BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Experience with 10.25" android 7.1 HU's
proTUNING Freaks
      01-04-2019, 02:21 PM   #1629
StevenRed
Italy
Drives: BMW X1 E84 XDrive20d
Originally Posted by mike78 View Post
siri also works with carplay!! perfect!!
Also, with the latest Android update you will find a new section in the factory settings, which allow you to set bmw oem buttons to android functions (learning function)!! Have not used it yet.
Finally, here are some new settings in other factory menus. Unfortunately I changed the mode to bmw-nbt and now I cannot have the bmw-id6 menu. There is no such option!
The option to change the mode is still there, in a second page... they moved to another pages differently from previous versions...
      01-04-2019, 02:24 PM   #1630
mike78
Drives: BMW G30 530e M Sport (2019)
Really? do you have screenshot? I can go down to garage and look now...
      01-05-2019, 01:39 AM   #1631
mike78
No way to switch back to id6 menu. Any help??
Only bmw-nbt, Audi and bmw-evo option!
There is a 3 radio button option. At first there was no radio option selected and I had id6. From the time I selected bmw-NBT I cannot deselect radio option to switch back to id6!
ID7 - 12Kwh Battery
Remapped to 388hp/644.9N.m
KN Filter
      01-05-2019, 10:14 AM   #1632
smahel
Drives: MINI Cooper, 2020 X1
load a factory.xml that contains a <UI>7</UI> line - for example this: https://drive.google.com/file/d/1L8B...ew?usp=sharing . And you have done.
      01-05-2019, 10:37 AM   #1633
mike78
Thanx, do you know if it's possible to export the current factory.xml?
ID7 - 12Kwh Battery
KN Filter
      01-05-2019, 12:37 PM   #1634
smahel
Sorry, I do not know how to do it. In any case, all settings from the provided file do not work even though it was included with the latest firmware version (PX3 20181128) provided by the reseller
      01-06-2019, 12:50 AM   #1635
mike78
How did you extracted the file from firmware?
Maybe we should look in the previous firmware...
ID7 - 12Kwh Battery
KN Filter
      01-06-2019, 08:19 AM   #1636
smahel
this is not extracted file, this is file from my reseller
      01-06-2019, 02:09 PM   #1637
jaydiemm
Drives: F10
Originally Posted by irose50 View Post
I think if you select any other "APP" and then switch off that should solve it loading Music when you start.(Only need to do it once, not every time). I find the same thing happens if I selected BT last too.
As for replacing the Music and Video tiles, I use a Launcher instead...everything I want on one screen
Hi- I'm interested to doing this, what is the process to install a launcher? I want the video tile to launch VLC video or Mx video app instead of the default version that is linked to the big video icon. Or do i need to go into APP section to locate the video APP I downloaded from play store? Thank for the advice.
      01-07-2019, 02:28 AM   #1638
mike78
Here is the missing BMW-ID6 option and cannot have the Id6 menu with the latest firmware (2018-11-28).
      01-07-2019, 07:12 AM   #1639
smahel
I know, I have it the same, as everyone who installed this update. Just update factory settings with the factory.xml that contains a <UI>7</UI> line, and you will have ID6 set. The ID6 menu does not, of course, come back.
      01-07-2019, 07:50 AM   #1640
mike78
The xml you've sent contains a password field with value 1951. This means that this will change the factory access password to 1951 ?
Also, are we sure that we are not missing any new setting that appeared in 2018-11-28 update?
      01-07-2019, 12:39 PM   #1641
sjoskog
Drives: F34 & E88
Wow, I wonder how that's possible.
Here is what I have on software dated 2018-11-28. There are a lot of options including some strange JLR which came as a new one (and I have no idea what JLR stands for). This was done by using the firmware mentioned in the beginning of this chain.
      01-07-2019, 06:18 PM   #1642
zenjubo
Drives: 2011 X3 F25
Does anyone have problems with the bluetooth setting stuck saying initialising? Because of this, I am unable to pair my phone. I had the phone paired in one of the earlier firmwares until I removed the pairing and had not tried to re-pair again until recently. Now I am noticing bluetooth setting stuck on initialising. So I know the unit is capable of bluetooth pairing and the issue seems to be related to certain firmwares.
      01-07-2019, 11:14 PM   #1643
Mikesmith2939
Drives: 2013 320i xdrive
JLR could be Jaguar Land Rover
      01-08-2019, 01:47 AM   #1644
StevenRed
Italy
That's the same I found last time... JLR is a strange and horrible chinese interface, nothing interesting...
      01-08-2019, 04:26 AM   #1645
Geoken
Drives: BMW X1 E84 2013
Originally Posted by sgs72 View Post
Please can you tell me how can i install igo or sygic to my android 10.25...what resolution...i try but say missing file...or from where can i download ...thanks
Have a look on the GPSURL forum www.gpsurl.com
The iGO file you are looking for is IGO_World.rar. Its 65.5mb.
You will need to dig around a bit to find it the link to download it. Elsewhere on that forum are instructions on what you need to do to install it. You can also find the latest maps.
      01-08-2019, 04:39 AM   #1646
Geoken
Also i have problem with backup camera..i connect to dvr is wrong??where i have to connect?any diagram
Connect the Yellow (video) cable from your camera to the Yellow cable from your Android unit that is labelled 'rear camera'. It will be something like the one in this picture....
What type of camera do you have? Have you connected the power correctly?
      01-08-2019, 04:48 AM   #1647
Geoken
Is your phone an Android? Have you tried setting the phone to Developer Options?
      01-08-2019, 06:00 AM   #1648
smahel
yes, you can change it arbitrarily.
      01-08-2019, 06:10 AM   #1649
smahel
It probably also depends on the MCU version (mcuupdate.bin). Mine are NBT_20180717 and CIC_20180824. Both units have BMW-NBT, Audi and BMW-EVO only ...
      01-08-2019, 01:26 PM   #1650
zenjubo
Drives: 2011 X3 F25
As a matter of fact, it is an Android phone (Oneplus 6T to be specific) and I already have developer options enabled.
I'm a bit confused tho. The initialising message implies a state in the Ugode HUD which prevents it from becoming ready. Not sure how an external phone would affect that state on the HUD.
