06-17-2020, 04:09 PM | #67 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
Sorry to bring up an old thread.
But I am going to be getting FBO with BM3 license, plan is to get custom tune by Jordan. With that being said, I have read that I need to get 1 step colder plugs. If I read correctly, I need: NGK 97506 (SILZKBR8D8S) Is this correct? |
06-17-2020, 04:18 PM | #68 | |
Rep 7,606
I am pretty sure the NGKs are two steps colder. |
06-17-2020, 04:37 PM | #69 | |
Moto Lover
187
Rep 591
06-17-2020, 06:05 PM | #70 | |
Rep 5,392
Stage1 just use stock Bosch plugs with stock gap Stage2 use NGK 97506 gapped down to 0.022" Lots of counterfeit 97506 on eBay etc. Buy from reputable dealer like FCP Euro which provides lifetime replacement |
06-17-2020, 06:42 PM | #71 | |
Rep 7,606
Also, the blanket recommendation to run those plugs/gap with a stage 2 tune is unnecessary. MHD recommends OEM Bosch even for stage 2+ and it is what i personally run for stage 2+ E20 tune. Also, ozymandias435 switched from those plugs/gap back to the OEM Bosch and had immaculate timing on BM3 stage 2 93 OTS map, and logs looked better in other respects as well. There really is no reason to go to a colder and a significantly smaller gap unless you have a tuner than wants you to run that or you have issues with the OEM plugs. At the same time, people can experience cold start/idle issues with the colder plugs and smaller gap. Additionally, you could consider if you will have other issues running a colder plug, such as fouling if you frequently take the car on short trips. Everyone's car responds differently so it's a little hit and miss, but generally speaking, theres no reason someone needs to immediately switch to the NGK 97506 gapped down to 0.022" just because they are going to run a OTS stage 2 tune. I do agree with being careful about counterfeits. Last edited by thejeremyman9; 06-17-2020 at 06:57 PM.. |
06-17-2020, 06:51 PM | #72 |
Rep 316
For the record they aren't 2 steps colder for the n55 motor. the plugs referenced in this thread are only one step colder in relation to n55 and 2 steps for n54. He'll be fine either way. Check with tuner.
06-18-2020, 03:46 AM | #73 | ||
Rep 5,392
06-18-2020, 03:52 AM | #74 | |
Rep 5,392
The N54 was the previous engine so spark plug conversations were typically how much colder plugs were in relation to stock N54 plugs. Then the N55 engine came along and used stock plugs that were one step colder than N54 stock plugs. So NGK 97506 are one step colder for N55 engines. AND the same NGK 97506 are two steps colder for N54 engines. |
06-18-2020, 06:09 AM | #75 | |
F36 GC
143
Rep 259
Every log I have taken since putting factory plugs back in has had better timing than any log that I took while I had NGK .022 plugs in. As soon as I flashed Stage 2 BM3 I installed the NGKs per their recommendation but my timing was never clean. In search for better timing I bought the Bosch factory plugs, checked them all (.030 out of the box), reinstalled them and produced perfect timing in logs and more power on Virtual Dyno. He was one of the reasons I went back and tried the factory plugs again. I am certain that he knows the recommendation but is just stating that the recommendation may be a little premature for the power levels of a stock turbo. For my car specifically I was able to prove this. Could be totally different on other peoples cars without a doubt as some people do have success with .022 gaps on stage 2 maps. This is just my experience with plugs and timing so far. |
06-18-2020, 09:34 AM | #76 | ||
Rep 5,392
I haven't had any issues. Engine runs smoothly and logs look good. I have an N55 EWG. Is yours PWG? I haven't taken note if there is any PWG/EWG correlation to spark plug observations. Anyway, I was running stock Bosch plugs at stock gap on BM3 Stage1. When I installed BM3 Stage2 I also followed the PTF recommendation to upgrade the spark plugs to NGK 97506 and gap them down to 0.022". NGK 97506 are considered to be 1-step colder for N55 and 2-steps colder for N54. Its important to note that there is no "coldness" standard. Different brands of plugs usually have numbers in their model numbers that provide a coldness value so that their products can be compared to each other up and down their own product line. But since there is no standard, there is nothing reliable that says that (made up numbers) a Bosch "3" is the same coldness value as an NGK "8". So just in terms of coldness, the NGK 97506 are presumed to be colder than the stock Bosch plugs in an N55. Is it one full coldness number? Is it actually 1/2 of a value colder? Who really knows. It does not matter. It's just presumed to be a colder plug. I suspect that the gap is more noteworthy. A very experienced senior BMW dealer tech who mods his cars told me not to try to gap down the stock Bosch plugs. He said that they're not constructed for that. They are brittle and often break if you attempt to reduce the gap. NGK 97506 are constructed differently, so their gap can easily be reduced. Most guys don't understand why a spark plug gap would be reduced. Stock engines have spark plugs and gaps chosen for their characteristics including the amount of air and fuel in the engine cylinder when the spark plug fires. A turbocharged engine that has been tuned is now shoving a lot more air and fuel into the engine cylinder than was calculated