01-27-2015, 09:46 PM | #23 | |
2154
Rep 5,011
I have kits in stock that can ship immediately. |
01-27-2015, 09:54 PM | #24 |
@obriennathaniel_f30 on Instagram
515
Rep 1,062
Drives: 582whp/596wtq '13 335i
Lol awesome. I just drive my car normally, no tracking so I wanted some of my comfort back. If the situation I'm dealing with with my KW V2's goes awry, I'll be sure to get some of these from you.
01-28-2015, 06:38 AM | #27 |
515
Rep 1,062
So these are basically KW V3's right? What makes these so much cheaper?
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
01-28-2015, 06:48 AM | #28 |
Rep 3,089
02-13-2015, 01:05 AM | #29 |
Rep 577
So I just installed the BC Racing Coilovers on my 328 F30, and I've got to say I'm seriously impressed.
This is my first Coilovers set, though I've done quite a few spring only changes before, so I don't have much to compare to, but in my opinion they are well made and terrific value. Now they may not be made from stainless steel, but hey neither are the polish made BMW struts. The finish is really solid and everything seems very sturdy. I should add that I'm a mechanical engineer, so not a complete novice when it comes to manufacturing, part quality, etc. As for the all important ride.... It's a complete transformation. Like others have said, the M-Sport suspension sucks! It's crashy over bumps and pot holes, making it seem hard, but then the body roll is all over the place. The BC setup is smooth over bumps and pot holes (I purposely steered into some known bumps and holes I typically avoid) which I honestly was not expecting, given the fact that I'm on 20" wheels with pzero runflats! Also the body roll issue has gone away and even with the lower ride height the suspension is smooth and nimble. This is what the M-Sport suspension should be! I chose to go with the standard springs the set came with and I have set the dampers to 10 clicks from softest to start with.As I said I don't have a lot of experience with coil overs and these adjustment, specifically with changing spring rates, but right now I couldn't see why I would need to. With regards to height adjustment, I've dropped the car around 1" all around (1finger gap between the top of the tire and the fender arch), and that is only a fraction of how far these could go. I think the maximum I would take the car to is half way on the available range. Anything lower and I reckon I'd be rubbing in turns for sure. I'm about to install a Varis style CF front spoiler lip, so I may well be raising it up a little. Something that is not a big factor (since it's mostly about performance) but is something I like... They are painted black. Not some bright color that screams modified. I like this subtlety. Good choice by BC racing IMO. Obviously time will tell on the quality and longevity of the BC racing set, but I've got to say that right now I feel rather happy that I took the risk. The camber plates and damper adjustment are great features that I wouldn't have got if I had gone with another brand for what they cost. I'm quite interested to see what I can get out of these two features in future. As for the install... It wasn't that difficult, but since it was my first attempt I took it slow. It took me pretty much all day, though I did have to go out and get a couple necessary tools. 1) spindle housing spreader and 2) Strut nut socket. Without those you would have a tough time. I'm sure you can improvise, but it wouldn't be much fun. Tools I got before the job after reading other reviews: 21mm socket and 21mm wrench. I had metric tools (10 through 18mm) and Torx bits already. Oh and you definitely need a low profile jack, good jack stands, a breaker bar and a torque wrench (good for 160Nm). I will try post some pictures tomorrow once the spoiler gets installed and car gets cleaned. |
02-13-2015, 08:38 AM | #30 |
Rep 3,089
NICE!! I am on the fence between the BC Racing and Bilsteins. With all coils I am most concerned with the ride height being too low. Like you I prefer about 1/2' gap between top of tire and fender. Could you have raised it a bit higher if you wanted? Did you get the car aligned as well? It would be interesting to see how the camber plates can help getting the alignment back in spec. Finally, how easy is it to adjust the damping settings? Can it be done from the bottom without taking the wheel off?
Looking forward to the pics!
