BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Door Actuator Fuses
      05-03-2018, 02:50 PM   #1
yogi2472
Drives: 2013 BMW 335i xdrive
Door Actuator Fuses
My passenger side door is lock and i cant open with the remote, pull handle, or center unlock switch. Could it be a bad fuse? Anyone know which fuses I should look at?
I already a new actuator to replace, but need to get the door open to replace it.
      05-09-2018, 09:27 AM   #2
volk50
Drives: 2013 F30 335i
I doubt it's the fuse if you can't open it manually.
I currently have a similar issue, passenger side front door will not unlock with the button or remote. I can unlock/lock and open it manually though. I'm hoping it's just a fuse, but I checked the three in the trunk and they were fine. I still need to check the last one that's in the engine bay though.
      05-13-2018, 02:08 AM   #3
yogi2472
It was not the fuses. I was able to get the door panel of with door closed with some trims tools and some pulling. I replaced the door lock actuator and now everything works.
Rebound61.00
      04-07-2019, 12:16 PM   #4
duhec
Slovenia
Drives: 2013 BMW F21 116dA
I have this issue also where I can open the passenger door with the handle but not with the inside button/keyfob/comfort access entry.
How did you fix it?
      10-20-2019, 01:54 PM   #5
Bkeller90
Drives: BMW 328i (F30)
How did you fix it?
Same issue here. My passenger door will not unlock with the fob or center button. I need to use the interior handle to unlock it. It will, however, lock along with the other doors when the fob or center button is pressed. I’m not sure if this is a fuse or actuator issue.
Help!
