      10-20-2019, 01:02 PM   #14983
RokasLTU
RokasLTU's Avatar
Drives: Volvo V50, BMW 318d
Originally Posted by gecko.ch View Post
Do you mean maybe this one?
Kombi 3000> BC_Leerzeile > aktiv
I need to code this. Is it the one you've mentioned?
      10-20-2019, 02:48 PM   #14984
gecko.ch
gecko.ch's Avatar
Switzerland
Drives: F30, F20
Yes
      10-20-2019, 03:58 PM   #14985
RokasLTU
RokasLTU's Avatar
Thanks!
      10-21-2019, 03:43 AM   #14986
colin.t.chiang
Drives: 2016 330e
Hi Shawn,
Thanks for your recent pm with the codes. I received the following message when trying to read the coding data:
"CAFD_00000794_018_070_003 Fehler:
CPS read from ECU "ECUId:FEM_BODY_0x40" failed! [C070]
openECUConnection for link FEM_BODY_40_ETHERNET failed with error MCD
Error Severity:2051, Error Code: 49184, Description: Object with name not found, Vendor Code: 3, Description: provided name FEM_BODY_40_ETHERNET doesn't map to an item[1694]"
I thought it was because I didn't have the latest files but I downloaded those only a few days ago. Can you please advise the cause and fix?
The car is a 2016 330e.
Many TIA,
Colin.
      10-21-2019, 06:14 AM   #14987
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by colin.t.chiang View Post
Hi Shawn,
Many TIA,
Colin.
"Object with no Name Found" means one of the following:
1) Insufficient Power (e.g. Motor not Running or Car not on Charger)
2) Incorrect E-Sys Launcher Car Series Selected
3) Incorrect E-Sys Connection Target Selected
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      10-21-2019, 11:00 AM   #14988
colin.t.chiang
Drives: 2016 330e
Thanks Shawn, I'll look into that tomorrow. I should have mentioned that I was able to successfully change parameters in the ACMS module before I struck this error with FEM_BODY. Does that strike you as strange?
TIA, Colin.
      10-21-2019, 11:11 AM   #14989
shawnsheridan
TIA, Colin.
That changes nothing I wrote. ACSM is ECU common to multiple chassis, so even choosing the wrong E-Sys Connection Target or wrong E-Sys Launcher Car Series it will still map correctly and code. It is when you take ECU such as FEM_BODY, which is unique to F20/F30 Chassis and you use wrong E-Sys Connection Target or wrong E-Sys Launcher Car Series it will fail.
      10-21-2019, 01:28 PM   #14990
RokasLTU
RokasLTU's Avatar
Is there a way to code an interior lighting to light up after engine is turned off?
      10-21-2019, 01:42 PM   #14991
shawnsheridan
If you mean link the light to the ignition switch position, no.
      10-22-2019, 09:48 AM   #14992
colin.t.chiang
Drives: 2016 330e
Hi Shawn,
Thanks for your help with the error. All good now... Issue was series selection... Had "all" instead of "f20"... New menu selection with this version of software caught me out.
As always, your help is much appreciated.
Cheers,
Colin.
      10-22-2019, 10:33 AM   #14993
shawnsheridan
Hi Shawn,
Cheers,
Colin.
      10-22-2019, 11:58 AM   #14994
Shawzy44
Shawzy44's Avatar
Drives: 2019 BMW 440ix MP Cab
Hi Shawn!
I have a 2019 BMW 440 (F33 LCI) can you send me the latest links?
TIA!!
Shawzy44
2019 BMW 440i XDrive Cab MP///MPPSK///MP FRONT SPLITTER///M CF MIRRORS///MP CF TIPS///
      10-22-2019, 11:59 AM   #14995
shawnsheridan
Originally Posted by Shawzy44 View Post
Hi Shawn!
TIA!!
PM sent.
      10-22-2019, 12:14 PM   #14996
Shawzy44
Shawzy44's Avatar
Has anyone been successful in adding a M Performance logo to the new digital dashboard in the F3X LCI (to replace the M550 logo)?
Shawzy44
      10-22-2019, 03:54 PM   #14997
JankyLV
JankyLV's Avatar
Drives: F34, i3
Hello! I'm looking to code F34 and i3. I already have the cable, will try to do some upgrades soon. Can someone please share the links? Thank you!
      10-22-2019, 05:02 PM   #14998
shawnsheridan
PM sent.
      10-23-2019, 09:11 AM   #14999
szaqall111
Drives: BMW F31 163 ED
Hello
I have BMW F31 2012 and planning to change my manual seats to manual seats with heating and electric adjustment of lumbar part.
Please tell me what should I code for that heating and electric regulation are just working?
      10-24-2019, 10:03 AM   #15000
dragosv6
Romania
Drives: 2016 f36 430i MPacket
hey guys
after i did a coding with esys 3.33 ( for example put the temperature under tyre presure)
i press the save button then go back from the edit windows
now the question is what shall i press?
Code or Code NCD?
i tried both but the coding is not there.
i did not receive any error, the PA is active,connections is successful, everything is made by the book but is not working. tried another coder but the same thing.
am i missing something here?
      10-24-2019, 10:37 AM   #15001
shawnsheridan
Originally Posted by dragosv6 View Post
hey guys
Code or Code NCD?
1) Right-Click on CAFD and Read Coding Data
2) Expand the CAFD Folder by clicking + symbol
3) Right-Click on the CAFD file and select Edit => Edit CAFD as desired
4) Click the Blue Floppy Disc Icon to Save CAFD
5) Click the green back arrow icon
6) Right-Click on the CAFD file => Select Code FDL (Code NCD)
      10-24-2019, 10:48 AM   #15002
dragosv6
Romania
yes exactly!
after i press Code NCD cause i don;t have code FLD, the coding starts and finished with no errors.
for example i want to code the tire temperature.
after i modify to aktiv , save it, go back , press code NCD.
it finishes but there is no temperature in idrive.
if i connect back to the care and read the module it's back to nich_aktive.
it's like the codding is not saved! but oneslty i press the save button.
very strange!!!
      10-24-2019, 10:57 AM   #15003
shawnsheridan
yes exactly!
very strange!!!
Try a different Launcher. This one is a hacked version of TM's Launcher PRO, and functionality is questionable. Code NCD should write new value to car, and you say it is not.
      10-24-2019, 01:39 PM   #15004
dragosv6
Romania
i installed esys 3.28 and worked! with 3.33 is not working.
