04-30-2018, 10:10 AM | #67 |
Rep 844
I agree. I don't care much for being talked down to though, and have no problem spending my money elsewhere. As a prior business owner, I may have a higher standard on what I expect, but an even higher standard when it comes to customer service.
terryd5150507.00 |
04-30-2018, 10:11 AM | #68 |
Rep 844
Just into the charge pipe. I wont be using the methanol as a fuel system replacement, I just want it to cool the air charge. After looking at some of the Fuel-It kits, id LOVE to have one of the spray bars, however I just don't have the need for it, and if I someday need more than I can get with my current setup, im just going to sell it and get a 5/6 series and do turbos.
04-30-2018, 11:35 AM | #69 | |
Rep 1,499
Cool!! I'm assuming you got the AEM Part Number: 30-3302 - V2 Water/Methanol Nozzle and Controller Kit, Standard Controller - Internal MAP with 35psi max, 200psi WM Pump, Jets, NO TANK INC. So my main questions regarding your setup, and why I was asking about a DIY is this....
1. What tank were you getting and where were you locating it? 2. Where did you mount the pump? 3. Did you get the shut-off solenoid and if so where did you mount it? 4. Where did you mount the indicator LED? 5. Where did you connect the boost line hose? I've been thinking of utilizing the windshield wiper fluid reservoir as my tank as windshield wiper fluid for cold climates can have as much as 50/50 meth/water solution. Snow Perf boost juice is 49/51. I like the windshield wiper fluid reservoir solution as you'll get an indication that your boost juice is low when the low-level indicator comes on the dash. Quote:
04-30-2018, 12:31 PM | #70 | |
Rep 844
Oh, thought id add... while I cant stand Snow Performance as a company, the boost juice is very cheap through Summit Racing, and if you order over $100, its free shipping. I just order 3 cases at a time and its cheaper than anywhere else I can find, plus free freight. I will probably eventually order methanol through Torco since they are local, but I had already ordered the AEM through summit, so I just added on the boost juice for this order. |
04-30-2018, 07:01 PM | #71 | |
Gettin It Figured Out
1820
Rep 2,669
Honestly, I'd wait...there's "supposed" to be a HPFP solution coming soon...should solve the up-top fueling issues up to the N55's "internals" capabilities. (I'd still recommend Fuel-It's S2 or S3 LPFP for sure, must have) and.....welcome to the Pure dark side . .. offer still stands . .
F30_SixSpeed1170.50 terryd5150507.00 |
04-30-2018, 07:05 PM | #72 | |
Rep 844
04-30-2018, 07:10 PM | #73 | |
1820
Rep 2,669
LOL! I get it. If you're going to go down the 1/2 mile run rabbit hole, I'd keep your build right where it is and start planning for a F80 or F82... .
05-01-2018, 01:58 AM | #74 | |
Rep 1,290
05-01-2018, 07:06 AM | #75 | |
Rep 969
The XDI-HPFP-35 is the first High Flow High Pressure Direct Injection pump to replace Bosch, Denso, Magneti Marelli and Delphi pumps. It is capable of up to 200bar / 2900psi injection pressure. It flows up to 35% more when mounted on the same cam lobe. The XDI-HPFP-60 is the bigger brother of the XDI-HPFP-35. Since it was designed based on the same flexibility criteria as the XDI-HPFP-35, it can be mounted on almost all the same engines. It is capable of up to 240bar / 3500psi injection pressure. It flows up to 60% more when mounted on the same cam lobe. http://www.xtreme-di.com/index_files/HPFP35.htm
ronanz1819.50 terryd5150507.00 |
05-01-2018, 07:13 AM | #76 | |
Rep 1,499
Would this require injector upgrades as well?
05-01-2018, 07:23 AM | #77 |
Rep 969
From my understanding, no... stock injectors should be fine to use with the HPFP upgrade.
JaredG_F301106.00 |
05-01-2018, 07:25 AM | #78 |
Rep 844
Do you know what the flow limitations are of the stock injectors? running straight E85 would be wonderful for these cars pending there is enough injector and pump to flow it... However if the injectors are the next hurdle to hit a 550-600ish rwhp E85 mark, that will be a pricy upgrade.
05-01-2018, 08:13 AM | #79 | |
Rep 969
05-01-2018, 09:15 AM | #80 |
Rep 1,290
This looks sweet, do we have any idea of the price? The 35 would suit my needs pretty well i think...
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i |
05-01-2018, 10:31 PM | #81 |
Rep 844
If perfection had a sound... Unfortunately the one day it rained this year was the day I installed the exhaust, so no videos until I get time later this week
Thanks to Mike at Extreme Powerhouse for the fantastic pricing and FAST shipping on this kit... I couldn't be happier with the service he offers and will keep feeding him money as fast as I can make it! Last edited by FenixMike; 05-02-2018 at 08:57 AM.. |
terryd5150507.00 |
05-02-2018, 10:24 AM | #82 |
Rep 211
Did you install the Akra downpipe as well as the full catback? If so I'll be very interested to hear how it sounds. I've resisted getting a downpipe as I actually really like how the Akra sounds with the stock downpipe. I've overdone it when it comes to exhausts on too many cars in the past and don't want to make that mistake again, especially with how much an Akra or a Fabspeed DP costs.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
05-02-2018, 10:51 AM | #83 | |
Rep 844
05-02-2018, 11:11 AM | #84 | |
Rep 211
Interesting to hear your perspective of the Wagner DP. I'm assuming its the catted version. I would have expected it to be noticeably louder but with the Akra being valved perhaps that helps tone it down when closed.
05-02-2018, 11:21 AM | #85 | |
Rep 844
Wagner makes top notch stuff, and judging by the construction and welds alone, its worth every cent over the competition. Fitment was perfect, sound is great, and it looks absolutely fabulous. |
05-02-2018, 12:29 PM | #86 | |
Rep 211
Interesting that you find the catless DP reasonable. I'm guessing that we might have different ideas on that front, since I'm probably 30-40 years older than you (just a guess of course). Excellent job on your build BTW. Very well thought out and executed.
05-02-2018, 12:48 PM | #87 | |
Rep 844
05-02-2018, 01:26 PM | #88 |
Rep 844
Idle vid cold start
F30_SixSpeed1170.50 |
