10-08-2019, 11:40 AM | #1 |
Rep 45
Siri not working after iOS13.1.2
Hi all,
I have an F36 430D 2017 and before iOS13 I was able to press and hold the dialogue button on the steering wheel and ask Siri questions. Now when I ask questions I get a message back from Siri saying "there is a problem with the connection". It just doesn't want to work over the BMW iDrive via bluetooth I thought this might be Siri playing up with my mobile network, but when the car is off and I use the normal Hey Siri command it all works. All questions etc... are answered. It is not working when connected to the iDrive. Any ideas? Does iDrive need a new software update for iOS13 features? Thanks JD |
10-09-2019, 11:34 AM | #2 |
Rep 4
I have confirmed that iOS 13.1.2 has disabled some features. I am still investigating, but it has disabled third-party cables, even those with MFi certification. None of my Anker cables work, only the Apple cables. You did not say if you were connecting via Bluetooth or cable, but if you are using a cable, make sure it is an Apple cable. This could be a bug, so we will have to wait and see if Apple releases a fix. However, I am lead to believe they purposely disabled third-party devices to protect the quality image of their product. The problem is that they disabled Apple-approved, third-party cables. This is also true of some wireless chargers. They no longer charge at full output. Either way, they are having connectivity issues.
10-09-2019, 12:28 PM | #3 | ||
Rep 45
Thanks |
10-10-2019, 02:35 PM | #4 |
Rep 1,467
I am using an Anker cable and my phone connects.
My issue is that i cannot select songs on my playlist. I can only press forward and back.
2014 EBII 435ix - Stage 2+ Dragy: 0-60 3.61; 60-130 10.18
2020 MG M340ix - Dragy: 0-60 3.48 2018 LBB X4M40i - Stock Dragy: 0-60 4.85 |
10-10-2019, 03:28 PM | #5 |
Rep 1,686
Drives: 2014 428i and 2018 X5
Works fine for me using both standard idrive, and my CarPlay MMI box.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
10-11-2019, 02:56 AM | #6 | ||
Rep 45
10-18-2019, 05:48 AM | #7 |
Rep 45
Hello,
I have been told by BMW to contacted the following dept about this Siri issue bmwconnecteddrive@bmwfin.com Last edited by JuiceDude; 10-18-2019 at 05:55 AM.. |
11-07-2019, 09:00 AM | #9 |
Rep 4
Not Completely Fixed
I downloaded 13.2 yesterday. While is should not matter, I also removed and reconnected my phone through Bluetooth. BMW service recommended this. Connected Drive did connect much quicker today. Immediately, I was able to access:
- Calendar - Contacts - Amazon Music - Spotify (with exceptions) The Home directory of Spotify still requires me to access Home, Exit, then renter the Home menu before it populates with options. Next question.... Since I find the BMW navigation to be better than the apps on my phone, are there other advantages to the CarPlay retrofit? If Connected Drive works, I am having difficulty justifying a $650 expense for the CarPlay retrofit. Thanks, |
11-07-2019, 11:51 AM | #10 |
Rep 295
Does anyone know how to program the handsfree button to Siri and not the BMW connect? When I am using carplay the only way I can summon Siri is with the 'hey Siri' command. Is this the new experience in IOS 13.2???
Shawzy44
2023 BMW X3 M40i 2019 BMW X5 40iX 2019 BMW 440iX M Performance Cabriolet |
11-07-2019, 12:01 PM | #11 |
Rep 10,473
You answered your own question based on what is best for your needs.
11-07-2019, 02:11 PM | #12 |
Rep 4
Try long-pressing the voice command button. In my 2016, short-press summons the BMW Connected Drive commands. Long-Press summons Siri on my USB connected phone.
11-10-2019, 08:41 PM | #13 |
Rep 1,031
Drives: Like a bat out of hell.
Be sure to "allow SIRI when locked" enabled in your SIRI setting
