BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > F31 weird dome light problem - help!
      10-15-2019, 04:29 PM   #1
bateman1234
Drives: E90
I've got a strange electronics problem: the interior dome light comes on when I open the door of the car, but not when using the switch on the light itself.
Because the light works it is possible to rule out bad bulb.
I suspect the previous owner did some tampering with the electronics/coding. Anyone knows how to fix it? I want to be able to use the switch to turn on the dome light!
Any help would be appreciated.
      10-20-2019, 02:06 PM   #2
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
This selection should be an option under the main menu/settings/lighting in the iDrive. Also you can change the interior lighting to orange (classic) and dim it if you want under the same menu. If it's not there in the iDrive then yes, someone has coded it to do so. I'm pretty sure it is though.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
https://www.facebook.com/newfinishcolumbia
http://www.instagram.com/newfinishcolumbia
      11-04-2019, 11:48 AM   #3
Onizukachan
Great Teacher
Onizukachan's Avatar
Drives: E46/3 M56 & F31d
I would look at the switch itself.
Do other button lights work for the doors as opposed to the main cabin light?
Or do all 3 buttons not work.
      11-04-2019, 01:01 PM   #4
Mikesmith2939
Drives: 2013 320i xdrive
Those options are not available on all models.
I believe you need the extended light package in the UK for that.
