10-04-2017, 10:20 AM | #23 | |
Rep 3,018
Drives: 2019 M2 Competition
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
kkasicha7.50 |
10-04-2017, 05:59 PM | #24 | |
Noob
Rep 7
Green #1 = ? Brown #2 = Ground Yellow #3 = ? Blue #4 = ? |
10-04-2017, 09:26 PM | #25 |
Rep 1
Hi,
Can you repost the pictures in the first post? All I can see is a place holder "Photobucket please update your account....." (or am I doing something wrong?) Also can you confirm there is no coding (I am wondering why that is)? Thanks, Phil |
12-07-2017, 11:56 PM | #26 | |
Rep 1,179
Drives: 2014 X5 50i M Sport, M3(sold)
01-11-2018, 03:48 PM | #29 |
Rep 3,018
Photos are busted.. can you update so they can be visible again? Thanks!
04-06-2018, 09:46 PM | #31 |
Rep 7
AVIN rear camera
When you turn the steering wheel, do the green and red lines on the screen curve accordingly or are they static?
In my screen they stay still... what do I need to do to make them connected to the steering wheel? I just finished installing my gen2 10.25 screen and I connected the camera: I just connected the red cable REAR CAMERA from the screen and the RCA yellow from the screen to the camera wire. It works. |
10-15-2018, 06:43 PM | #33 |
Rep 91
I got the wireless 2.4ghz camera with transmitters. I don't know which wire in the car's harness is for the reverse camera. The video cable that I was provided with the camera has a blue wire that needs to tap into the reverse camera wire in the car. Anyone know where this is (what color)?
12-28-2018, 12:28 PM | #34 | |
Rep 1
WiFi transmitter
01-03-2019, 10:13 AM | #35 |
Rep 91
10-20-2019, 07:20 PM | #36 |
Rep 4
Can someone help me please. I bought the after market reverse camera and connected it.
In the image you will see the 2 red wires, that's the camera wire connected to the 12V reverse camera light. I used a DIGITAL MULTIMETER to find out the correct wire. However when I put the car in reverse. The camera connections is very very temperamental, its comes on for about 2 seconds and then goes off. I believe the camera is not getting enough power to it. How did people fix this is this? I have this little box, I believe it's a relay box, However I have no idea on how to use it. This image is my reverse camera with all the wires. The only thing missing is the relay. Pictures and links will be useful please. Thanks Last edited by richard_yii; 10-20-2019 at 07:41 PM.. |
10-23-2019, 01:06 AM | #37 |
Rep 399
The easiest way to connect a third party backup camera to an Android unit:
1. Connect the yellow video cable to the Android box, and to the camera in the other end. 2. Connect the red wire sticking out from the video cable, to the red Camera (+12v) wire on the Android unit, and the other end to the red camera power cable. This is usually all it takes. Ground is supplied through the video cable. Now, if this doesn't work, then you could try this: Ground the black cable from the camera power harness. If still no success, you might need to use the Detect (DET) wire from the Android box: Find the +12v cable in the backup light harness, and run a cable from it to the Detect wire. In this last case, there might not be any power from the Android Camera +12v cable either, so you will need to find another power source. Only in this case is a relay needed. Last edited by Mjam; 10-23-2019 at 01:15 AM.. |
10-23-2019, 01:18 PM | #38 | |
Rep 45
05-07-2022, 11:15 AM | #40 |
Rep 2
Afternoon All,
I have just retofitted which looks like a kit extremely similar to this. For some strange reason when i put the car into reverse (manual) and the rear view camera activates - the rear parking sensor image which should push over to the right hand side of the screen (split screen is on and works normally) just vanishes and the right side of the screen is left black. if i click the options button i can see that opens behind the camera screen if that makes sense (almost like the camera screen is an overlay). The first time i tested this everything worked fine and i could see both the parking sensor screen (on the right) and the rear view camera (on the left). No idea why all of a sudden its not splitting correctly when the camera is active. Sensors still work fine. Has anyone experienced this or know a fix? Its a 8.8inch screen in a F31 - NBT with satnav. |
05-07-2022, 01:52 PM | #41 |
Rep 2
I managed to fix this problem.
Turns out i had DIP switch 1 and 3 on but was using a non OEM camera. This made it not work right. turning DIP switch 1 to the off position fixed everything. If anyone else has similar issues or fits this themselves, this guide i have just found was perfect. https://incartec.blob.core.windows.n...20(BM-908).pdf |
12-29-2022, 11:27 AM | #42 | |
Rep 106
DO I need to try different dip switch settings? I have HU-Entry with 6.5 inch screen. Andream MMI unit and their after market camera which looks identical to the picture you posted. |
01-06-2023, 03:03 PM | #43 | |
Rep 5
