07-27-2017, 10:35 AM | #1 |
Rep 3,940
Another Stock N55 Charge Pipe Failure
Well, folks, I have now experienced the dreaded charge pipe failure...
The car in question is my 2014 335i M Sport RWD with SAT. It has approximately 78,500 miles on it and I did purchase the BMW Extended Warranty Platinum for 5years/100,000 miles. The only modifications are M Performance Suspension Kit, M Performance Limited Slip Differential, F8X M3/M4 brake pads, and APEX ARC-8 + Michelin PSS 255/40/18 all around. The powertrain has remained completely bone stock for the entire life of the car. No tunes, piggybacks, downpipes, intakes, etc. It failed around ~7:30 in the video below which was taken at Summit Point, WV during an HPDE: Here's a picture of the cracked charge pipe: I'm thinking that because the charge pipe is plastic, it will withstand stock boost pressures initially. But after age and repetitive heat cycles, the plastic becomes brittle and is prone to failure right where it connects to the throttle body. I was able to duct tape it and drive it to a BMW dealership in Eco Pro mode after that failure. The Service Advisor said that because the powertrain is stock, this failure would be covered under my extended warranty. Here's what it looks like after the repair work: The service advisor said that this was the 3rd stock N55 to come in this week with a cracked charge pipe. The other two vehicles had cracked charge pipes around 35,000 miles and 50,000 miles. I'm curious if we're going to be headed to recall... I've attached a ISTA ISTAD Charge Pipe PDF as a reference in case you may want to upgrade to an aftermarket charge pipe. My plan is to run the original plastic BMW charge pipe until the extended warranty has run out. Last edited by Polo08816; 07-27-2017 at 10:51 AM.. |
07-27-2017, 10:44 AM | #2 |
Rep 305
Most likely not, being these cars have been out since 2012. It's more limited to the people that drive the cars hard, and if you look whom buys these that doesn't happen that often.
07-27-2017, 10:47 AM | #3 | |
Rep 5,776
Because tracking. Time for: tunes, piggybacks, downpipes, intakes, etc. I think you said you were against that stuff a while ago, but time to go to the dark side and get a metal pipe. Nice vid by the way--looks like fun.
2013 335i Msport Black sapphire/Coral red. MHD. stage 2--e30 VRSF DP, ER CP, Dinan Shockware. VRSF 12mm/15mm spacers. Cobra dashcam. Various codings.
Last car: 2011 335i Msport. JB4. Vrsf CP |
Paul_M356.00 |
07-27-2017, 10:54 AM | #4 | |
Rep 3,940
I may consider the metal pipe post warranty period unless BMW revises the charge pipe and starts selling an improved OEM version. |
07-27-2017, 10:57 AM | #5 |
Rep 10,346
Well, think of it like this. You'll never own the car when itbreaches 150k miles so you'll probably never replace it again.
Water pumps and hoses on the other hand.
"Drive more, worry less. "
07-27-2017, 11:00 AM | #6 |
Rep 3,940
I'm confident that BMW has calibrated everything in the car to fail spectacularly at 101,000 miles - just outside my extended warranty coverage.
07-27-2017, 03:46 PM | #8 |
Rep 190,597
Glad your car is under warranty
Polo088161604.00 |
07-27-2017, 03:57 PM | #9 |
Rep 3,940
07-27-2017, 06:13 PM | #12 |
Muwiee
19
Rep 178
Drives: 07 335i '12 335i
Had same issue in Sunday. My car is totally stock. I got aftermarket pipe and waiting to see if the warranty will cover the price of the pipe. I went with the FTP from Bavauto. Broke in two spots. Right around connection to throttle body and also where vacuum line connects.
07-28-2017, 03:54 PM | #13 |
Rep 3,010
Drives: 2019 M2 Competition
I have a spare OEM pipe in good condition if anyone is interested.. *grin* (the Active Autowerke upgrade is installed!)
07-28-2017, 04:31 PM | #14 | |
Rep 589
07-28-2017, 05:19 PM | #15 | ||
Muwiee
19
Rep 178
11-03-2017, 08:38 AM | #16 |
Rep 963
My stock charge pipe blew up on Wednesday. Never had a tune, no aftermarket mods other than suspension and muffler swap.
United BMW Roswell wants $755 to replace it because my factory warranty expired (I'm at 50,700 miles) and CPO "does not cover it".... Going to make a fuss if the manager doesn't end up covering this. This is total bullshit. |
11-03-2017, 08:42 AM | #17 | |
Rep 2,082
If not get the VRSF for $225 i think and do it yourself.
11-03-2017, 08:56 AM | #18 | |
Rep 963
Think I'm going to just go aftermarket at this point. Does the VRSF still have fitment issues? |
11-03-2017, 09:22 AM | #20 | |
Gettin It Figured Out
1820
Rep 2,669
ER is another option...OEM fitment .
11-03-2017, 09:30 AM | #21 |
Rep 775
Sadly, welcome to the 'club'. Yeah, the CP blew on the 2014 435i earlier this year and she had around 28k miles on her. To be fair, the car had Dinan Stage 2 at the time so nothing crazy yet a nice improvement over stock. Frankly, get the ER CP and be done with it. JMHO YMMV
Enjoy the Drive,
Steven 2014 435i M-Opt, M LSD, Dinan CAI/IC/BTurbo/Stage 4, ER TIC/CP, GFB DV+, Fabspeed HJS cat DP & Mich PS4S. |
kabrichx133.00 |
11-03-2017, 09:37 AM | #22 |
Rep 3,010
No doubt super frustrating, but yeah, welcome to the improved CP club! I am a big fan of the Active Autowerke CP, and my DIY video can help you through the install. (Or probably any other brand as well)
Sorry for the crappy experience but thankfully you are a relatively easy fix. I on the other hand wont be driving my car for a week.. literally. I have roughly 600 miles left on my warranty and after a full inspection by my independent shop, have a laundry list of little things for the dealer to fix. The earliest date possible? A week out... no driving for me! *laugh*
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
