PM | #38 |
Rep 95
My concern with using the screws that came with the kit is the different thread pitch from the OEM screws, as shown in the picture I posted above. Unless the intercooler screws changed with different year models possibly? My car is a 2015 f30 and the thread pitch on the OEM intercooler screws is a good bit more spaced out than the screws that came with the kit.
11-09-2018, 01:51 PM | #39 |
Rep 95
In regards to the picture I posted above, how do your OEM and VRSF screws compare to what I have? (The shorter screw with the wider thread pitch is my OEM, the two longer screws are what came with my FMIC and have a tighter thread pitch.)
11-09-2018, 04:33 PM | #40 | |
2095
Rep 43,350
We love selling intercoolers but I'd hate to have to sell you another one because the first FMIC fell off the car due to using the incorrect fasteners |
11-10-2018, 09:44 AM | #41 |
Rep 251
I'm installing mine this morning. I've got everything in and tightened up, but it looks like the new intercooler is hanging about 1/4" too low. The tabs on the intercooler do hold the fan in place but just barely. The intercooler mounting bolts are tight and I can't get it to go any higher. The mounting tabs are touching the mounting points. The fan isn't moving and won't go any lower. I've loosened everything back up and moved things around but this is the best I can get. It's the same on both sides. Piping and clips are in place. The fan shroud is touching the turbo inlet on the intercooler and it could be binding there and preventing it from dropping into place. There is plenty of clearance on the other side between the fan shroud and the outlet/chargepipe. Is this correct fitment?
11-10-2018, 10:05 AM | #42 |
Rep 251
The screws I received are exactly the same as yours. I had no problems using them.. The mounting points look to be plastic and it looked like the new screws cut a bit deeper than the factory ones to help support the weight of the heavier intercooler.
11-10-2018, 05:56 PM | #43 | |
2095
Rep 43,350
bkdore103.00 |
12-12-2018, 08:55 AM | #44 | |
Rep 832
Drives: 2019 G01 X3
Tiago@VRSF I tried contacting you via PM three times since last week with no response, so I'm hoping I have better luck here. |
