11-21-2018, 04:38 PM | #816 |
Rep 321
Another happy customer here. My UK dealer got the fascia panel in a couple of days (£45) and I thank KTE for his excellent suggestion of an alternative and very cheap cable: https://f30.bimmerpost.com/forums/sh...&postcount=813
KTE78.00 |
11-22-2018, 05:32 AM | #817 | ||
Rep 1,246
11-22-2018, 05:48 AM | #818 |
Rep 321
Try the fourth line of your unnecessarily long quote. I also used this and the seller is a first-class guy.
If you can't work this link, go back to the original post here: https://f30.bimmerpost.com/forums/sh...&postcount=810 |
11-23-2018, 04:39 PM | #820 | |
Rep 351
The one I bought: https://rover.ebay.com/rover/0/0/0?m...2F173183792577 Although any similar lead schematics should work. Last edited by KTE; 11-23-2018 at 05:50 PM.. |
11-25-2018, 05:05 AM | #821 |
Rep 1,246
I received my £1.89 Y connector yesterday and tried it out. It works a treat.
The male fits into the BMW female perfectly. With the females, pry off the outer sheath of the connector to reveal the body of the connector and exposing the pins. These then fit perfectly into the BMW males perfectly. A little insulation tape around each will ensure they all remain in place. Top stuff. |
11-27-2018, 05:14 AM | #822 |
Rep 150
I order a Y cable from ebay (£30) and the trim from BMW (£34) yesterday. Should all be here Monday
There was loads of Y cables for around £1/£2 from china, which are probably spot on but I didn't have the balls to risk it lol. |
11-27-2018, 05:24 AM | #823 |
Rep 356
If anyone’s interested, I have the LCI trim panel and Y cable available for sale out of my F36.
Also got the LCI AC panel with white/orange illumination. (uk) |
11-27-2018, 02:28 PM | #824 |
Rep 1,246
I've just retrofitted the LCI climate control panel including stereo and climate display.
I already have IHKA3 so just need to code the colour change. I'm planning a software update at an independent in a few weeks. Can I leave the old panel installed for this or does the original need to be fitted? |
01-03-2019, 11:44 AM | #826 |
Rep 1
01-05-2019, 07:31 PM | #827 |
Rep 17
Did mine. For such a small change it looks worlds different!
2015 F30 N20
https://www.instagram.com/hotazf30/ |
01-10-2019, 05:53 PM | #828 |
Rep 381
Drives: 2018 340xi tanzanite blue
Wait in my 2018 340i I have ambient lighting around the hvac unit on the center console? Didnt even notice
01-11-2019, 07:58 AM | #829 | |
Rep 55
I just did the retrofit and I made my own Y-cable. Everything works but I find that the light around the trim appears to be more white then orange even though the other ambient lights are orange. Do I need to code that it should be orange? Thanks Tony |
01-11-2019, 08:04 AM | #830 |
Rep 321
Is it possible that there is a problem with your home-made cable? Try setting the lighting from Classic to Sport (assuming you have that option) and see what changes. Coding should not be the cause, if it's wired to the LED under the dash, above the cup holders, and should work in exactly the same way..
_Tony_12.50 |
01-11-2019, 08:48 AM | #831 | ||
Rep 1,246
Roll the brightness dial up and down at night when the dash is orange and this should change the climate panel to orange. |
01-14-2019, 12:48 PM | #832 |
Rep 42
Found this one: Would I have to buy a Y-Wire Harness? https://ebay.us/P5dxDK
d1mitrov66.50 |
01-14-2019, 01:43 PM | #833 | |
Enthusiast
466
Rep 1,791
Drives: F87 M2 / F31 330d
Garage List 2004 E46 BMW M3 [0.00]
2017 F87 BMW M2 [10.00] 2013 F31 330d Touring [9.50] 2009 E89 Z4 Sdrive 30i [9.00] 1989 E30 320is 2-door [10.00] 1986 E28 M535i [9.00] |
2017 F87 ///M2, Long Beach Blue, 6MT
2013 F31 330d Touring, ///M-Sport, Alpine White, Alcantara/Cloth, 19" Style M403, 8AT 2009 E89 Z4 SDrive 30i, Titanium Silver, Coral Red Leather, 19" Style 296, 6MT 1989 E30 320is, ///M-Technik II, S14 Engine, Sterling Silver, Black Leather, 16" BBS RS 003, 5MT 1986 E28 ///M535i, Agate Green, Pine Green Velours, 16" ALPINA, 5MT |
d1mitrov66.50 |
01-20-2019, 11:12 AM | #835 | |
Enthusiast
466
Rep 1,791
The LCI controls only work if you have IHKA3 Module, which was used from 03/2014 builds onwards.
01-21-2019, 03:26 PM | #836 |
Rep 24
I did this mod tonight, jeez the radio/air con controls were PITA until I figured it out.
I have plastic trim tools which made the job pretty easy eventually. Nice mod. |
