BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > Rear tail light socket corrosion
      10-07-2019, 12:02 AM   #1
theothernguyen
Drives: '12 Jet Black 328i Sedan
Question Rear tail light socket corrosion
Hi all,
So randomly, my left rear brake light starts having intermittent brake light bulb malfunction, sometimes it would work, sometimes it would not, but then it just stopped working altogether. The bulb looks good, but when I tried to remove the bulb, I had a bit of trouble, it felt stuck and I had a hard time twisting it to remove.
When I finally did, I saw this... the light bulb socket contact is corroded and so was the tip of the bulb.
Anyone seen this before or know what could have caused it? Will I have to fix the whole housing unit?
Thanks!
      10-07-2019, 07:21 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
It's caused by a loose bulb fit, which results in arcing. You probably need to replace the socket assembly. It may be possible to clean the contact but there's not much room to get at it.
      10-07-2019, 11:56 PM   #3
theothernguyen
Thanks for the reply. Arcing will cause the tip of the bulb to melt/disfigure as well?
      10-08-2019, 07:11 AM   #4
Billfitz
Billfitz's Avatar
Yes, it will. What you're seeing on the contact is probably material that came from the bulb tip, just as an arc welder deposits material from the welding rod to the work.