by the original engine designers when they decided on the best spark plug and gap for the engine. Going back to high school physics, there are many more air and fuel molecules so it's much more dense. That spark now has a lot more molecules in its way when it's trying to jump the gap. It just gets too thick inside the cylinder at high boost levels. If the spark can't reliably jump the gap because of this increased fuel/air density it's called "blowout". This makes it sound like a candle that is blown out. This term is a misnomer because the spark doesn't make it across and get blown out. The spark never gets started in the first place. There are two typical solutions: 1) install some upgraded coils to increase the power of the spark, which can have its own issues, or 2) reduce the distance of the gap so that the spark can fire effectively and efficiently even in that new high boost, thick with fuel/air molecules environment. Pure Tuning Freaks must have done some calculations and trials based on these factors before deciding on making their NGK 97506 gapped at 0.022" recommendation for N55 BootMod3 Stage2. |
06-18-2020, 10:56 AM | #77 | ||
Rep 7,606
The varying experiences is exactly what i was getting at, and why i always say everyone's car responds differently. This is precisely why the spark plug debate will never die: - Some people try bosch and have misfires/timing issues, go to NGK, and it solves the problem. - Some people switch from bosch to NGK and have cold start/idle/other issues, switch back to a new set of bosch, and it solves the problem. All i was saying is that theres no reason to switch to the NGKs just because you are going to a stage 2 tune. Its not a prerequisite, but i feel like it is spoken like gospel. I am in no way saying the NGK are worse, or wont work, or anything of the sort. Its a perfect example of "YMMV". I agree the heat range ratings are different between plugs. The only warning i gave for heat range is potential fouling if you make only short trips with the car. I also agree that you should not change the gap on the bosch plugs unless you have an issue with one out of the box and need to correct it. But the gap out of the box is fine, so there is no need to gap down. Just do you know, I am fully aware of why a spark plug gap should be reduced, as i dealt with spark "blowout" and misfire issues on my 3000gt for years. I kept trying different plugs, heat ranges, gaps, etc, until finally a year ago i switched to a non resistor copper plug with a 0.026 gap and it finally solved my issues. If you want some non BMW reading, i even posted a thread about it here: https://www.3si.org/threads/spark-pl...ost-1056307591 So i agree that generally speaking you do need to reduce the gap as you increase boost - its a direct relationship with cylinder pressure. However anecdotal evidence has shown that this may not be necessary for our platform unless you are pushing extremely high power/boost levels. Infact i think it was Harkes that was running 20+psi with meth on OEM plugs and gap... again YMMV. I believe that the NGK plugs, colder (potentially) and with smaller gap are recommended because that is the "safer" plug for two main reasons: - Smaller gap is less likely to have misfire or "blowout" issues at higher boost levels - Colder plug is less likely to have detonation if the plug is overheated at higher boost/power levles So these recommendations are the conservative approach - they are more likely to run well at WOT even if there are some potential tradeoffs. Hopefully people can learn from reading our conversation here, but i can guarantee the spark plug thread will live to die another day, because there is no "best" plug nor one size fits all. Last edited by thejeremyman9; 06-18-2020 at 02:25 PM.. |
06-18-2020, 02:09 PM | #78 | |
F36 GC
143
Rep 259
06-18-2020, 03:44 PM | #79 | |||
Rep 5,392
06-18-2020, 08:39 PM | #80 | |
Rep 2,358
Stock Bosch at 0.03" gap:
(A Dane in China) |
ozymandias435142.50 AmuroRay2282.50 |
06-18-2020, 09:19 PM | #81 |
Rep 2,358
(A Dane in China) |
06-18-2020, 10:02 PM | #82 |
Rep 765
I wonder how well the S55 plugs will work in the N55. they are still a step colder but gapped @ .25 instead of the .18-.22 NGK's some people are running.. I think it's more popular for the 4 cylinder guys because they're running higher boost, but if some people are having trouble going as low a gap as what's recommended by some with the NGK's, maybe less of a gap while also going colder might help? I would also think they're cheaper than the NGK's.. any thoughts? dumb question?
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
06-18-2020, 10:39 PM | #83 | |
Rep 7,606
06-18-2020, 10:57 PM | #84 | ||
Rep 765
07-14-2020, 12:40 AM | #85 |
Rep 68
I wonder how octane levels will change the recommendations here
Some people use 91 octane, others 93. I'm using 95 octane as standard, and have the option to use 98 as well. The higher the octane level, it is less likely to have early detonation if im not mistaken, and this by itself may resolve the need to replace or upgrade the plugs. So , my question is should I go with 1 step colder plugs if I tune my car and use 98 octane? |
07-14-2020, 12:47 AM | #86 | |
Rep 7,606
Just curious, what is the price of your 95 and 98 per gallon? |
harkes1078.00 |
07-26-2020, 10:43 AM | #87 | |
Rep 68
07-27-2020, 11:13 AM | #88 |
Rep 7,606
