10-22-2012, 12:28 AM | #1 |
Rep 127
Burning oil smell from new car
Just want to make sure this is normal: When I picked up my car from the dealer we took it for a spin. When we got back I asked, "Why do I smell burning oil?" My CA said, "That's normal, they lube these engines up with oil when they ship 'em."
The smell is dissappating with every drive, so it seems like his info is accurate. Should I be concerned? |
10-22-2012, 12:47 AM | #2 | |
Rep 96
It actually smells like something was burnt. Not sure whether it was the smell of oil burnt. |
10-22-2012, 05:12 AM | #4 |
Rep 258
It could also be the brakes that smell.
/// M-Sport 328i // Packages -- Adaptive Drive-- Drive Comfort -- Function -- Visibility // 19" 403M // M-Sport Brakes // Harman Kardon // Head Up Display /// |
10-22-2012, 05:21 AM | #5 |
Rep 15,858
In my experience a couple of decent drives up to full heat soak, normally clears any oil type residue from parts that heat up, like exhaust, manifold, etc.
If you only drive short trips it can hang around for longer, until you cook it all off. If it persists, worth looking for evidence of some unusual issue, to be safe and sure there isn't an oil leak. HighlandPete |
10-22-2012, 08:59 AM | #6 |
Rep 286
Should be normal I had the smell for awhile and when I get on it hard and have the roof tilted I can still get a whiff of it, I also get a ton of soot on the back of the car too... BMW says its all ok
'12 335i Sport Apline White w/black... Totaled
'14 535i xdrive M-Sport Carbon Black w/Mocha Nappa |
10-22-2012, 02:23 PM | #7 | |
Rep 28
10-22-2012, 10:40 PM | #9 |
Rep 127
Thanks everyone! Day 4 and it's much less noticeable.
I hope the others who are having this problem after 6 months find an answer that isn't bad news. |
10-26-2012, 06:59 PM | #10 |
Rep 20
My dealer says its normal - apparently it's Cosmoline that is applied to cars shipped overseas and it'll burn off.
2022 X5 xDrive45e, Alpine White, MSport, DAPP, HK, M Brakes, Shadowline
2019 X3 xDrive30i, Phytonic Blue Retired: 2013 328i, Estoril Blue, 6MT, MSport |
04-14-2014, 02:35 PM | #11 |
Rep 543
Sorry to dig up an old thread but I wonder if what I'm experiencing is the same thing. I have a 2013 335i Msport with 700 miles and mostly I love it. However, there is a strange burning smell inside like burning plastic or crayon. It will start during the first hard acceleration and then usually last a few minutes before it goes away. Sometimes it will come back at various points during a longer drive. One of my passengers noticed it too.
Any thoughts? Also, I've noticed the car seems to run quite a bit hotter than my 328i did. Usually close to 250.
2014 335i f30 M Sport, Mineral Gray, Premium, Nav, Comfort Access, M Sport Brakes, 18" Potenza RFT Summer/Staggered
2011 328xi e92 M Sport, Space Grey, Premium, Nav, Comfort Access, BMW Apps |
04-14-2014, 03:21 PM | #12 | |
Rep 1,450
http://en.wikipedia.org/wiki/Cosmoline |
04-14-2014, 07:13 PM | #13 |
Rep 4,323
Exhaust burn in to...took me several thousand between engine and that.
04-23-2014, 11:43 AM | #14 |
Rep 1,739
Reviving this one again....hey I use the Search function......
Picked up my '14 335 yesterday and it has maybe 20 miles on it now. I drove to work in the pouring rain (man that sucks that my first day with it and it's raining). When I parked and shut the engine off there was quite a bit of steam or smoke coming out from the hood. Not billowing out like something burning, mind you. Just more than looks normal for a hot engine in the rain. Safe to assume this is cosmoline burning off? I sat in the car and didn't smell anything. It eventually stopped after a few minutes. |
04-24-2014, 09:00 AM | #15 |
Rep 600
I too noticed this smell on my car. However, oddly enough it seems to be coming from the sunroof/headliner area between the front windshield and front of the sunroof. It smells like burning crayons, and is worse with ambient temperature. I'm thinking it's the adhesive they used or maybe even the oil to lube the sunroof?
Jay (in San Antonio, TX)
2014 428i coupe, mineral gray metallic with black interior, black ash trim, luxury edition. Last edited by JRJ1970; 04-24-2014 at 09:16 AM.. |
04-24-2014, 11:07 PM | #18 |
Just Copacetic!
177
Rep 616
04-26-2014, 03:26 AM | #20 | |
Rep 78
I've also noticed this a few times on my '13 335ix MSport. |
04-26-2014, 07:21 AM | #21 |
Rep 214
My nose is as sensitive as a dog's nose. I still smell a bit of oil burn when I drive the car hard (8500 miles). But from experience, this is normal to me. Turbo cars I've driven tend to burn oil under hard acceleration. Possibly because of the high compression and boost in the cylinders. It would be concerning if it did it under grandma driving
P.S. Break in period was done the way the manufacturer recommends. So, no, I didn't mess up the rings etc.
Current: 2019 G05 x5 50i M-Sport
Past: 2016 F10 550i M-Sport ~ 2015 F83 M4 Convertible ~ 2013 F30 335i M-Sport ~ 2006 E85 Z4 30i |
