BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > F31 MPPSK Vibration Help
      09-29-2019, 08:11 AM   #1
Chris_340i
Drives: BMW F31 340i
Hi all
Need some advice.
I have an F31 340i with sunroof fitted and it has the under car braces.
I have the MPPSK fitted, however recently I've noticed the centre section now rests on the under body braces and causes vibration.
Has anyone else has this issue? Could it be exhaust centre section is loose and sliding out.
Many thanks
Chris
      09-29-2019, 08:28 AM   #2
Malone
Malone's Avatar
243
Drives: 340i Touring Shadow Ed. MPPSK
How long have you had MPPSK? Does the vibration come from somewhere around the driver’s footwell?
If it’s a recent fit and coming from that area, it’s probably the standard problem with MPPSK of clamp bolt against heat shield. There’s a whole thread about it on here somewhere. Take back to fitting dealer and get them to cut down bolt or rotate clamp slightly 👍
hilift57.50
      09-29-2019, 08:39 AM   #3
Chris_340i
The vibration feels like it's the drivers footwell but I'm more than convinced it's in the centre.
Argh taking it back is going to mean a 3 drive!
      09-29-2019, 08:48 AM   #4
Malone
Malone's Avatar
243
When we had the problem with ours, our dealer advised us to ring BMW assist, so the car would get in ASAP and we’d get hire car (if you’ve got this?). Said car was pretty much undrivable and played it a bit dumb, worried about safety etc.
Car was collected and taken to dealer, hire car delivered and then we picked the car up (but it was local), but I’m sure they’d drop the car back.
Good thing about the MPPSK being a BMW warranted product!
      09-29-2019, 08:53 AM   #5
Chris_340i
I'll give it a go.
Many thanks
      09-29-2019, 09:01 AM   #6
Malone
Malone's Avatar
243
Thinking about it - if it’s under warranty you should be able to get it sorted by any local dealer 👍
      09-29-2019, 03:36 PM   #7
Chris_340i
Would the whole still have to be under warranty or just the exhaust.
Had the exhaust fitted in June but the cars 3 year warranty has now expired.
      09-30-2019, 04:45 AM   #8
Malone
Malone's Avatar
243
Pretty sure the MPPSK come with 1 year warranty at least, irrespective of the car.
Might just be worth a quick call to fitting dealer to double check 👍
      09-30-2019, 08:24 AM   #9
Fazil
Drives: Bmw 340i '16
Could be wrong, but if I remember rightly, the exhaust comes with 4 years warranty if fitted on a new car at factory, and 2 years if fitted on a used car?
      09-30-2019, 10:31 AM   #10
Chris_340i
I'll check my paper work tomorrow re warranty tonight.
My car is a used car.
      09-30-2019, 05:28 PM   #11
Pizzaeatingking
Drives: VAG
It's not possible to have it fitted at the factory, it's a dealer fit part.
      10-23-2019, 02:53 AM   #12
Chris_340i
Hi all,
Many thanks for all your suggestions.
This is turning out be a frustrating situation... The car has now been back to BMW and they have seen and heard the issue. It does not appear to be vibration from the front exhaust clamp but from the valves in the MPSSK back box itself.
Now for the annoying part.. BMW are not sure warranty of the parts covers the valves and the replacement part is 1700 quid.
BMW have agreed to take my car for a week for more tests and diagnostics. Fingers crossed they sort it. I really don't see how they cannot replace the faulty item as its all installed by them.
Let's watch this space however I must admit I'm slightly concerned about getting a large bill.
      10-23-2019, 03:24 AM   #13
Londoner
Londoner's Avatar
Drives: 340i msport+ MPPSK
The valves are surely part of the MPPSK and warrantied along with the rest of the product. Maybe they just don't want to commit until they're 100% certain as to the problem. Good luck.
t5pilot653.00
      10-23-2019, 04:31 AM   #14
Chris_340i
I agree, thanks.
I'm sure it will be ok but I just hope BMW don't try anything on. It was only fitted in June and only covered 2k mileage.
      10-23-2019, 06:34 AM   #15
Abzynthe
Abzynthe's Avatar
Drives: BMW 440i Gran Coupe LCI
Hi all,
£1700! So basically the whole exhaust is replaced?
Previous: 2010 F01 740d M Sport | 2015 F36 420d M Sport w/ M Performance kit
Current: 2018 F36 440i M Sport w/ M Performance kit, MPPSK & AP Intake
My Daughter's Lego Youtube Channel
      10-23-2019, 06:39 AM   #16
RobUK
RobUK's Avatar
Drives: 340i MPPSK
I would hope that if the exhaust is only 4 months old and has only covered 2K miles and has not been damaged in use, then it would fall under the heading of 'not of merchantable quality' and BMW would replace it f.o.c.
Good luck, hope they sort it for you.
Life is a state of mind
      10-23-2019, 10:09 AM   #17
Chris_340i
I agree, thanks.
Yes that's what BMW think, all the valves are in the back box which seems to be where the cost is. The centre section must be fairly cheap.
Thanks and I 100 % agree, I have had no reason to fiddle around with the exhaust as I am no mechanic
      10-23-2019, 10:23 AM   #18
bimmer456
Drives: 340i
It's the remainder of new car warranty or 2 years 25k miles whichever is greater or something like that. It should say on the website of your country.
      11-05-2019, 10:54 AM   #19
Chris_340i
Hi All,
To close this all off. Had a call from BMW today. They replaced the MPSSK exhaust under warranty. They have had the car for a week for tests and the valves had failed.
Therefore I pick the car up on Saturday - earliest I can do.
However my 19 plate 320i msport new shape 3 series loaner is a lovely car.
      11-05-2019, 11:12 AM   #20
Londoner
Londoner's Avatar
Hi All,
Congrats mate. So were the valves faulty from day one?
      11-05-2019, 11:54 AM   #21
SW6Steve
Drives: F30
Hi All,
Glad you've sorted your car👍
Interesting your impressed with a new shape 2 litre, even though you have a 340.
Must be the build quality?
      11-05-2019, 12:42 PM   #22
Chris_340i
Hi All,
The 2 litre engine is dog shit but the car is lovely.
Bet the M340i is a beast.
