02-05-2017, 09:51 AM | #3 |
Rep 46
93 with 30% e85 so around 96.... these numbers seem way off considering there was a 340i that dynod 367 so around 400 on a dynojet and i beat him bad in a race
02-05-2017, 11:10 AM | #4 |
Rep 693
02-05-2017, 03:20 PM | #7 |
Rep 1,782
Try running Map 7 BMS ran e30 blend on map7 and made good power on a dynojet
13' 335i M Sport. EBII/Coral Red 6MT. RPI GT exhaust, Resonator delete, PS1, GFB DV , BM3 Stage 2, ER CP, VRSF DP, VRSF 5.5in Stepped FMIC, Dinan Shockware. Carbon M Performance rear diffuser. M4 trunk lip. Conti DWS06 225/40/19 and 255/35/19
02-05-2017, 05:10 PM | #8 |
IG @bmwF9xG80
3813
Rep 7,593
Try finding a Dynojet place instead, Auto dyno in 4th gear and manual dyno in 5th gear
60-130mph 6.5s X4M #HCP
02-05-2017, 06:02 PM | #10 |
IG @bmwF9xG80
3813
Rep 7,593
Automatic gear ratios – IV/V/VI 1.67 / 1.29 / 1.00 Most people dyno 8spd auto in 4th gear so less heatsoak, tell dyno guy to do 1 pull in 4th & another in 5th see how you hit speed limiter on 5th gear unless you're flash tuned. but on manual its a must 5th gear cuz they're 6spd.
02-06-2017, 02:17 PM | #12 |
Rep 191,215
There is no point in doing a dyno with mao 5 since boost will constantly change.
As mentioned above, you need to always datalog. I see three runs, is one of them stock?
Chicken_Joe608.00 |
02-07-2017, 06:01 PM | #13 |
Rep 46
None of them is stock, all the other runs was just random dynos because he couldnt get the car to stop shifting :| ... and some other pulls where he didnt k ow what gear to be in all on map 5
02-07-2017, 06:05 PM | #14 |
Rep 698
It should stay in gear with the trans in sport mode and manually shifting with paddles as long as he doesn't push past the little click when you push the pedal to the floor
02-07-2017, 09:08 PM | #15 |
Moon Parasite
655
Rep 1,336
Yeah kinda sounds like he was hitting kickdown with the dyno.
2020 X4M Comp. (currently stock) - Was 2015 335 MSport -MPPK -Borla ATAK -Dinan Sport+ - E.R. Charge pipe / 2013 X1 35i Sport - Dinan tune / 2009 X6 50i Dinan badged |
02-08-2017, 08:34 AM | #16 |
Rep 115,999
02-08-2017, 01:11 PM | #17 |
Rep 4,323
need 4th in sport.
02-08-2017, 01:12 PM | #18 |
Rep 4,323
Mike, what's that?
02-08-2017, 01:34 PM | #19 |
Rep 305
02-08-2017, 01:38 PM | #20 |
Rep 191,215
+1
02-09-2017, 12:00 AM | #21 |
Rep 46
No it was in sport+ with paddles selected (M1-8) but i believe he did not admit it and just had it in sport+ (S1-8) the first time he did a pull which uses kickdown... anyways now that i look at the numbers, it feels like maybe the jb4 kicked itself into map4 for some reason... i wish i logged 😑
02-09-2017, 02:55 AM | #22 |
Rep 698
Even if the paddles are selected it will still kickdown if he pushes the pedal past the point. It doesn't matter whether the trans is just in sport auto or sport with paddles active
