BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > HPFP New Option
      03-13-2019, 09:25 PM   #67
Daleb
Drives: M2
The e20 log is a little strange, boost/load is quite a bit off target. Some of your older logs had some erratic boost control too. A slightly leaner afr might give you the room to run e20 at this load.
With the e40 m2 logs I expected to see a fairly clean e20 log on yours. M2 on oem flash has a richer afr which adds extra stress to the hpfp. On a proper map with a more suitable afr i’d expect to see a higher ethanol tolerance over the jb4 setup.
This hpfp upgrade might just be suitable for the stock turbo guys looking to max out performance there. Hopefully your tuner can get you an e20 specific map to test.
      03-14-2019, 01:19 PM   #68
FastF30
FastF30's Avatar
521
Originally Posted by T_H_O_M_A_S View Post
93oct
https://datazap.me/u/thomas/log-1552302396?log=1
E20
https://datazap.me/u/thomas/log-1552511070
same engine map different fuel . what do you think ?
I keep telling you guys... we got a built-in dyno with MHD... Your "Torque act. clutch nms" on average is 10nms higher with the E20..... just like I thought it would be higher.... but I was expecting a little more...
      03-15-2019, 09:09 PM   #69
Daleb
Drives: M2
B58 on Stock turbo and fuel system running e85 on BM3.....
https://www.instagram.com/p/BvCwJV8n...d=tc6tkv5hhwwf
AFR is leaner but it shows that the hpd5 evo can support e85 with the required tuning.
      03-15-2019, 10:20 PM   #70
Ownnij
Drives: F30 335i
thats a lot of power on stock turbos.. i wonder how much power a n55 can make with that fuel pump
      03-19-2019, 03:18 AM   #71
harkes
harkes's Avatar
China
1078
Drives: M135i, E39 M5, NSX and AE86
Do you know how we translate that torque reading into crank/wheel Nm? Mine is reading 530 here but I am pretty sure that is more than 530 wheel Nm.
Momir@MHD
(A Dane in China)
      03-20-2019, 03:29 AM   #72
SHI
Drives: 2013 F30 335ix
Momir@MHD
hi,we have a N55 WeChat group in china,my WeChat 13366600015
      03-24-2019, 07:29 PM   #73
racemepunk
racemepunk's Avatar
Drives: 2013 335i xDrive
I was having HPFP problems so i decided to give this a try.
Before:
https://datazap.me/u/racemepunk/4th-...16-20-21-22-24
After changing HPFP:
https://datazap.me/u/racemepunk/4th-...-5-17-21-22-24
i have been waiting for my tuner to poke at the HPFP to see if it will hold up.
      03-27-2019, 06:07 AM   #74
Daleb
Drives: M2
Before:
Logs look good, what’s your mods/spec?
When fitting the b58 hpfp did you use the sealing o-ring the n55 hpfp uses? I notice the b58 hpfp does not use one.
      03-27-2019, 09:22 AM   #75
racemepunk
racemepunk's Avatar
2013 F30 335i xDrive Stock turbo, VRSF 5" intercooler, catless downpipe, Injen air intake,
FTP charge pipe + boost pipe, Walbro 450 fuel pump,
2017 430i HPFP and MHD E30 custom map.
I used the o-ring from the N55.
2013 F30 Mineral Gray 335i xDrive Sport Line, FBO, MHD E30 Stage 2
      03-27-2019, 12:20 PM   #76
adrien78
France
52
Drives: BMW F30 335i
2013 F30 335i xDrive Stock turbo, VRSF 5" intercooler, catless downpipe, Injen air intake, FTP charge pipe + boost pipe, Walbro 450 fuel pump, 2017 430i HPFP and MHD E30 custom map.
Hey, can you try full E85?
      03-27-2019, 12:43 PM   #77
Pray for Mojo
Drives: 2014 M235i & 2018 X3 M40i
Anyone know what the max psi we can get out of this? Mine stock N55 HPFP hits 2,900psi according to BM3 logs. Haven't seen anything higher with the evo pump in people's logs. Not even sure if the MHD logs are measuring the same thing as the BM3 ones.
      03-27-2019, 03:35 PM   #78
racemepunk
racemepunk's Avatar
I spoke to 2 different tuners and they both said 40% is the most the N55 fuel system can support.
