BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Retrofitting lumbar support
      06-16-2018, 12:17 PM   #23
sspade
sspade's Avatar
Drives: F30
2014 BMW 328i  [5.00]
Interested in this mod as well...
Anyone have part numbers of known to fit pieces?
BMW 328i FBO, Bootmod3 Stage 1
      06-17-2018, 11:36 AM   #24
powerflower
Drives: E46 - 320i
lumbar air pad corbeau
This is the item im planning to use
https://www.corbeau-seats.com/product/lumber-support/
in fact i got 2 and will try and replicate the bmw original which uses 2 bags.
but if that does not work as i hope then will use 1 for passenger and 1 for driver.
      03-28-2019, 04:59 AM   #25
unclebobuk
Drives: BMW F31 335D
going to give this one a go...
https://www.ebay.co.uk/itm/Real-Esse...dAw3Iveim4XPCg
I'll try and take some pics on the install on the F31 LCI.
btw if anyone had an amazon link for the a4 backing used on those pics that would be useful
thanks
      03-28-2019, 01:02 PM   #26
sensible
sensible's Avatar
494
Drives: BMW 420i M-Sport Gran Coupe
thanks
I think that one will be too big.
Here is my guide to retro fitting lumbar support.
https://f30.bimmerpost.com/forums/sh...fitting+lumbar
      03-28-2019, 01:06 PM   #27
sensible
sensible's Avatar
494
thanks
I used that one and it is an ideal size. You don't have to inflate it much to give a good level of support. Mine works perfect.
My guide is here;
https://f30.bimmerpost.com/forums/sh...lumbar+support
      04-12-2019, 09:09 AM   #28
unclebobuk
My guide is here;
Here's some pics of my install. Still needs a bit of modding i think as it's not quite there yet for me... I might resort to removing the physical lumbar support from inside the foam as i can still feel it although with this inflated it is definitely an improvement. I used some kitchen chopping mats as a backing on my inflatable cushion which i got from B&Q for about 1.99. Ideal backing..
To route the inflation bulb i removed it and then threaded the tube out of the underside of the seat and up the side to it's current location. Whole job including chopping down the backing and cable ties etc only took about 30 mins. Hope it helps. Cheers.
ps apologies if the pics are side on. i set them all to the correct rotation but for whatever reason they kept being flipped onto their side!
Watsey2561.50
      04-12-2019, 09:47 AM   #29
Watsey
Drives: F31 330D sDrive M Sport
Thanks for the photos and the tip regarding B&Q chopping mats. I've already bought the inflatable bladder - just need to get round to installing it.
What's the method/knack for removing the seat back ?
Current : F31 330sD, DMS remap, Ohlins Road & Track, Millway Motorsports top mounts, SuperPro poly bushes, Quaife LSD, Stoptech BBK with Pagid RS4-2 pads, Birds ARBs.
      04-12-2019, 11:51 AM   #30
sensible
sensible's Avatar
494
If you look on my guide here there are some pics .
There are two pins at the bottom of the seat back. Pull the centre pin out of the retaining plugs and they should then pull out. Pull the bottom of the seat back out and then pull down as the top of the seat back has two hooks. (see pic).
Hope this helps.
      04-12-2019, 11:54 AM   #31
sensible
sensible's Avatar
494
Nice job. Looks similar to what I did.
I cut my inflation bulb off too, threaded the tubing through then just pushed the bulb back on.
      04-16-2019, 08:19 AM   #32
pointfive
Drives: 435d
[QUOTE=sensible;24580025]I used that one and it is an ideal size. You don't have to inflate it much to give a good level of support. Mine works perfect.
I also used this one. It's been in there for over 3 years. Works great.
      04-18-2019, 04:46 PM   #33
npr
Drives: slow volvo
Hi, does it help now you have fitted it? Has it alleviated your back pain somewhat? I drove for 2 hours and then 2.5 hours back about 3 weeks ago and was in pain afterwards for a few days. On holiday in a mk7 Golf, back and neck was fine (it haD lumbar support)
Also do you need to declare to your insurer? And if I do this would i be best to wait until out of warrany (enD jun)
      04-18-2019, 05:23 PM   #34
BeamerFan_f30
Drives: BMW 3 Series f30
I've done mine without backing and not had any issues. The only problem one I can think of is that the air doesn't always stay so you have to reinflate manually. Also make sure you have two plastic clips (2x6mm) that hold the seat cover in to hand because you may break them when you remove them from the bottom of the seat cover and you put it at the right height that suits you one inflated 1/3 of the way it's rule of thumb.
      04-29-2019, 01:26 PM   #35
Watsey
Finally got round to installing the single cell lumbar support into my driver's seat. I used a flexible cutting mat (Amazon), cut to size, as a backing.
It makes a nice difference and has plenty of inflation capacity in reserve.
      06-13-2019, 09:01 AM   #36
flashollie
Drives: F31 2017 335d black
I've just order the lumber supports.
I've gone mad and bought 2.
I know, I'm too good to my missus!
I'm hoping this will mean less earache when I table the remap.....
      06-19-2019, 01:39 PM   #37
flashollie
Fitted these today one on each front seat. Took no more than 30 minutes the pair. Very easy to do. Very good value mod with very good improvement to seat comfort.
Highly recommended.
      10-11-2019, 10:38 AM   #38
BishTing
Drives: F30 335d XDrive MSport Lci
easy
Thanks for the guide. Took me 5 mins prep & 5 mins to install.
I got the three element bladder and went to Argos for the flexible board.
It works for me, my back and shoulder pain is gone. Just need to refine the seating position over time.
      10-12-2019, 05:13 PM   #39
C320
C320's Avatar
Drives: F30 320d, F86 X6 M, W203 C320
Have any of you that have fitted these also got heated seats?
I'm tempted to do this on my wifes F30 as she suffers from lower back pain. However, I'm a little concerned that inserting the inflatable pad and the PVC covers could impair the heated seats.
Is it obvious where the lumbar pad goes?
Cheers in advance!
      10-12-2019, 06:00 PM   #40
Watsey
Cheers in advance!
Yes, I have heated seats and they continue to work as normal.
It's pretty logical where to place the bladder - directly in front of the spring-located wire frame which forms the support in the back of the seat.
Releasing the springs on one side makes it much easier to insert the bladder. They are quite strong - needs a bit of force.
C32087.00
      10-12-2019, 06:06 PM   #41
C320
C320's Avatar
Awesome, many thanks. Looking at the pictures above that does seem to make sense now. Appreciate the help
      10-21-2019, 08:19 AM   #42
Michael340i
Drives: BMW 340i Touring, Aston Martin
Cheers in advance!
If you buy the OEM lumbar support, it pushes the seat forward the same as this pad, so no need to be concerned about the heater elements