02-13-2015, 08:56 AM | #31 | |
2154
Rep 5,011
02-13-2015, 08:58 AM | #32 | |
2154
Rep 5,011
The dampening settings are on the very top and the top side of the strut, which could be accessed without removing the wheels (but on a jack). Let me know if you have any other questions, I have these in stock and ready to roll. |
02-13-2015, 09:03 AM | #33 | |
Rep 3,089
02-13-2015, 09:49 AM | #34 | ||
Rep 1,035
That being said ... i absolutely love my BC Racing BR-type coilovers I've had mine for about 6 months now, and have had absolutely no problems. I don't track the car. I have the damper setting at 24 currently (0-31 click range with 31 being the stiffest setting). I'm lowered about 3" and i need to not bounce around. 24 provides the best comfort at the absolute minimum stiffness i need to be able to go over anything without scraping/rubbing. I heard that at the softest setting (0-clicks), it will feel like a boat, but i can't think about going there because i'm lowered so much. So I've never tried that. The springs and struts are matched and tuned to work together optimally. BC goes as far as dyno-testing each damper for their compression/rebound rates then matching the left and right units within a single digit percentage tolerance. I thought i read online somewhere it was around 3-5% variability/tolerance. And just by visual inspection, i can see that the manufacturing of this part is high quality, made of durable and robust materials, and precise construction. I know its made in Asia, but things manufactured in Taiwan are typically way better quality than things made in China, but YMMV. I hear the comments about BC's being "cheap" and "ghetto" versions of kW or other higher-priced coilovers, but i don't get it. To me, what matters are the real features that you will actually feel, touch, and see. I can't justify kWs that are anywhere from $2k-$3k with less features. At a minimum, i need: 1) ride height adjustability 2) damper setting adjustability for stiffness control 3) springs that are tuned/optimized/matched to the struts/shocks And all this for about $1k. So the only other thing is durability. I've only had mine 6 months, so i can't say yet how durable they are. Ask me again in a year or two. But so far so good... Last edited by squidlyboy; 02-13-2015 at 10:11 AM.. |
02-13-2015, 10:10 AM | #36 |
Rep 3,089
Can you please explain this more? I am relatively new to BMW, having only installed coils on my previous Audis. Adjusting the rear ride height just required me to take off the wheels. Why does the control arm have to removed?
02-13-2015, 10:40 AM | #37 | |
Rep 1,035
With that said, the issue is with the spring having to be pre-loaded to a certain tension to keep everything in place. Once you mess with this pre-loaded tension in the spring, you need to re-do it to get it back to its original pre-load tension. Otherwise, you risk your suspension parts coming apart as your car is bumping along on the road. The way the front coilovers are designed, the spring and the ride height adjustment are completely separate and independent. So when you adjust your ride height there, the spring pre-tension doesn't get messed with. So for the fronts, a few turns of the adjustment collar gets your ride height set, and you are done in a few minutes. For the rears, the spring and the ride height adjustment are in the same assembly. In fact, the ride height adjustment is sitting just above the pre-loaded spring in line with it. Its near impossible to change the ride height because the spring is pre-loaded against it, so you would have to be superman to change it. So what they have you do is remove the control arm to release the spring, so that you can freely move the ride height up/down to your liking. Well, now you've untensioned the spring, so you need to get it back to its pre-load tension. So after you adjust your ride height to where you want, you need to re-attach the spring against the ride height adjustment, then change the height of the shock/strut to pre-load the spring back to its original tension. Its a ROYAL PITA, and something i searched high and low in these forums and on the internet in general to find out how to do. Its not well documented, and the BC install instructions are almost completely worthless in that regard. Its very vague on how to adjust rear height. I documented the issue here in this posting a while back. The picture i posted will help you understand what i'm talking about. |
02-13-2015, 10:59 AM | #38 |
Rep 3,089
^^ Thank you. On my previous coils (KW). all I had to do was adjust the collar. The spring and ride height assembly was also the same. It wasnt easy but definitely doable even with all the spring tension pushing against the ride height adjustment collar. I would imagine you can do the same with the BCs??? In looking at the image from the post you referenced, I dont see why you cant just turn the collars on top?
02-13-2015, 11:37 AM | #39 | |
Rep 1,035
But even if you were able to, the fact that you have now changed the vertical distance in the same column where the spring is loaded, it seems to me that this would change the pre-load tension of the spring (albeit slight), which would mean you would have to pre-loaded again to insure you meet the original spec. Let me see if i can picture this correctly.... if you lower the ride height, collar shortens, and spring untenses. Increase ride height, collar increases, and spring compresses. If i'm thinking of that correctly, lowering the ride height would be easier than increasing ride height because its easier to allow spring to untense than to compress. |
02-13-2015, 03:47 PM | #43 |
Rep 3,089
I would just like to get confirmation that the rear ride height can be adjusted without having to remove any of the suspension components.
@obriennathanial - still no solution to your KW issue?
02-13-2015, 07:37 PM | #44 |
515
Rep 1,062
well i just bought these lol. and it turns out that the ones velos sold me ( i was under the impression they would work on my car cuz he said they would) are only for a car with EDC. i asked for my money back but i havent heard from then in over a week and a half. So now im stuck with some KW v2's without the EDC parts, so theyre useless to sell.