      03-28-2019, 06:39 AM   #79
adrien78
France
52
Even with the B58 hpfp?
      03-28-2019, 08:04 PM   #80
T_H_O_M_A_S
Drives: M140i
Before:
nice results man , boost can be a bit higher too hope your tuner can sort it out
M140i DP , OPF delete , MHD stg2 93oct , xhp stg3
      03-28-2019, 09:39 PM   #81
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
With the Walbro LPFP I run 50% all the time, and I ran as high as 60%. I am PWG N55.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      03-31-2019, 10:18 PM   #82
listed5
Drives: 2011 e93 M3 DCT black/bamboo
Before:
Wow, the b58 pump makes a tremendous difference in rail pressure! I need to do this mod ASAP!
      04-04-2019, 07:57 PM   #83
Tchao
Boost Addict
Tchao's Avatar
334
Drives: E30, E82, F30, F87
JordanTune just released full E85 flash for B58...stock fueling.
So we just need to find how to calibrate the B58 pump correctly to our N55...
S55 M2C | Three Pedal Club | E30TU
      04-05-2019, 02:50 PM   #84
Jpup
Drives: 2015 435i
This.
I wonder if the tables exist for the N55 so it can run the B58 pump full E85. Hoping some of the tuners can chime in.
I do know that for full e85, it can only handle it on stock turbo. If you upgrade the turbo with the B58, the hpfp can not supply for E85 at higher boost levels.
2015 435i (current): VRSF Catless Downpipe, Bootmod3 Stage 1, xHP
2008 Corvette (sold):Vortech supercharger, ported/built heads, catless
2015 M235i (sold): CTS Turbo Intake, VRSF Catless Downpipe, CSF FMIC, MPE, xHP, Bootmod3 Stage 2 E30
      04-05-2019, 03:42 PM   #85
Munchi435i
Munchi435i's Avatar
Drives: 2014 Alpine White 435i M-sport
Originally Posted by Jpup View Post
This.
Most likely would need to upgrade injectors and LPFP to run full E85 even with the B58 pump.
435i M-Sport | Pure Stage 2 Turbo | MHD Tune | XHP Stage 3 | Wagner Comp Evo 2 | MPE | Evolution Racewerks CP/DP/TIC | M-LSD | XDI-35 |
      04-06-2019, 04:58 PM   #86
RSicks
Typical Car Guy
RSicks's Avatar
Drives: 2015 435i M-Sport
This.
You have to remember this is not just a coding thing. There are many differences between the N55 and B58 fueling. While the pump may help the N55, there are few bigger differences...
Look how the outlet of the pump separates into 2 hoses to our 1. (Part 5)
Now look why, there are 2 separate fuel rails where we have 1.
And this is just the tip of the fueling iceberg as this is only the equipment side. I do not know the compression differences, where the AFR's lie - whether the B58 runs more lean or rich, etc. If a tuner would like to jump on the N55 using a B58 hpfp, we can see what its made of. There have been articles saying the B58 is also fueling limited and Mission Performance and APR has already started looking at an upgrade for the B58. So please note that this is not the end all for the N55 hpfp woes, its just a great step forward without having to spend +$2k.
'15 435i ///M Sport
CTS Intake • VRSF CP/Race FMIC/DP/TIC • MST Inlet • xHP S3 • 3.5 TMAP • Dorch S1 HPFP • Wedge Tuned
Jpup26.00
      04-06-2019, 08:30 PM   #87
T_H_O_M_A_S
Drives: M140i
this setup will give you more equal pressures on every injector
      04-08-2019, 03:20 PM   #88
sea_m2c
sea_m2c's Avatar
82
Drives: 2019 M2C - 6MT
Hey Thomas,
Do you have any additions pictures (like the ones on N54 Tech) of the cuts you made to the B58 pump in order to get it to fit? I see the picture that shows where the new mounting hole is drilled which seems pretty clear. I notice that you also cut off part of the mounting bracket though and would like to see what that cut looks like if possible.
Looking to do my pump install this weekend and begin logging/testing. Thanks!
-Chris
Current: 2019 M2 Comp, Coilovers, Camber Plates, Rogue SSK, AA Single MP, BM3 Stg 1
Sold: 2015 M235i RWD, MHD Stage 2, FBO, MPE, XHP, HPD5Evo | IG @sea_m235i
