BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Oil cooler
      10-17-2019, 01:41 PM   #1
cedaj
Drives: F30 328i xDrive
Oil cooler
Has anyone done an oil cooler on a n20/n26? After going on spirited drive the temperature rises to about halfway between the second tick and 250. Is this a normal oil temp?
      10-17-2019, 02:14 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Unless you're doing some serious tracking there's no need for additional oil cooling. The oil temperature does fluctuate a lot depending on driving conditions. It's supposed to do that.
rjd_F301670.50
johnung1637.00
      10-17-2019, 06:33 PM   #3
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
Once it hits half way or just past it will
go back down
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
      10-21-2019, 02:35 PM   #4
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
As people have mentioned above, no need unless you tracking her. But if you are to do it get the 335I thermostat housing and run lines to the oil cooler. You can just get the regular Mishimoto one for $145 and run some lines to it. Reason you want the 335I housing is cause it has a thermostat and will allow your car to heat up normally and open once up to temp. You will usually see about 15-20 degrees on average cooler temps if you live in Florida or Texas where it is super hot. But not much change if you are in the colder states.
2012 F30: 5959 Big Turbo, Top Mount Mani+ DP+Intake, CSF FMIC, FTP CP, Walbro 450LPFP, AIC 4 with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max HP 428WHP 452WTRQ.
      10-21-2019, 08:26 PM   #5
floridaorange
Do you think that's a smart mod for us Florida drivers? I assume yes.
Stage 2 BM3
Sounds pizzagatey.
      10-22-2019, 02:34 AM   #6
Manboy
Sweden
155
Drives: 2016 428i EB M-Sport
some members have done an oil cooler. there are several threads on here with lots of good info.
I did my oil cooler last year. It keeps the temps in check and the power delivery consistent.
https://f30.bimmerpost.com/forums/sh...4&postcount=28
ESS Stage 2 - Wagner EVO2 Competition FMIC - Wagner Catless DP - Kate Cool Oil Cooler - AFE Charge Pipe - ER TIC Pipe - AFE Momentum CAI - AFE Air Scoop
      10-22-2019, 05:36 AM   #7
johnung
FYI- That N55 oil thermostat opens at about 230-235 degrees F. and purposely keeps the oil between 230-250 which is where it is designed to run. Guys tend to assume that colder is always better, but it is not! Our engines are optimized to run in a certain range. I was told that with an N55 (by someone involved in racing them) to only be concerned if I saw it hitting 260+.
Assuming something is not wrong with the engine, that's impossible to do unless you are doing lap after lap on a racetrack. The racing solution is upgrading the stock oil cooler located in front of the right front tire area to a larger unit. And there's even a racing kit that adds a second oil cooler over on the other side.
      10-22-2019, 07:47 AM   #8
Billfitz
Billfitz's Avatar
+1. The engine is most efficient when run as hot as possible. The problem with running it hot is that increases the potential for pre-ignition. For these reasons the temperature management system will have the temperature higher when cruising, where you're not constantly accelerating and decelerating and pre-ignition isn't a concern, colder when you are driving more aggressively.
rjd_F301670.50
