BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Clean Diesel!
      09-21-2019, 09:35 AM   #1
CO_Steve
Drives: '15 M235 Dinan S1 MT Slicktop
Clean Diesel!
So this week I did the metal to rubber giubo swap/output flange inspection/locktite job. The good news is our 65k mile '14 wagon had very little wear on the splines. In order to access the driveshaft you have to get the exhaust pipe out of the way. There is a slip connection near the front where the SCR metering unit enters through a Y connection. After I was done with the job it dawned on me that for a 5 year old, 65k mile car the pipe, both outside and inside was amazingly pristine. The joint came apart easily and even inside the pipe looked nearly new, no soot deposits of any kind. Clean diesel.
      09-23-2019, 08:56 AM   #2
Enabled
Drives: 328xd Wagon
I can confirm the same.
These are really clean. In fact the North American 328d has SULEV level emissions. Yet nicer than a Prius. It only didn't get the SULEV rating because it would require special extended warranties.
-2014 328d Wagon 2WD, 8HP flash, self-tuned, 265hp/430ft-lbs.
Others
-E36 328is ~210-220whp: Lots of Mods. 2000 Z3 Roady. 2003 VW Jetta TDI Manual 47-50mpg Modded. S52 Estoril Z3M Coupe.
