BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Weird dash lines on instrument cluster
proTUNING Freaks
      10-20-2019, 01:57 AM   #1
drdonuts
Taiwan
Drives: E92 F20 F82
Hello, after some play around with KOMBI and HU_NBT FDL editing, I found my instrument cluster's screen show up this dash line as shown below.
Initial thought it's probably speed limit info, but isn't SLI logo has a red circle around the dashes? If anyone know, please help. Many thanks!
Name:  Screen Shot 2019-10-20 at 2.55.12 PM.png
      10-20-2019, 04:33 AM   #2
IAmATeaf
IAmATeaf's Avatar
Drives: 2015 F30 335i
2015 BMW 335i  [0.00]
What car is that from?
      10-20-2019, 04:38 AM   #3
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
94
Drives: BMW 320d
That’s indeed for speedlimit info, since you don’t have it, it doesn’t show up in a red circle.
      10-20-2019, 09:36 AM   #4
drdonuts
Taiwan
Drives: E92 F20 F82
This one is from 2018 1series F20 LCI.
      10-20-2019, 09:49 AM   #5
drdonuts
Taiwan
Drives: E92 F20 F82
Got it! Thanks! I'm getting a module. Hopefully there is no additional coding needed and everything show up properly.
Here is the code that I input earlier, please let me know if I'm doing anything wrong:
VO added 8TH
HU_NBT2 EXBOX, SPEEDLIMIT_INFO = aktiv
KOMBI Anzeige_Konfiguration, SPEED_LIMIT = aktiv
KOMBI KI_PIA_SPEED_LIMIT = aktiv
KAFAS2 SLI_ON_OFF = F20 F30...
      10-20-2019, 10:52 AM   #6
IAmATeaf
IAmATeaf's Avatar
Wow that looks so much better than the blank black area under the speedo.
      10-22-2019, 05:16 AM   #7
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
94
Drives: BMW 320d
VO added 8TH
You also need an adapter for enabling speedlimit info, coding alone wont do the job.
      10-22-2019, 06:56 AM   #8
drdonuts
Taiwan
Drives: E92 F20 F82
You also need an adapter for enabling speedlimit info, coding alone won’t do the job.
I'm getting one on Ebay, FSC code option is just way too expensive. Hope the changes I randomly added didn't mess up anything. Thanks a lot to clear this out!
Yea, indeed it's really eye catching on an entry car like this F20.
      10-22-2019, 02:24 PM   #9
IAmATeaf
IAmATeaf's Avatar
Oh I thought you had fitted it to an f30?
      10-23-2019, 09:56 AM   #10
Mikef30335
Drives: BMW F30 335xi
I thought only M models can have the current speed displayed, or does it come with newer cars or some adaptive cruise control package. Mine is an F30
      10-23-2019, 12:38 PM   #11
drdonuts
Taiwan
Drives: E92 F20 F82
No, it's from a F20 LCI. My bad came to F30 asking for coding on a F20 causing confusion.
Adaptive cruise control sounds way too fancy that I really never seen F20, F80/82 around equipped. I believe newer F-series cars all equipped with this newer instrument cluster. By the way, I saw bunch of F30s went for all digital instrument cluster upgrade which is way cooler.
      10-23-2019, 05:54 PM   #12
Ibo24
New BMW owner
Ibo24's Avatar
Belgium
94
Drives: BMW 320d
F20 LCIs get this by standard when ordered a pro navigation.
F30s get the full digital or the 6WA.
      10-24-2019, 07:07 AM   #13
drdonuts
Taiwan
Drives: E92 F20 F82
Module came in earlier, I had it installed and only coded KOMBI and HU_NBT's SLI option.
Because when I try to code KAFAS's SLI related options I found out the circle start blinking. I'm gonna try to have it tested and see actual speed number will come up or not.
