BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Buzz around steering column. Caused by run flats?
proTUNING Freaks
      10-22-2019, 04:21 AM   #1
Chill59
Chill59's Avatar
Drives: 4 Series convertible
I'm getting an intermittent buzz at certain resonant frequencies, mainly on newly gritted, slightly course, residential roads (around 30 MPH).
I'm planning on fitting non-runflat tyres in the near future.
Do you think this might cure the steering column buzz given that regular tyres give a slightly softer ride?
      10-22-2019, 06:05 AM   #2
HighlandPete
Drives: BMW F11 535i Touring
That's a difficult one to guess at, depends on the cause. Only one way to find out.
      10-22-2019, 08:02 AM   #3
Sasquartch
Drives: 520i G30
Definitely possible. My 328i on 18" runflats does sometimes have a bit of dashboard vibration on rough surfaces
      10-22-2019, 08:43 AM   #4
Chill59
Chill59's Avatar
I find it hard to comprehend why BMW are prepared to settle for added road noise and ride harshness for the sake of fitting runflats rather than supply a jack and spacesaver. Unbelievable!
      10-22-2019, 08:59 AM   #5
HighlandPete
If that those were the only reasons for fitting RFTs, I'd agree. Back in the early days it was clear more was involved. According to BMW, run-flats were a highly requested feature by users, for safety reasons. Plus benefits for vehicle design, use of space, weight reductions, emissions and more.
BTW, road noise and harshness is only partly due to run-flats. Even some non run-flats will appear just as noisy and virtually as harsh.
      10-22-2019, 09:30 AM   #6
Chill59
Chill59's Avatar
I hear what you're saying but noise/refinement should surely be more important in a luxury saloon?
The amount of road noise was the very first thing that struck me when I first drove my car.
      10-22-2019, 01:30 PM   #7
HighlandPete
You'll be opening up a can of worms calling a 3 or 4-series a luxury car.
Noise intrusion in the F3x models is well documented. Some models do seem to be more noisy than others, and it isn't simply down to tyre choice. I remember my first drive in a 328i and tyre noise was high, very surface dependant, worse than my E91. Even an F30 with higher profile, non run-flat tyres, was just as noisy to my ears.
Slightly sideways, was talking with the manager at my local National Tyres, and we got to discussing tyre noise and what tyres (using the tyre labelling drive by noise data), would be best in my 5-series. He didn't think (based on his experience), I'd notice much difference in a 5-series, due to the good insulation from road noise. 3 & 4-series is a different issue, we know that through both airborne and structure-borne pathways, we get more noise into the cabins than with a 5-series. Clearly BMW target a different market with the 3 & 4-series. There is less isolation from road noise.
      10-22-2019, 02:23 PM   #8
lear45xr
Drives: 420i msport
My first 4 series had a buzz around the steering column surrounds over roughish roads stopped when I put light finger pressure on them. My current 4 series which was brand new made some noise.
      10-22-2019, 02:55 PM   #9
James-335dx
James-335dx's Avatar
Drives: F30 335d M Performance
As above I've also often had a buzzing/vibrating noise which I finally found out to be the plastic trim behind the steering wheel. Stops when I give it a bash. Might try and tighten the screws or put a bit of foam or something in there to stop it. I've also switched to NRF and it still does it :
      10-22-2019, 04:24 PM   #10
Chill59
Chill59's Avatar
Thanks for all your observations guys ...much appreciated
...and sorry for calling 3/4 series a luxury saloon. I did, of course, mean sports saloon/coupe.
      10-23-2019, 02:27 AM   #11
RobUK
RobUK's Avatar
Drives: 340i MPPSK
My understanding was always that BMW fitted RFTs because they didn't want the weight of a spare plus jack etc., upsetting the near 50/50 weight distribution? (Also why the battery is in the rear). That could of course be complete BS
Life is a state of mind
      10-23-2019, 04:26 AM   #12
Wills2
Barge driver
Wills2's Avatar
Drives: X3M
It is but you've got a 4 series....which is a sporty (ish) 2 door, if you think your car is harsh and noisy don't try an M3/4 they come with non RFT but make a right racket.
I doubt it's your tyres.
X3M/Z4C, Gone G11 740d xdrive/F80 M3/F10 M5/F31 335d/e92 M3 x 2/F10 520d x 2/997 C2S/e46 M3/e46 320d/SL320/Touareg 3.2V6/Audi allroad 2.7TDi
      10-23-2019, 05:51 AM   #13
liam_
liam_'s Avatar
Drives: F30 330d M Sport
I have the exact same issue, good old bashing makes it go away for about 5 mins.
Keep us updated if you manage to fix it!
BMW F30 330d M Sport - Black Sapphire
      10-23-2019, 07:24 AM   #14
James-335dx
Ha, ha, yeah 5 mins or so then it's back again. I will have a go and see if I can get it to stop and let you know how I get on.
