05-21-2023, 02:09 AM | #1 |
Rep 10
F30 Steering wheel not centered?
Hi guys.
Got an f30 340i, and went for a longer drive today.. when my shoulder and back started hurting. Unaware til now, my steering wheel is massively offset to the left and my body compensates for it. I know I can adjust the height and depth of the steering wheel into position.. but surely I can move it side to side too? Look how far left off center it is from my sitting position. This can't be safe.. would the airbag even fire at me, or blow my left shoulder instead? Surely there's a way to adjust it.. Last edited by -BigMac-; 05-21-2023 at 02:44 AM.. |
05-21-2023, 03:45 AM | #2 | |
Rep 15,858
Looking at your picture, your wheel does appear to be offset, out of alignment from the binnacle display. To me, that doesn't look right, I'd be checking if there is something wrong. I'd also second check against another F30, see if your example has a particular problem. |
05-21-2023, 03:54 AM | #3 | |
Rep 10
Would you say this could be a safety issue? Not really the level of quality assurance one would expect from the brand.. |
05-21-2023, 04:00 AM | #4 | |
Rep 15,858
Regarding the offset, if it is out of design alignment, has there been an issue, some sort of fault, or damage? |
05-21-2023, 10:43 AM | #5 |
Rep 215
I have same car and that looks wrong. When you see Dealer please be very clear that you (and the car) are in distress, and that this is totally not acceptable. They are diagnosing you as well as the car when you go in. Best of Luck.
05-21-2023, 02:50 PM | #6 |
Rep 10
05-21-2023, 02:54 PM | #7 | |
Rep 10
Speaking with the dealership today, will update with the outcome. Last edited by -BigMac-; 05-21-2023 at 05:16 PM.. |
05-21-2023, 07:34 PM | #9 | |
Rep 10
Incase you are being serious.. I am sitting centered. Also, here's another forum I found with another owner having the same.. https://www.2addicts.com/forums/show....php?t=1100399 You had me second guessing myself. So i went and took this: Blue line = straight forward from center line of seat. Pink line - middle of 2 gauges to middle end of seat. BMW logo is to the left of the seat, and even further left than the gauges. Last edited by -BigMac-; 05-21-2023 at 08:03 PM.. |
05-21-2023, 08:41 PM | #10 |
Rep 215
Ok, so I started out Many years ago as a draftsman which means my opinion is worthless I may be totally wrong, but isn't the entire drivers seat off center a few degrees clockwise? Given that, then it may not be correct to use it a a reference for the red center line between guages.
05-21-2023, 08:47 PM | #11 |
Rep 215
Looking further, the area directly below the end of the blue line wrong. The rectangle type shape top line slopes to the right, while the bottom line of the rectangle appears to be square with the seat back. The ends of the rectangle slope inwards.
05-21-2023, 09:21 PM | #12 | |
Rep 10
No matter where the line on the seat starts, the steering wheel is still to the left of the gauges. Don't know how such a big mistake could be made by such a brand |
05-22-2023, 04:35 AM | #13 | |
Rep 15,858
Same is often argued for other models, including the F10 5-series I drive. We've had similar threads where a user states how bad it is, whereas most hardly even notice it. May have to sit in the vehicle and really study it in detail. Sure, there are points we could make. Another could be, why is the dead pedal not be exactly the same offset (from centre of seat) as the throttle is on the other side? One leg has a couple more degrees of swing to sit straight, etc. I guess some of us are more sensitive than other drivers to these issues. BTW, it's not just BMW, other marques also have issues with alignment for a perfect driving position. |
05-22-2023, 06:22 AM | #14 |
Rep 528
Drives: 2019 440i XDrive GC
I drove a friends GTI years ago and felt like the pedals were offset from the seat and wheel leaving me feeling like my body was twisted in the car. That was the most i've felt that in a car. At first i thought it might have just been that one car (buddy's dad owns a shop so who knows if the car had previously been damaged or something). My brother test drove a GLI and GTI back in the day (before getting a 2013 WRX) and I recall him saying the same about the pedals feeling offset to one side... And people LOVE the GTI and praise it for its driving feel. I personally hated the feeling and was happy to go back to my own car after a short stint in the GTI. Granted that was a stick and the clutch felt like it was directly under the steering wheel which made the issue even more apparent. Not sure if i would have noticed it as much in an auto... either way, I understand that its an uncomfortable feeling to not be "aligned" when driving. Hopefully its something easy to remedy.
Current: 2019 440i xDrive Gran Coupe - Alpine White, Coral Red Dakota Leather, 8AT, MSport, THP, BM3; 2015 X5 35i xDrive - Mineral White Metallic, Mocha Dakota Leather; Previous: 2015 Subaru WRX - World Rally Blue, Premium, FBO+Tune
05-22-2023, 09:51 AM | #15 | |
Rep 215
