01-30-2023, 03:36 PM | #23 |
Aidas
Rep 13
No problem. I'm also preparing to do a lot of retrofits. Making a lot of research, buying parts, making wiring drawings and etc. The fun will start in second half of February
01-31-2023, 11:48 AM | #24 | |
Rep 139
If you need anything regarding this options please let me know. Have a nice day |
02-03-2023, 08:52 AM | #25 |
Rep 139
Hi all! Having some progress today. Sunblind is working (manually) I got from amazon a reverse polarity switch to find out if it’s working and YES, IT IS!
alexonahurry221.50 |
02-03-2023, 08:59 AM | #26 |
Rep 139
Next step does it automatically switching REM and pressing it from drivers switch buttons. That’s my next issue. Once I swap switch from mine (1) from new one with sunblind option (4) it doesn’t work (No function at all, no button works).
The only function performed is that driver side mirror tilts down when i plug it. I did some research and as far as I understood is LIN controlled. So, would it be a matter of FEM coding? What I’m worried about is that pin out is different. Hope you can help me |
02-03-2023, 12:13 PM | #27 |
Rep 139
I thinks there´s another step (wiring) I have to perform with the switch
https://f30.bimmerpost.com/forums/sh....php?t=1360941 Does anyone have the wiring of drivers switch button? I have NON power folding mirrors. I have normal ones Thanks for your help |
02-04-2023, 08:29 AM | #29 |
Rep 139
This is going to be very helpful. Is it possible for you to share complete diagram for S35 Switch block driver's side? Right now i have basic configuration ( NO power folding mirros) and must change to high configuration with power folding mirrors and sunblind BTW what SW are you using to have all this info? It's amazing Tks again! |
02-22-2023, 07:35 AM | #33 |
Rep 139
Analyzing schematics unfortunately I won’t be able to retrofit sunblind using S35 Switch driver’s door with the sunblind option (right now is working using an external switch) due that a I have basic mirror configuration (manual seats, no power folding mirrors) basic mirror doesn’t support LIN as is needed in the S35 Switch driver’s door with the sunblind option.
The S35 Switch driver’s door withOUT the sunblind option uses point to point wiring to control side mirrors. Nice learning! If you want to retrofit sunblind, you must also change power folding mirrors. I’m not sure I’ll do this in the short time. Tks all for your help. |
02-22-2023, 10:33 PM | #34 | |
Ozzy Dude
222
Rep 187
Drives: BMW F30 330i LCI
retrofit sunblind, sunblind |
