BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Hardwire Fuse Question
proTUNING Freaks
      10-18-2019, 09:45 AM   #1
Ishan99
Ishan99's Avatar
Drives: 2017 BMW 320i
Hey guys!
I have 2 dashcams in my car that I am hardwiring. They both have a wire for ground, a wire for ACC, and a wire for BATT. For one of them, I put it on fuse number 143 for ACC and 150 for BATT. This works fine for me. The dashcam is always on.
However
The other dashcam is put on 146 for ACC and 152 for BATT. The dashcam stays on when the car is on. But when the electrical fully shut off after ~10 mins, this turns off with it.
The first dashcam I mentioned is always on, but this second dashcam turns off with the car.
Can someone tell me which fuses I should use for ACC and which fuses I should use for BATT? I have an F30 btw.
Thank you!
Ishan Achar
Former: 2004 BMW E46 325i
Current: 2017 BMW F30 320i
Follow @Black_Lux_Cars on IG
      10-18-2019, 10:30 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Why not run both off the same fuses? Just make sure the current draw isn't too much for them to handle.
      10-18-2019, 10:31 AM   #3
Ishan99
Ishan99's Avatar
How would I do that? Put the 2 fuses in one?
Ishan Achar
      10-18-2019, 10:42 AM   #4
Billfitz
Billfitz's Avatar
You'd connect two wires, one from each camera, to each fuse.
      10-18-2019, 12:19 PM   #5
Ishan99
Ishan99's Avatar
But how would I connect them? They both have the thing you put into the fuse (idk what it's called). It's not just a wire. It has the thing that plugs into the fuse.
Ishan Achar
      10-18-2019, 01:09 PM   #6
Billfitz
Billfitz's Avatar
Use a Y splitter after the fuse tap.
      10-19-2019, 11:27 AM   #7
Ishan99
Ishan99's Avatar
Bump
Ishan Achar
