BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > BMW F30 Instrument Cluster Color
      06-14-2015, 11:17 AM   #1
bryan06
bryan06's Avatar
25
Drives: BMW F30
Hi All,
Can it be changed the instrument cluster color from orange to white?
Mine is like following, it's orange
this is example what I mean, it's white.
Maybe there are some code change color from orange to white. Someone know it? is it possible?
Thanks,
      06-14-2015, 11:37 AM   #2
kitster
Drives: G31 M Sport
Originally Posted by bryan06 View Post
Hi All,
Thanks,
ECU: KOMBI [3007]
VALUE: DIM_NACHT_EIN
DEFAULT: werte = 32
NEW: werte = FF
Changes orange night colors of KOMBI to be white at night (No Navi Night Switch too). I'm guessing it also does the same when the lights come on in tunnels etc etc.
      06-14-2015, 12:37 PM   #3
bryan06
bryan06's Avatar
25
Drives: BMW F30
Originally Posted by kitster View Post
ECU: KOMBI [3007]
DEFAULT: werte = 32
NEW: werte = FF
Thanks,
I will try it and inform,
My car's currently values like following,
Also there is a KOMBI, 3007, DIM_NACHT_AUS, Activ Werte = 36
Do you know that What does meaning the DIM_NACHT_AUS?
      06-14-2015, 12:41 PM   #4
kitster
Drives: G31 M Sport
Nacht according to Google is night. The others are dim = dim and aus = from.
      06-14-2015, 01:12 PM   #5
bryan06
bryan06's Avatar
25
Drives: BMW F30
Maybe this is day mode, My lcd letters is white in day time like following,
Maybe also there is coding for lcd screen color.
      06-14-2015, 02:53 PM   #6
bryan06
bryan06's Avatar
25
Drives: BMW F30
ECU: KOMBI [3007]
DEFAULT: werte = 32
NEW: werte = FF
I have tried which your shared codes, but not change color after coding.
I saw the below after coding, Aktif changed to UNKNOW,
Before code
Aktiv
Werte=08
After code
UNKNOW
Werte=FF
Because of this , I have changed back coding.
Do you have any suggestion?
Thanks,
      06-14-2015, 05:27 PM   #7
kitster
Drives: G31 M Sport
Before code
Aktiv
Werte=08
After code
UNKNOW
Werte=FF
Thanks,
The coding I gave you came from the coding cheat sheet. I've personally not done it myself. However a quick look on google. Others have done the same and also got the UNKNOWN value. They say it's normal if you change the Werte value to something other than the defined ones.
Did you FDL code and save it, see if it works? Worst case is just back it out afterwards.
      06-14-2015, 07:21 PM   #8
david51
david51's Avatar
France
538
Drives: bmw M3 F80
hello
I made the change on the counter
here's how
http://f30.bimmerpost.com/forums/sho...1027008&page=2
      06-15-2015, 01:24 AM   #9
bryan06
bryan06's Avatar
25
Drives: BMW F30
Yes, I have made FDL coding and power off car, I wait a little and power on again. Then I have connected car via e-sys and checked the coding whether is OK.
Coding was OK, but not change the color.
Thanks again.
      06-15-2015, 01:27 AM   #10
bryan06
bryan06's Avatar
25
Drives: BMW F30
Originally Posted by david51 View Post
hello
here's how
First of all, your car looks amazing. I hope that Use a good day.
I have readed your post and I saw that This feature requires hardware changes. So we can not change the color with any coding, right?
Thanks,
      06-15-2015, 05:28 AM   #11
david51
david51's Avatar
France
538
Drives: bmw M3 F80
hello
I do not think so
Thanks,
      06-15-2015, 08:23 AM   #12
bryan06
bryan06's Avatar
25
Drives: BMW F30
So No need try to change color with coding.
Thanks,
      06-15-2015, 09:02 AM   #13
carzaddict
Drives: 2015 Cadillac Escalade ESV
no need to try coding. Changing the color on the speed/tach requires changing the LEDs (hardware).
the only thing you can code is the screen below it
2015i Cadillac Escalade ESV
      06-15-2015, 09:32 AM   #14
bryan06
bryan06's Avatar
25
Drives: BMW F30
Yes, my lcd screen is white in day and it's orange in night. this means that we can change color of lcd with coding.
      06-26-2015, 02:48 AM   #15
BimmerF32_430i
BimmerF32_430i's Avatar
303
Drives: 2012 335i
I coded mine today and the only thing that turned white was the small screen like Bryan. Has anyone coded it to where everything is white?
      06-26-2015, 04:57 AM   #16
franzzz
franzzz's Avatar
Italy
144
Drives: BMW M4
Hi All,
Thanks,
led, hardware replacement
BMW F82 M4 Black MHD CS Map - GTS DKG - Navi -Performance Brake RSL1 Pads - USB - DivX-DVD - Bluetooth - VoiceControl - Connect - Apps - Online - H&K - TrafficInfo - SpLimInfo - WhiteMerino- PDC - Cam - Adaptive Led - Antitheft - CP Steering- Performance ST - Adaptive CP Setup - GarageDoorOpen - Pipercross - Stock Exhaust - Mdrivers Pack - 437M Wheels
      06-29-2015, 03:26 PM   #17
bryan06
bryan06's Avatar
25
Drives: BMW F30
Yes...
      10-01-2015, 02:04 PM   #18
ibrahim321
Drives: f30 328i
Before code
Aktiv
Werte=08
After code
UNKNOW
Werte=FF
Thanks,
anyone figured how to fix this?
      11-26-2015, 04:54 AM   #19
UtilisaE9
Belgium
Drives: Various BMW
Hi Everyone,
Can you indicate the posssible coding for the LCD (at the bottom of the tachi).
This coding:
ECU: KOMBI [3007]
DEFAULT: werte = 32
NEW: werte = FF
Does not change anything on mine (still orange at night)
Thx!
      11-26-2015, 09:29 PM   #20
RedRaiderDavid
Drives: 2017 X3 35i X Drive M Sport
2009 BMW 328i  [0.00]
Originally Posted by UtilisaE9 View Post
Hi Everyone,
This coding:
ECU: KOMBI [3007]
DEFAULT: werte = 32
NEW: werte = FF
Thx!
If you read the posts in the thread you will see it was determined that the actual LEDs have to be changed.
      11-27-2015, 03:21 AM   #21
UtilisaE9
Belgium
Drives: Various BMW
Right, But I mean the LED screen.
      11-30-2015, 05:39 PM   #22
Steve_M_Sport
Steve_M_Sport's Avatar
614
Drives: U06 230e Active Tourer
This is impossible to do as there are only orange LED's in the instrument cluster so no amount of coding can turn them white. You need to replace them with white LED's.
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport
